Old 04-30-2018, 09:33   #1 (permalink)
Member: 1043909
Thanks Meter: 51,293
Chinese Miracle-2 MTK/Mediatek v2.00 r2 - MT6739 support, SPUnlock and more
As we told earlier, it was found some kind of problems with v2.00 at some PC and some hardware configuration. Current release should help to fix it. More details please see here - Chinese Miracle-2 MTK/Mediatek v2.00 - new CPU support, new features, new options
More details about current release:
- Main
MT6739 CPU supported!
MT6739 moved from TEST to GENERAL support.
Firmwware read
Firmware write
NVRAM read
NVRAM write
Reset Settings / Format FS
Reset FRP
Reset Privacy
MemoryTool
- MemoryTool
Fixed PMT init on some devices
Optimized Expand/Collapse view functions
Fixed DA1804 and DA1712 loaders support for WIPE
Optimized NAND support
- Service
NVRAM module updated
.dynamic page detection
.some types support fixed
.repair security ( security type detection ) updated
FormatFS / Reset settings rebuild
.Activated fully automatic "FULL FACTORY" mode, designed for all modern devices ( include devices with SEC_CONTROL )
."FULL FACTORY" mode set to default
.Some "OLD" agents (DA15xx) may not work
- SP Unlock activated
Support all MTK modern phones, except MT6763 and MT6739.
Read codes and Direct Unlock mode supported
MT6570 eMMC ONLY devices supported
- Core
Fixed memory leak issues and problems with booting on some systems
Optimized different OLD agents support for MODERN devices ( DA16xx and DA17xx line )
SW more faster now
EMI handler for MT6570 and MT6797 fully automated and complete
Improved EMI lookup support for MT675x devices
EMIDB updated
Hint/Error explain module updated
MT6758 support under test
MT6771 support under test
- Flasher
Fixed break issue, when just one file selected for flashing.
HWInfo compatibility status shown in log in both cases ( succes or failed )
- FW reader
MT6739 support
New types of firmwares supported
Optimized NAND reading on DA18xx line loaders
Read Firmware size now shown in log
- New models included
Limited MEIZU support
Limited Oppo support
Limited Gionee support
Limited BQ support
Some basic "generic" secure devices support optimized
Known issues/warnings/info :
1. [NAND on MT6570] v1712,v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors!
In result you will give read/write FW errors and rest problems at all.
Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write
2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format!
3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed.
Read-Write data, which you want, ignore "EMPTY" states.
4. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND devices! Result - stuck after system/userdata partition flashing
5. FileSystem flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list.
6. Cheap MT6739 devices require BATTERY REMOVING after EVERY operation in most cases!
7. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list!
Download link
Upload file to Support
Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News
Twitter - Facebook - Telegram
The Following 65 Users Say Thank You to YellowBoss For This Useful Post:
Old 04-30-2018, 09:39   #2 (permalink)
Member: 50772
Sonork: 100.1590990
Thanks Meter: 304
moto x1721 i got this error
Operation : Identify [ v2.00 r2 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : PreLoader USB VCOM Port (COM1)
MODE : PRELOADER PORT
PORT : 1
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000
TYPE : LEGACY MTK
Info : Device is not supported yet!
Reconnect Power/Cable!
The Following 5 Users Say Thank You to aashir For This Useful Post:
Old 04-30-2018, 09:58   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,596
MT6739 test :
MT6739 : Support with CM2MT2 [ WorldFirst ]
The Following 17 Users Say Thank You to JayDi For This Useful Post:
Old 04-30-2018, 10:02   #4 (permalink)
JayDi's Avatar
Member: 462970
MT6750 : ALCATEL 4049X : SP Unlock :
Operation : SP Unlock [ v2.00 r2 ]
PTFN : MediaTek PreLoader USB VCOM (Android) (COM6)
PORT : 6
BROM : Init BROM
BROM init passed!
CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : PRELOADER PORT
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6570
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00020000 [ 128,00 KB ]
DRAM: 0x20000000 [ 512,00 MB ]
EMMC: 1101003030344736300260716CA482AC
EMMC: VEN : TOSHIBA | OEM : 01 | DEV : 004G60
EMMC:
BOOT1 : 0x00200000 [ 2,00 MB ]
BOOT2 : 0x00200000 [ 2,00 MB ]
RPMB : 0x00080000 [ 512,00 KB ]
USER : 0xEC000000 [ 3,69 GB ]
CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 7755CF722D0C39C75756F32F4D008357
DA : USB : HIGH-SPEED
Boot done!
ID0 : Lock : Locked! | MNC : 256 | CNT : 5 | CODE : 32538347
ID1 : Lock : Not Locked!
ID2 : Lock : Not Locked!
ID3 : Lock : Not Locked!
ID4 : Lock : Not Locked!
ID5 : Lock : Not Locked!
ID6 : Lock : Not Locked!
Direct unlock done!
Done!
Elapsed: 00:00:12
The Following 21 Users Say Thank You to JayDi For This Useful Post:
Old 04-30-2018, 10:27   #5 (permalink)
Member: 50772
Sonork: 100.1590990
Thanks Meter: 304
Jaydi how to solve motorola xt1721
The Following 2 Users Say Thank You to aashir For This Useful Post:
Old 04-30-2018, 10:44   #6 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,240
Smile MOTO/LENOVO K8 NOTE XT1902-3 MT6797 READ INFI & NVRAM READ Done
SUCCESSFULLY READ INFO & NVRAM(MOTO/LENOVO K8 NOTE XT1902-3 MT6797)USB
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r2
PTFN : MediaTek PreLoader USB VCOM (Android) (COM23)
PORT : 23
BROM : Init BROM
BROM init passed!
CHIP : MT6797 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000
BROM : SecLevel : 0x00000001
BROM : SecMode : SBC
AGENT : Found MT6797
BROM : DA sent
DA : AGENT started!
DA : SYNC
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 450100444634303634011D8CE3AC6425
EMMC: VEN : SANDISK | OEM : 01 | DEV : DF4064
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0xE8F800000 [ 58.24 GB ]
CHIP : MT6797 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 74E828A599803F7288E78567441A5FB
Boot done!
Patch Level : NMB26.54-94
Display ID : NMB26.54-94
Ver. CodeName : REL
Ver. Release : 7.1.1
Sec. Patch : 2017-12-05
Build Time : 1514214693
Product Model : Lenovo K8 Note
Product Brand : lenovo
Product Name : manning_retail
Product Device : manning
Product Manfct : lenovo
Board Platform : mt6797
Product Info : manning
Done!
Elapsed: 00:00:29
PORT : 23
BROM : Init BROM
BROM init passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
SEC Data :
IMEI[0] : 864XXXXXXXXXXX
IMEI[1] : 864XXXXXXXXXXX
NVRAM check : Passed!
NVM saved as : MT6797__eMMC__864XXXXXXXXXXX.mt_sec
NVM saved to : E:\MOTO BACKUP\
Done!
Elapsed: 00:00:26
THANKS INFINITY-BOX TEAM
The Following 10 Users Say Thank You to gracy_elec For This Useful Post:
Old 04-30-2018, 11:38   #7 (permalink)
JayDi's Avatar
Member: 462970
Start from reading info about LEGACY.
Old 04-30-2018, 12:05   #8 (permalink)
Kwesi_Roy_GH's Avatar
Member: 2575234
Thanks Meter: 1,105
The Following 4 Users Say Thank You to Kwesi_Roy_GH For This Useful Post:
Old 04-30-2018, 12:31   #9 (permalink)
JayDi's Avatar
Member: 462970
@Kwesi_Roy_GH, I had expect some caustiс/sarcastic comment.
Do not ruin my hopes
The Following 5 Users Say Thank You to JayDi For This Useful Post:
Old 04-30-2018, 13:35   #10 (permalink)
Member: 2575234
Thanks Meter: 1,105
Surely, I'm not gonna ruin your hopes on this one my friend JayDi.
I say it when it's good. I also say if it's bad.
You need to get on with me bro... I'm always a neutral person.
Good job done!
The Following 3 Users Say Thank You to Kwesi_Roy_GH For This Useful Post:
Old 04-30-2018, 14:45   #11 (permalink)
sindhi.aslam's Avatar
Member: 1919988
Thanks Meter: 177
Arrow unable to write nv
dear sir iam unable to write nv on oppo f5 cph1725
plz help
here is log
Operation : Write Security [ v2.00 r2 ]
PTFN : MTK USB Port (COM11)
MODE : BOOTROM
PORT : 11
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
AGENT : DA_PL_CRYPTO.bin
AGENT : Found MT6763
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : MT6763
EMI : SRC : preloader_oppo6763_17031.bin
EMI : CNT : 000F
EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ]
EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ]
EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ]
EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ]
EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ]
EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ]
EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ]
EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ]
EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ]
EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ]
EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : UNKNOWN | DEV : S0J9B7 : RAM : [ 3.00 GB ]
EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ]
EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ]
EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ]
EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ]
EMI : Init EMI from PRELOADER
EMI : EXT_RAM CFG Passed!
EMMC: 90014A484247346132A5288668C2B4D7
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2
EMMC:
USER : 0x747C00000 [ 29.12 GB ]
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 8765811B9011D8136C6E65EA658E8BD8
Boot done!
Restore NVRAM from : MT6763__eMMC__ (4).mt_sec
ERR : 0xC002002A
ERR : SEC_IMG_TYPE_MISMATCH
ERR : 0x04000000|0x04000000
Error : Flashing failed!
Seems as some of MANDATORY section of FW is damaged! If device alive and work - send report!
The Following 2 Users Say Thank You to sindhi.aslam For This Useful Post:
Old 04-30-2018, 14:55   #12 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 696
Lenovo A7020a48 frp reset done thanks team
Operation : Reset Settings/Format FS [ v2.00 r2 ]
PTFN : MediaTek PreLoader USB VCOM Port (COM9)
PORT : 9
BROM : Init BROM
BROM init passed!
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
AGENT : Found MT6755
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC: 90014A484247346132A41E43C8E5A3A3
EMMC:
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 3C275BED8C074945F1BBEE147495A384
Boot done!
Format Ok : RESET PROTECTION
Format Ok : PRIVACY
Done!
Elapsed: 00:00:13
The Following 6 Users Say Thank You to diesel6 For This Useful Post:
Old 04-30-2018, 15:03   #13 (permalink)
-Mosin-'s Avatar
Member: 1948608
Thanks Meter: 1,582
Good update JayDi.
hope LEGACY on V2 will be activated soon...
The Following 8 Users Say Thank You to -Mosin- For This Useful Post:
Old 04-30-2018, 15:26   #14 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by -Mosin- View Post
Good update JayDi.
Yes, after r3 release.
The Following 22 Users Say Thank You to JayDi For This Useful Post:
Old 04-30-2018, 15:26   #15 (permalink)
JayDi's Avatar
Member: 462970
@sindhi.aslam, it will be enabled in near release. Next, probably.
The Following 4 Users Say Thank You to JayDi For This Useful Post:
Page generated in 0.49592 seconds with 7 queries
