Old 04-19-2018, 09:16   #31 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Smile
Originally Posted by anees ur rehman View Post
Operation : Identify [ v2.00 r1 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM11)
MODE : PRELOADER PORT
PORT : 11
Waiting BOOT ack ...
PRELOADER : ACK confirm FAIL!
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
Info : Device is not supported yet!
Reconnect Power/Cable!
Important information:
- You DO NOT need to update Smart-Card to use this version. Smart-Card firmware is enough to use this version
- DO NOT uninstall previous version 1.58, in some cases you still need it
- Software installed to new folder /CM2MT2/ and designed to support new models
- If you are trying to connect phone with new software and see a message like LEGACY MTK - please use version 1.58 for this device !
ShahiD
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Old 04-19-2018, 09:28   #32 (permalink)
ahmer5050's Avatar
Member: 2385819
Sonork: No More Used
Thanks Meter: 827
Originally Posted by rahihimkhan View Post
U R link is fully Empty like This
The Following User Says Thank You to ahmer5050 For This Useful Post:
Old 04-19-2018, 09:42   #33 (permalink)
Member: 1686673
Thanks Meter: 53
Originally Posted by YellowBoss View Post
Chinese Miracle-2 MTK/Mediatek v2.00 - new CPU support, new features, new options
MTK 6570 CPU support:
with NAND memory
with eMMC memory
Read Info - Complete device info, Security info
Read Firmware - Factory Scatter format [ NAND supported - WorldFirst and unique! ]
Write Firmware - Factory Scatter Format [ NAND supported - WorldFirst and unique! ]
Read NVRAM
Write NVRAM
Repair Security
Formay FS - FRP, Settings, Privacy ( and mixed/special mode )
MemoryTool
MTK 6750 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6755 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6757 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6763 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6797 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
--- Under Test ---
MTK 6758 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6739 CPU support:
with NAND memory
with eMMC memory
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
Main
- New look and design. All simplified and optimized much, as possible. [ please refer to v2 interface introduction ]
- New core. All code made from scratch.
- New boot chain selection mode - automatic ( via defined user combination ) or manual.
- New connection
- Complete error handling and explanation
- Internal EMIDB cover 99% of existing memory devices on both - NAND and eMMC devices
- Easy end user customization for adding support for new device etc.
Flasher
- Completely new flasher design, which allow customize whole flashing process [ please refer to v2 interface introduction ]
FW Reader
- Completely new core, which allow handle all existing types and flash devices.
Service
- Security repair NOT require reboot to meta, not required CDC drivers or whatever else. All direct.
- Format FS include different mode, optimized for different secure devices type ( with FORMAT, WRITE protection )
- During NVRAM read/write SW also verify it condition and data
MEMORY TOOL activated!
Easy, fast and ultimate solution now come in MTK too!
- Support eMMC and NAND flash IC secure
- Allow READ, WRITE, ERASE partitions
- Show partitions states and info only for eMMC devices
- Allow RE-init PMT ( from scatter )
Other
Lot of other changes from v1 line, which not mandatory to mention
Known issues/warnings/info:
1. [NAND on MT6570] v1712, v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors!
In result you will give read/write FW errors and rest problems at all.
Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write
2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format!
1. [NAND on MT6570] UBI SPARSE image flashing may take MUCH time (up to 5 minutes and more) for some devices!
3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed.
Read-write data, which you want, ignore "EMPTY" states.
4. [MEMORY TOOL] Old protocol secure devices (MT6750/MT6755) - LeEco and similar
In some cases WIPE partition may not work!
5. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND/eMMC devices! Result - stuck after system/userdata partition flashing
6. FileSyhstems flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list.
7. Device with NV_TYPE2 security may not work yet for repair sec!
Download link
Upload file to Support
Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News
Twitter - Facebook - Telegram
Thanks And Great Update but After Download EXE and Install Show This Error
Old 04-19-2018, 09:43   #34 (permalink)
Member: 1043909
Thanks Meter: 60,926
PORT : 11
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
please follow the instruction from post #2
Old 04-19-2018, 09:47   #35 (permalink)
Member: 1043909
quite strange situation. try to download again.
and also check your PC for viruses, it may be a reason
Old 04-19-2018, 09:48   #36 (permalink)
Member: 1043909
yes you are right, I see also nothing.
Old 04-19-2018, 09:59   #37 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Lenovo Ka10a40 not booting
PTFN : MediaTek DA USB VCOM (Android) (COM232)
PORT : 232
Error : Failed to open port!
Error : Fail to init protocol!
Remove battery, cable. Check cable and connection. Repeat operation!
Hello,
Reset device and try again,,means Remove battery and try again
Old 04-19-2018, 10:03   #38 (permalink)
Member: 1686673
Thanks Meter: 53
Sir ré Download EXE File in server Extract 7zip Software and progress Show Error your EXE Incropted
window xp Window 10 both Window Show This Error
Old 04-19-2018, 10:03   #39 (permalink)
rahihimkhan's Avatar
Member: 613449
Sonork: 100.1614074
Thanks Meter: 634
https://image.ibb.co/fkV7HS/Untitled.png
Old 04-19-2018, 10:13   #40 (permalink)
Member: 2603633
Sonork: family
Thanks Meter: 214
Welcome to back mtk........
Old 04-19-2018, 10:25   #41 (permalink)
Member: 1085044
Sonork: 100.1654128
Thanks Meter: 37
[IMG][/IMG]
ANY SOLUTION
Old 04-19-2018, 10:32   #42 (permalink)
ahmer5050's Avatar
Member: 2385819
Thanks Meter: 827
Originally Posted by skkumer View Post
[IMG][/IMG]
ANY SOLUTION
This is Old CPU .Try wit 1.58 Version Bro.
Old 04-19-2018, 10:47   #43 (permalink)
Member: 1043909
[IMG][/IMG]
ANY SOLUTION
please read instruction in current thread post #2
Old 04-19-2018, 10:48   #44 (permalink)
Member: 1043909
thanks for report we will check it
Old 04-19-2018, 11:16   #45 (permalink)
Member: 1677653
Thanks Meter: 2,769
My smart card firmware version is v0136 but MTK v2 not work for me...
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Page generated in 0.29934 seconds with 10 queries
