02-16-2016, 17:24 | #62 (permalink) |
No Life Poster Join Date: May 2013 Location: Earth
Member: 1943439 Status: Offline Sonork: 100.1669578 Thanks Meter: 214 | TECNO H5 VIRUS REMOVE AND FULL FORMAT DONE BY NO.1 TOOL Chinese Miracle II [MTK module] v 1.41 Operation : Remove Viruses [SmartAV] [ v1.41 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Remove Viruses [SmartAV] [ v1.41 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 40 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447453001F211ABBBB127 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001F211ABBBB127 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 5E9C8F54A4B42B01A9721432CDD0182E INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 39 Removing infected files and scripts ... SmartAV Report : Removed 39 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #3 : PostFix Ok! Done! Done! Elapsed: 00:00:43 Reconnect Power/Cable! Operation : Format FileSystem [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 40 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447453001F211ABBBB127 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001F211ABBBB127 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 5E9C8F54A4B42B01A9721432CDD0182E INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
02-16-2016, 17:30 | #63 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: punjab Age: 43
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | Quote:
they are all boot blocked thanks again you are the best | |
02-16-2016, 17:42 | #64 (permalink) | |
Member: 1943439 Status: Offline Sonork: 100.1669578 Thanks Meter: 214 | Quote:
as for me i prefered smart-av | |
02-16-2016, 18:16 | #65 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Every 1's heart
Member: 682054 Status: Offline Sonork: 100.1602688 Thanks Meter: 144 | Bro plz check this Huawei its secure boot bro G730-U10....... Operation : Check / Read Info [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... [DA_ERROR] : SECURITY_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:20 Reconnect Power/Cable! |
02-16-2016, 18:23 | #66 (permalink) |
Freak Poster Join Date: Feb 2014 Location: P A K I S T A N
Member: 2130135 Status: Offline Sonork: XXXXXXXXX Thanks Meter: 50 | Cm2 Team plzzzzzz add wrong flashing preloder courpeted plzz add this option avnger box supported this option plz cm2 added this option |
02-16-2016, 19:10 | #68 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,535 | Quote:
Step #1: Step #2: - visit https://www.google.com/safebrowsing/report_error/ | |
The Following 3 Users Say Thank You to InfinityHelp For This Useful Post: |
02-16-2016, 19:19 | #69 (permalink) | |
Click HERE to check Support Expiration date. | |
02-16-2016, 19:45 | #70 (permalink) | |
What is your support expiration date ? Click HERE to check Support Expiration date. | |
02-16-2016, 19:45 | #71 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
We will try improve it much, as possible. | ||
02-16-2016, 19:47 | #72 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Heart of Asia
Member: 1706168 Status: Offline Sonork: 100.1619095 Thanks Meter: 66 | @JayDi How if you add search option in App Manager and add application name aside with package name ? because sometimes it is really hard to find a specific package name Thanks |
02-16-2016, 19:56 | #73 (permalink) | |
If that - scan will take from 3 to 20 times more time. Will be need check every app completely. I can make showing also list of "AutoStartup" apps with their names and etc and enable "hide" of system applications. But all this make manager hard to understand for some users. | |
02-16-2016, 20:26 | #74 (permalink) |
Member: 1706168 Status: Offline Sonork: 100.1619095 Thanks Meter: 66 | Chinese Miracle-2 MTK/Mediatek v1.41 - New way MTK Servicing - Unlock/Securit... Yes , exactly, if needs more time then it is not helpful And a search option in app manager , for example I search for a specific app/package name among other apps , I could be able to search and tick them Sent from my iPhone using Tapatalk |
