04-19-2018, 06:59 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 MTK/Mediatek v2.00 - new CPU support, new features, new options MTK 6570 CPU support: with NAND memory with eMMC memory Read Info - Complete device info, Security info Read Firmware - Factory Scatter format [ NAND supported - WorldFirst and unique! ] Write Firmware - Factory Scatter Format [ NAND supported - WorldFirst and unique! ] Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6750 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6755 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6757 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6763 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6797 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool --- Under Test --- MTK 6758 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6739 CPU support: with NAND memory with eMMC memory Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool Main - New look and design. All simplified and optimized much, as possible. [ please refer to v2 interface introduction ] - New core. All code made from scratch. - New boot chain selection mode - automatic ( via defined user combination ) or manual. - New connection - Complete error handling and explanation - Internal EMIDB cover 99% of existing memory devices on both - NAND and eMMC devices - Easy end user customization for adding support for new device etc. Flasher - Completely new flasher design, which allow customize whole flashing process [ please refer to v2 interface introduction ] FW Reader - Completely new core, which allow handle all existing types and flash devices. Service - Security repair NOT require reboot to meta, not required CDC drivers or whatever else. All direct. - Format FS include different mode, optimized for different secure devices type ( with FORMAT, WRITE protection ) - During NVRAM read/write SW also verify it condition and data MEMORY TOOL activated! Easy, fast and ultimate solution now come in MTK too! - Support eMMC and NAND flash IC secure - Allow READ, WRITE, ERASE partitions - Show partitions states and info only for eMMC devices - Allow RE-init PMT ( from scatter ) Other Lot of other changes from v1 line, which not mandatory to mention Known issues/warnings/info: 1. [NAND on MT6570] v1712, v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors! In result you will give read/write FW errors and rest problems at all. Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write 2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format! 1. [NAND on MT6570] UBI SPARSE image flashing may take MUCH time (up to 5 minutes and more) for some devices! 3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed. Read-write data, which you want, ignore "EMPTY" states. 4. [MEMORY TOOL] Old protocol secure devices (MT6750/MT6755) - LeEco and similar In some cases WIPE partition may not work! 5. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND/eMMC devices! Result - stuck after system/userdata partition flashing 6. FileSyhstems flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list. 7. Device with NV_TYPE2 security may not work yet for repair sec! Download link Upload file to Support Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News Twitter - Facebook - Telegram Last edited by YellowBoss; 04-19-2018 at 10:47. |
The Following 182 Users Say Thank You to YellowBoss For This Useful Post: |
04-19-2018, 07:01 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Important information: - You DO NOT need to update Smart-Card to use this version. Smart-Card firmware v0136 is enough to use this version - DO NOT uninstall previous version 1.58, in some cases you still need it - Software installed to new folder /CM2MT2/ and designed to support new models - If you are trying to connect phone with new software and see a message like LEGACY MTK - please use version 1.58 for this device ! - Some unpredictable bugs have been found with some PC and OS configurations, it may lead to "Access violation..." errors. Problem is known and fix is on the way. previous software versions: http://forum.gsmhosting.com/vbb/f296...tures-2142003/ http://forum.gsmhosting.com/vbb/f296...-58-a-2242009/ Last edited by YellowBoss; 04-22-2018 at 08:28. |
The Following 62 Users Say Thank You to YellowBoss For This Useful Post: |
04-19-2018, 07:14 | #5 (permalink) |
No Life Poster Join Date: Aug 2013 Location: CHENNAI, TAMILNADU,INDIA
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Team, Thanks for ur update... will eager to check how its working.... Pls add MTK6771 cpu(oppo F7) in next update... thank u |
The Following 3 Users Say Thank You to mubarak2344 For This Useful Post: |
04-19-2018, 07:17 | #7 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 593876 Status: Offline Thanks Meter: 302 | welcome and Congrats to Yellow Boss, JayDi, and Infinity Team Great Update!! i Think MTK secure boot Game will over Now. |
The Following 2 Users Say Thank You to mcclinic For This Useful Post: |
04-19-2018, 07:28 | #9 (permalink) |
No Life Poster Join Date: Nov 2007 Location: ☆I-LOVE Pakistan☆
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | hi Boss We Trust on your product please Don't leave alone The infinity user |
The Following 8 Users Say Thank You to rafi_5217705 For This Useful Post: |
04-19-2018, 07:51 | #12 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Bangladesh
Member: 1087456 Status: Offline Thanks Meter: 39 | Waiting for device connection ... PTFN : MediaTek USB Port (COM62) MODE : BOOTROM PORT : 62 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! |
The Following 2 Users Say Thank You to mijanur_017 For This Useful Post: |
04-19-2018, 07:53 | #13 (permalink) |
Freak Poster Join Date: Aug 2014 Location: Yaoundé Cameroon �ȸ
Member: 2245732 Status: Offline Sonork: i need help please Thanks Meter: 9 | HI team please why new version don't show sp unlock ? Thanks for update |
The Following User Says Thank You to fregis10 For This Useful Post: |
04-19-2018, 08:00 | #15 (permalink) |
Member: 2245732 Status: Offline Sonork: i need help please Thanks Meter: 9 | Help HI team please why new version don't show sp unlock ? Thanks for update |
