06-01-2016, 12:20 | #391 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2450124 Status: Offline Thanks Meter: 0 | i am a new user can i read or reset huawei mtk phones code using CM2 mtk Module...... because currently i am trying y220 and its not going through. it says device boot not done check drivers tryagain |
07-18-2016, 07:32 | #394 (permalink) |
Insane Poster Join Date: Feb 2016 Age: 29
Member: 2534066 Status: Offline Sonork: 100.1672178 Thanks Meter: 51 | STOP and EXIT Button is already added since start BR - YULDUZ GSM =D Last edited by Yulduz Gsm; 07-18-2016 at 07:38. |
The Following User Says Thank You to Yulduz Gsm For This Useful Post: |
11-09-2017, 11:48 | #399 (permalink) |
Junior Member Join Date: Dec 2014 Location: Cameroon
Member: 2312365 Status: Offline Thanks Meter: 0 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100514531334D420DBF5AFA5BB3F1 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:37 Reconnect Power/Cable! |
06-25-2018, 18:08 | #401 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | you are liar. proof - http://forum.gsmhosting.com/vbb/f296...l#post13193554 |
