06-14-2014, 12:24 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Chinese Miracle-2 : MTK Module Need 5-7 users with activated "CM2" to check some thing for release. Requirements : 1. Few MTK625A and/or MTK6260 2. Activated CM2 module 3. At least - 2-3 post in RDA/SPD thread. Request is here, not in PM. |
The Following 7 Users Say Thank You to Dzirt For This Useful Post: |
06-14-2014, 12:59 | #8 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | I am also ready as a beta tester i have mtk6260 and mtk 625a (6250) in hand post count is also more then required |
The Following 3 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
06-14-2014, 12:59 | #9 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Ok, I think enough. In near few minutes in PM all will receive link to version and some info. BR. |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
06-14-2014, 13:19 | #12 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Micromax X281 , MTK6260 , 3Mb flash (FW) Operation : Read Flash [ v0.01 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : ACEDD9A6226C6647FA60E21DB2996828 BROM Protocol Version : 05 Setting... Setting done , result code 0x8000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Read Flash now Read Ok , 3145728 bytes read Check and collect compile info File_Info : BESTONE60M_OVERSEA_11B_PCB01_gsm_MT6260_S00.A9_60M_MMX_L242_ER_V1_0_9.bin FileVersion : A9_60M_MMX_L242_ER_V1.0.9 Saved to : C:\Infinity\MTKTST\Read_out\BESTONE60M_OVERSEA_11B_PCB01_gsm_MT6260_S00.A9_60M_MMX_L242_ER_V1_0_9.bin Done! Elapsed: 00:00:14 Reconnect Power/Cable! Code: Load File File_Info : BESTONE60M_OVERSEA_11B_PCB01_gsm_MT6260_S00.A9_60M_MMX_L242_ER_V1_0_9.bin FileVersion : A9_60M_MMX_L242_ER_V1.0.9 Load File Ok Operation : Flash [ v0.01 ] Code: ======= Flash Files set for flashing : [ MCU ] : BESTONE60M_OVERSEA_11B_PCB01_gsm_MT6260_S00.A9_60M_MMX_L242_ER_V1_0_9.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : ACEDD9A6226C6647FA60E21DB2996828 BROM Protocol Version : 05 Setting... Setting done , result code 0x8000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Erase region , wait ... Write data , wait ... Write : BESTONE60M_OVERSEA_11B_PCB01_gsm_MT6260_S00.A9_60M_MMX_L242_ER_V1_0_9.bin Done! Elapsed: 00:00:33 Reconnect Power/Cable! Operation : Check / Read Info [ v0.01 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : ACEDD9A6226C6647FA60E21DB2996828 BROM Protocol Version : 05 Setting... Setting done , result code 0x8000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Done! Elapsed: 00:00:05 Reconnect Power/Cable! Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : ACEDD9A6226C6647FA60E21DB2996828 BROM Protocol Version : 05 Setting... Setting done , result code 0x8000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x002A5000-0x002FDFFF , LEN : 0x00059000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Repair Security [ v0.01 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : ACEDD9A6226C6647FA60E21DB2996828 BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6260 SW : A9_60M_MMX_L242_ER_V1.0.9 HW : BESTONE60M_OVERSEA_11B_HW IMEI[1] : 135790246811220 IMEI[2] : 135790246811220 Update IMEI[1] to : 356763524364778 Update IMEI[2] to : 356763524364786 Done! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
06-14-2014, 13:23 | #15 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Unknown China Samsung I9003 copy , MTK625A , 16 MB FlashIc Operation : Read Flash [ v0.01 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : C7C26007942FA631EC5BD689BA4FF7F1 BROM Protocol Version : 05 Setting... Setting done , result code 0x8000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : GM50_6464_11B_PCB01_gprs_MT6250_S00.R5001C_TY9300_V01.bin FileVersion : R5001C_TY9300_V01 Saved to : C:\Infinity\MTKTST\Read_out\GM50_6464_11B_PCB01_gprs_MT6250_S00.R5001C_TY9300_V01.bin Done! Elapsed: 00:01:05 Reconnect Power/Cable! Code: Load File File_Info : GM50_6464_11B_PCB01_gprs_MT6250_S00.R5001C_TY9300_V01.bin FileVersion : R5001C_TY9300_V01 Load File Ok Code: ======= Flash Files set for flashing : [ MCU ] : GM50_6464_11B_PCB01_gprs_MT6250_S00.R5001C_TY9300_V01.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : C7C26007942FA631EC5BD689BA4FF7F1 BROM Protocol Version : 05 Setting... Setting done , result code 0x8000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Erase region , wait ... Write data , wait ... Write : GM50_6464_11B_PCB01_gprs_MT6250_S00.R5001C_TY9300_V01.bin Done! Elapsed: 00:03:01 Reconnect Power/Cable! Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : C7C26007942FA631EC5BD689BA4FF7F1 BROM Protocol Version : 05 Setting... Setting done , result code 0x8000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00E80000-0x00FFFFFF , LEN : 0x00180000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:13 Reconnect Power/Cable! Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : C7C26007942FA631EC5BD689BA4FF7F1 BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6250 SW : R5001C_TY9300_V01 HW : GM50_12864_11B_HW IMEI[1] : 352012080850018 IMEI[2] : 352012080850018 Update IMEI[1] to : 356763524364778 Update IMEI[2] to : 356763524364786 Done! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
