10-11-2015, 06:52 | #46 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Samsung S7582(clone) write IMEI error Read Info Code: Operation : Check / Read Info [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : A45J1 [eMMC] : FLASH_CID : FE014E50314A3534411205280199319B [eMMC] : FLASH_EXT : 00100000/00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
10-11-2015, 12:05 | #48 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Infinity Team
Member: 2072265 Status: Offline Thanks Meter: 46 | QMOBILE M90 READ FFW DONE WITH CM2 Card found : S/N : 7BD0661F , v0129 Chinese Miracle II [MTK module] v 1.33 Operation : Read Flash [ v1.33 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Read Flash [ v1.33 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D420158BDCA59A1F9 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D420158BDCA59A1F9 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : QMobile ProdName : QMobile ProdModel : M90 Device : QMobile AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_gionee82_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : spdata.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6582 / V1.1.1 / gionee82_cwet_kk / EMMC FW Size : 1196 MiB Scatter saved to : C:\Documents and Settings\SAGAR NADEEM\Desktop\MT6582__QMobile__M90__QMobile__4.4. 2__ALPS.KK1.MP1.V2.10\ All done! Done! Elapsed: 00:06:42 Reconnect Power/Cable! |
10-11-2015, 12:06 | #49 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 46 | SAMSUNG J100H READ FFW DONE WITH CM2 Card found : S/N : 7BD0661F , v0129 Chinese Miracle II [MTK module] v 1.32 Operation : Read Flash [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : A80111303443534D411036014DBC62B7 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00A8 , OEM : 0111 [eMMC] : FLASH_INF : AMSC4 [eMMC] : FLASH_CID : A80111303443534D411036014DBC62B7 [eMMC] : FLASH_EXT : 00200000/00020000 [eMMC] : FLASH_LEN : 0x00000000EA400000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : samsung ProdName : Galaxy J1 ProdModel : SM-J100H Device : j13g AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 [Read Ok] : preloader_keytak72_cwet_lca.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / keytak72_cwet_lca / EMMC FW Size : 933 MiB Scatter saved to : C:\Documents and Settings\SAGAR NADEEM\Desktop\MT6572__samsung__SM-J100H__j13g__4.4.2__ALPS.KK1.MP7.V1\ All done! Done! Elapsed: 00:04:40 Reconnect Power/Cable! |
10-11-2015, 12:08 | #50 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Hello, Done with NEw ver(permanent method) Code: Operation : Repair Security [ v1.33 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : A45J1 [eMMC] : FLASH_CID : FE014E50314A3534411205280199319B [eMMC] : FLASH_EXT : 00100000/00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 35534150411xxxx IMEI [01] : 35534150411xxxx IMEI [02] : 358688000000158 IMEI [03] : 358688000000158 Set IMEI [00] : 35534150411xxxx Set IMEI [01] : 35534150411xxxx Prepare finished. Security check required! Wait for phone... Phone found! [ 8 ] Sync... PostCheck Ok! Repair done! Done! Elapsed: 00:00:53 Reconnect Power/Cable! |
10-11-2015, 16:03 | #51 (permalink) |
No Life Poster Join Date: Mar 2013
Member: 1892312 Status: Offline Sonork: 100.1651296 Thanks Meter: 76 | huawei g610-u20 unfortunately system.dev has stopped. Card found : S/N : CEC7977B , v0129 Chinese Miracle II [MTK module] v 1.32 Operation : Check / Read Info [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 291 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT targted! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
10-11-2015, 16:23 | #52 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | @Zubair45ali Hello, Secure Boot select/check model setting if same , read it http://forum.gsmhosting.com/vbb/f296...ation-1978450/ |
10-13-2015, 11:28 | #54 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | New version released - http://forum.gsmhosting.com/vbb/f296...irect-2001395/ |
