09-12-2015, 15:19 | #17 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | dear sir i have infinity box can i use this version on my infinity box... here is my infinity box log: and what it means (inf v.0118) Firmware version: 0118.02 "UK edition" status: Off Last launched Application: 0026 v.0205 Active modules: - 00: inf v.0118 - 0A: Test Version |
09-12-2015, 15:22 | #18 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: Poland
Member: 2085623 Status: Offline Thanks Meter: 221 | Quote:
First need buy 1 year suppport for update after can use without problem. | |
The Following User Says Thank You to m1serwis For This Useful Post: |
09-12-2015, 15:32 | #21 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
09-12-2015, 15:33 | #22 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Select SP:Select Model [6571..6595] under CPU/WorkMode in Settings tab. After that select model in next below tab. After you will see SP unlock enabled. Br. | |
09-12-2015, 15:35 | #23 (permalink) | |
http://forum.gsmhosting.com/vbb/11283777-post21.html Need store that link for future questions | |
09-12-2015, 15:56 | #24 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | i think MT6753 format file system not supported till now. Chinese Miracle-2 MTK v1.30 - MT6753 support: Flash/Repair/Unlock/FactoryFW/Service/Forensic as you mentioned above........ am i right? |
09-12-2015, 15:59 | #25 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: CLOUD Age: 40
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | Quote:
ooops Sorry here is upload NVM file | |
09-12-2015, 15:59 | #26 (permalink) |
No Life Poster Join Date: Oct 2012
Member: 1824929 Status: Offline Thanks Meter: 99 | i have infinity main box activated Also best dongle conected with pc but when i open cm2 it says activte your software any method to run cm2 with out removing best dongle from pc |
09-12-2015, 16:07 | #27 (permalink) | |
If you want to run both softwares first connect one box/dongle and open it's module, after connect second Dongle/Box to pc and open it's module. Or keep one module running with minimized. Br. | |
09-12-2015, 16:08 | #28 (permalink) | |
Ok, finally. Will check it and let you know result in your thread about this sample, or in PM. Yes. Connect BEST dongle , run BEST first, then connect Infinity and run CM2. | |
09-12-2015, 16:38 | #29 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2406517 Status: Offline Sonork: 100.1641481 Thanks Meter: 38 | Q mobile x70 read done Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473264040501A29778222D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501A29778222D [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! BR GSM BOSS |
09-12-2015, 16:47 | #30 (permalink) | |
Member: 1824929 Status: Offline Thanks Meter: 99 | Quote:
can best dongle add in my infinty | |
