Old 04-19-2018, 06:59   #1 (permalink)
Member: 1043909
Thanks Meter: 60,926
Chinese Miracle-2 MTK/Mediatek v2.00 - new CPU support, new features, new options
MTK 6570 CPU support:
with NAND memory
with eMMC memory
Read Info - Complete device info, Security info
Read Firmware - Factory Scatter format [ NAND supported - WorldFirst and unique! ]
Write Firmware - Factory Scatter Format [ NAND supported - WorldFirst and unique! ]
Read NVRAM
Write NVRAM
Repair Security
Formay FS - FRP, Settings, Privacy ( and mixed/special mode )
MemoryTool
MTK 6750 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6755 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6757 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6763 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6797 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
--- Under Test ---
MTK 6758 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6739 CPU support:
with NAND memory
with eMMC memory
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
Main
- New look and design. All simplified and optimized much, as possible. [ please refer to v2 interface introduction ]
- New core. All code made from scratch.
- New boot chain selection mode - automatic ( via defined user combination ) or manual.
- New connection
- Complete error handling and explanation
- Internal EMIDB cover 99% of existing memory devices on both - NAND and eMMC devices
- Easy end user customization for adding support for new device etc.
Flasher
- Completely new flasher design, which allow customize whole flashing process [ please refer to v2 interface introduction ]
FW Reader
- Completely new core, which allow handle all existing types and flash devices.
Service
- Security repair NOT require reboot to meta, not required CDC drivers or whatever else. All direct.
- Format FS include different mode, optimized for different secure devices type ( with FORMAT, WRITE protection )
- During NVRAM read/write SW also verify it condition and data
MEMORY TOOL activated!
Easy, fast and ultimate solution now come in MTK too!
- Support eMMC and NAND flash IC secure
- Allow READ, WRITE, ERASE partitions
- Show partitions states and info only for eMMC devices
- Allow RE-init PMT ( from scatter )
Other
Lot of other changes from v1 line, which not mandatory to mention
Known issues/warnings/info:
1. [NAND on MT6570] v1712, v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors!
In result you will give read/write FW errors and rest problems at all.
Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write
2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format!
1. [NAND on MT6570] UBI SPARSE image flashing may take MUCH time (up to 5 minutes and more) for some devices!
3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed.
Read-write data, which you want, ignore "EMPTY" states.
4. [MEMORY TOOL] Old protocol secure devices (MT6750/MT6755) - LeEco and similar
In some cases WIPE partition may not work!
5. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND/eMMC devices! Result - stuck after system/userdata partition flashing
6. FileSyhstems flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list.
7. Device with NV_TYPE2 security may not work yet for repair sec!
Download link
Upload file to Support
Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News
Twitter - Facebook - Telegram
The Following 182 Users Say Thank You to YellowBoss For This Useful Post:
Old 04-19-2018, 07:01   #2 (permalink)
Member: 1043909
Important information:
- You DO NOT need to update Smart-Card to use this version. Smart-Card firmware v0136 is enough to use this version
- DO NOT uninstall previous version 1.58, in some cases you still need it
- Software installed to new folder /CM2MT2/ and designed to support new models
- If you are trying to connect phone with new software and see a message like LEGACY MTK - please use version 1.58 for this device !
- Some unpredictable bugs have been found with some PC and OS configurations, it may lead to "Access violation..." errors. Problem is known and fix is on the way.
previous software versions:
http://forum.gsmhosting.com/vbb/f296...tures-2142003/
http://forum.gsmhosting.com/vbb/f296...-58-a-2242009/
The Following 62 Users Say Thank You to YellowBoss For This Useful Post:
Old 04-19-2018, 07:04   #3 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
wow great update welcome
Old 04-19-2018, 07:09   #4 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 708
ohhh
welcome back mtk warrior.
The Following 2 Users Say Thank You to diesel6 For This Useful Post:
Old 04-19-2018, 07:14   #5 (permalink)
mubarak2344's Avatar
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 581
Team, Thanks for ur update...
will eager to check how its working....
Pls add MTK6771 cpu(oppo F7) in next update...
thank u
The Following 3 Users Say Thank You to mubarak2344 For This Useful Post:
Old 04-19-2018, 07:14   #6 (permalink)
Member: 2562097
Thanks Meter: 203
great news thank you infinity team
The Following User Says Thank You to umera5zal008 For This Useful Post:
Old 04-19-2018, 07:17   #7 (permalink)
mcclinic's Avatar
Member: 593876
Thanks Meter: 302
welcome and Congrats to Yellow Boss, JayDi, and Infinity Team
Great Update!! i Think MTK secure boot Game will over Now.
The Following 2 Users Say Thank You to mcclinic For This Useful Post:
Old 04-19-2018, 07:22   #8 (permalink)
Member: 2555426
Thanks Meter: 5
good update thank u team
Old 04-19-2018, 07:28   #9 (permalink)
rafi_5217705's Avatar
Member: 627475
Sonork: 100.1594828
Thanks Meter: 1,144
hi Boss
We Trust on your product please Don't leave alone The infinity user
The Following 8 Users Say Thank You to rafi_5217705 For This Useful Post:
Old 04-19-2018, 07:46   #10 (permalink)
Member: 2676621
Thanks Meter: 14
Thanks infnity is always king
The Following 2 Users Say Thank You to mani78600 For This Useful Post:
Old 04-19-2018, 07:50   #11 (permalink)
Member: 2286149
Thanks Meter: 34
Wow, many thanks for this update... keep rocking infinity team..
The Following User Says Thank You to Jamil69 For This Useful Post:
Old 04-19-2018, 07:51   #12 (permalink)
Member: 1087456
Thanks Meter: 39
Waiting for device connection ...
PTFN : MediaTek USB Port (COM62)
MODE : BOOTROM
PORT : 62
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000
TYPE : LEGACY MTK
Info : Device is not supported yet!
Reconnect Power/Cable!
The Following 2 Users Say Thank You to mijanur_017 For This Useful Post:
Old 04-19-2018, 07:53   #13 (permalink)
Member: 2245732
Sonork: i need help please
Thanks Meter: 9
HI team please why new version don't show sp unlock ?
Thanks for update
The Following User Says Thank You to fregis10 For This Useful Post:
Old 04-19-2018, 07:53   #14 (permalink)
Crazy Poster
Member: 2673715
Thanks Meter: 6
Best team of all times nyc update
The Following User Says Thank You to Ohara1984 For This Useful Post:
Old 04-19-2018, 08:00   #15 (permalink)
Member: 2245732
Thanks Meter: 9
Help
Thanks for update
Page generated in 0.27210 seconds with 9 queries
