Old 12-22-2015, 21:49   #1 (permalink)
Member: 1043909
Thanks Meter: 60,926
Chinese Miracle-2 MTK/Mediatek v1.40 - New Repair and Test features
MTK SP Platform
- New Features supported:
MTK Android: "HW Test"
Allow Check/Verify phone FlashIc (eMMC), test DRAM memory
Support eMMC:
eMMC Read/Write Test (eMMC ReadOnly verify)
DRAM Memory test: Data Bus, Address Bus, Pattern and Increment tests
Misc HW Test: Battery test (presense, type, level)
[Info]: eMMC test IS COMPLETELY SAFE - it not damage/erase/destroy Android or UserData!
Support NAND:
DRAM Memory test: Data Bus Address Bus, Pattern and Increment tests
Misc HW Test: Battery test (presense, type level)
- Factory Firmware Reading improved
Brand-specific improvements (HTC x64 and Oppo)
Some other improvements and bugfixes
- SmartAV engine improved
Data accuracy level improved
InternalDB updated and revised
Some other changes and improvements
APP Scanner improved
- Other
FlashLoaders updated and revised
"Preloader Init" feature improved
FlashID database updated
FlashInit DB updated, new FlashIC types supported
"CRC Errors" should be fixed. Again.
Separate "FRP Reset" option enabled in "Format FS"
Some improvements and bugfixes at all
MTK FP Platform
New types supported
FW reader engine revised
- UserData operations improved
Improved "User Code" read
- Other
Flash Read/Write revised
Some other bugfixes
Download link #1
Download link #2
Download link #3
New method to upload firmware files to support area - Flash Files Database - iosFileUploader
Infinity-Box 10 (ten) years (2005 - 2015) non-stop regular updates and support as nobody else - Infinity-Box - News
Unlock Codes (Huawei, SE, Motorola, Samsung etc.), iPhone Unlock, Software Activations - Infinity-Box Online Service
- Infinity-Box Dongle ready for delivery
- BB5 Easy Service Tool [BEST] Dongle
- CDMA-Tool Dongle (fast and easy unlock)
Twitter - Facebook - Telegram
The Following 61 Users Say Thank You to YellowBoss For This Useful Post:
Old 12-22-2015, 23:19   #2 (permalink)
abdulhaq_majroh's Avatar
Member: 1600947
Sonork: 100.1627298
Thanks Meter: 772
hello team add stop button on software
The Following 3 Users Say Thank You to abdulhaq_majroh For This Useful Post:
Old 12-22-2015, 23:33   #3 (permalink)
Aladdin994's Avatar
Member: 2266922
Sonork: 100.1659771
Thanks Meter: 64
CM2-MTK is what i need at all for MTK Platforms
i think just some secure platforms i use SPFT for it
Thanks alot BEST TEAM EVER
Old 12-23-2015, 01:04   #4 (permalink)
aliburhan1's Avatar
Member: 1520256
Sonork: 100.1612582
Thanks Meter: 137
Already Added in Menu Bar.
Note: A menu bar is a graphical control element which contains drop down menus. The menu bar's purpose is to supply a common housing for window- or application-specific menus which provide access to such functions as opening files, interacting with an application, or displaying help documentation or manuals.
The Following User Says Thank You to aliburhan1 For This Useful Post:
Old 12-23-2015, 01:24   #5 (permalink)
JHUNpanabO's Avatar
Member: 265729
Thanks Meter: 144
this one also i need to complete me this 2015..
by the way this tool really helps me a lot everyday..
thanks a lot infinity team,
Old 12-23-2015, 03:28   #6 (permalink)
Member: 1695792
Thanks Meter: 10
Cm2 is bast plz add spd6820 cpu
Old 12-23-2015, 03:33   #7 (permalink)
Member: 1778254
Sonork: sornork id
Thanks Meter: 36
nice update team
so petrified when replacement eMMC MTK chipset
I look forward to the next update
in option " read phone info " provide more detailed information , such as IMEI, SN, and firmware build number
beacause some phone wrong build number kill phone
Old 12-23-2015, 04:22   #8 (permalink)
Member: 1211191
Thanks Meter: 46
best team please add nand .bin flashing support
Old 12-23-2015, 04:30   #9 (permalink)
Member: 2473814
Sonork: 1669719
Thanks Meter: 6
thanks a lot infinity team, Abu Hasham
Old 12-23-2015, 04:47   #10 (permalink)
SOFTWARE.HELP's Avatar
Member: 1844204
Sonork: 100.1111172
Thanks Meter: 337
Good update CM2
Thanks Infinity Team
Old 12-23-2015, 05:44   #11 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Samsung G360H (Clone) HW Test (Test Report) :)
Operation : Check / Read Info [ v1.40 ]
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v5.1540.01.01
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164048607A27308A09D
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048607A27308A09D
[eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB
INT RAM    : 0x00020000
EXT RAM    : 0x20000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : alps
ProdName  : SM-G360H
ProdModel : SM-G360H
Device    : SM-G360H
AndroidVer: 4.2.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.JB3.MP.V1.2
Done!
Elapsed: 00:00:17
Reconnect Power/Cable!
Operation : HW Test [ v1.40 ]
Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Processing Miscellaneous test
MSC : BatteryLevel : 3841 mV
[Processing] FlashMemory Read-Write test
[eMMC] : [HYNIX] , d1G4 , 0xE7000000 , 3696 MiB
[eMMC] : CID : 90014A4834473164048607A27308A09D
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
[Processing] RAM Read-Write test
[DRAM] : 0x20000000 , 512 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x1C
[DRAM] : DATA BUS test
[PASSED] : Bus Count : 0x1F
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
Elapsed: 00:01:37
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 12-23-2015, 05:51   #12 (permalink)
p.k510's Avatar
Member: 1778370
Sonork: sujan_goa
Thanks Meter: 66
infinity team cm2 tool alwyas word best update but mtk nand not full support why pls full suppport nand my reqbest long team dear team
Old 12-23-2015, 05:53   #13 (permalink)
Member: 1211191
Thanks Meter: 46
cm 2 next update for Qualcomm
FOR QMobile Qualcomm Series
Qmobile W1
Qmobile Z9 (Upto Lollipop)
Qmobile Z8 Plus
Qmobile Z8
Qmobile Linq LT10
Qmobile Linq LT600
Qmobile Linq LT250
All Other Qmobile With Qualcomm Cpu,s (Beta)
The Following 2 Users Say Thank You to Tariqaziz1984 For This Useful Post:
Old 12-23-2015, 06:08   #14 (permalink)
ask4moon's Avatar
Member: 531289
Sonork: 100.1603200
Thanks Meter: 292
Teem look here
The Following 2 Users Say Thank You to ask4moon For This Useful Post:
Old 12-23-2015, 06:18   #15 (permalink)
Crazy Poster
Member: 1778259
Sonork: 100.1667.102
Thanks Meter: 13
Qmobile W1
Qmobile Z8 Plus
Qmobile Z8
Qmobile Linq LT10
Qmobile Linq LT600
Qmobile Linq LT250
infinity team we needed this plz add soon thanks
you are the best infinity team
The Following User Says Thank You to sk20000 For This Useful Post:
Page generated in 0.26474 seconds with 9 queries
