Old 09-20-2015, 16:09   #1 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Chinese Miracle-2 RDA/Coolsand v1.03 - RDA Android Repair and more
Infinity Chinese Miracle-2 RDA/Coolsand v1.03 - RDA Android Repair and more
RDA SP Platform
- RDA8811 eMMC supported
- Connection improved
RDA881x Flashing improved:
- Factory Firmware Flashing: RDAtotal Format type supported for eMMC phones
- RDATotal files and RDAFileSet handling revised
- RDA881x Service:
Safe "Format FS" (Reset Settings) revised
Factory Area Rebuild improved:
- Random MAC/BT generation
- Rebuild clean/erased FactoryArea improved
Calibration (IFC) Read/Write/Verify now supported:
- Allow fix Network problem (software related)
- Allow fix Unknown BaseBand problems
- Allow fix different "calibration errors"
RDA FP platform
- COM support improved
- RDA885x: 1/2 MiB flash ic support improved
- FactoryReset/FormatFS revised
- CompileInfo extraction revised
Other
- Some bugfixes and improvements
Official download link
Infinity-Box 10 (ten) years (2005 - 2015) non-stop regular updates and support as nobody else - Infinity-Box - News
Unlock Codes (Huawei, SE, Motorola, Samsung etc.), iPhone Unlock, Software Activations - Infinity-Box Online Service
1. Infinity-Box Dongle ready for delivery
2. BB5 Easy Service Tool [BEST] Dongle
3. CDMA-Tool Dongle (fast and easy unlock)
Twitter Facebook
The Following 24 Users Say Thank You to InfinitySupport For This Useful Post:
Old 09-20-2015, 16:51   #2 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,233
Kindly Add Manual Port Section Also For Flash SP ..
The Following 3 Users Say Thank You to hitech care For This Useful Post:
Old 09-20-2015, 18:13   #3 (permalink)
Member: 314561
Sonork: 100.1660866
Thanks Meter: 16
please make update allwinner platform
The Following User Says Thank You to OKey Cellular For This Useful Post:
Old 09-20-2015, 18:49   #4 (permalink)
Member: 1076060
Thanks Meter: 25
SPD SC7701B and SPD SC8801G2 ARE ALWAYS NOT SUPORT ,but there phone are from China and made in China !
why you say there no exist to your region ?
you can see here the picture of cpu :
https://lh3.googleusercontent.com/LA...jbMdV2v5vQ=s85
The Following 2 Users Say Thank You to genylle For This Useful Post:
Old 09-20-2015, 21:35   #5 (permalink)
obioha's Avatar
Member: 121356
Thanks Meter: 73
Please I don't know if itel phones are in your region,but uptill now I have been able to use chinese miracle spd to do any itel phone.but other tools do it good and fast.please make reserch on itel phones and support its cpu.tanks
Old 09-21-2015, 01:01   #6 (permalink)
Member: 1043909
Thanks Meter: 51,499
I am very sad to say but you should think before write to avoid such kind of stupid posts.
Here is a thread about RDA/Coolsand CPU.
How is it possible for you to give an advices to PROGRAMMERS if you are even unable to read thread name and make a post in correct forum thread ?
The Following 3 Users Say Thank You to YellowBoss For This Useful Post:
Old 09-21-2015, 01:02   #7 (permalink)
Member: 1043909
Old 09-21-2015, 01:04   #8 (permalink)
Member: 1043909
Please read current thread name once again.
Old 09-21-2015, 03:26   #9 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,662
Leave that pictures for yourself. If you want just crying in update threads - better leave that section at all. Next your crying will be last. Instead of stupid timewaste by making such posts - better check section and, maybe, you will find something.
I have no idea, what EXTRA inside itel phones, but fast look over section shows - they are same - MTK/SPD and perfectly works.
If it is hard for you to connect them - maybe, better leave that at all.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 09-21-2015, 06:18   #10 (permalink)
Member: 2072265
Thanks Meter: 37
fast update thanks CM2 team
Old 09-21-2015, 08:16   #11 (permalink)
sainathgsm's Avatar
Member: 2038392
Sonork: 100.1654462
Thanks Meter: 187
Please ADD Mtk 6572 nand emmc full support
Old 09-21-2015, 08:42   #12 (permalink)
JayDi's Avatar
Member: 462970
Seems as you was in come last year. Wake up!
Old 09-21-2015, 09:58   #13 (permalink)
Member: 1043909
Here is RDA/Coolsand discussiion but not MTK.
Old 09-27-2015, 08:47   #14 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 550
INTEX R3 RDA CPU Pattern Lock Remove Done With Infinity RDA/Coolsand v1.03
Operation : Format File System
Settings : SmartFormat is On
Waiting phone ...
Connect battery, press and hold 'VolUP' + 'PowerOn' buttons
Connect USB cable and keep hold buttons, until phone will be detected
Device found!
Handshake Ok!
Processing UBOT init ...
UBOOT FCS Init Ok!
Processing FL init ...
Handshake with FL Ok!
Factory Defaults : Will reset UserData and Settings!
Format USERDATA partition ...
Format USER Ok
Reboot Phone
Elapsed: 00:00:55
Reconnect Power/Cable!
Old 10-09-2015, 21:47   #15 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,650
Karbonn A109 Flash Done By CM2.
Chinese Miracle II [RDA module] v 1.03
Load file...
RDATotal : UTLA109v1011_rda_total.bin
Load Ok
Operation : Flash
======= Settings
Settings : Factory Settings Enabled
======= Flash
Files set for flashing :
RDATotal File : UTLA109v1011_rda_total.bin
Load Ok : PDL1
Load Ok : PDL2
Load Ok : bootloader
Load Ok : boot
Load Ok : system
Load Ok : modem
Load Ok : customer
Load Ok : recovery
Waiting phone ...
Device found!
Handshake Ok!
[PDL] : Setting FlashMode ...
[PDLBoot] : Sending First PDL ...
[PDLBoot] : First Boot Ok!
[PDLBoot] : Sending Second PDL ...
[PDLBoot] : Second Boot Ok!
Boot Finished!
Factory Defaults Enabled, will reset UserData and Settings!
Format UDA partition ...
Format USER Ok
[PDLFlash] : Sending All Images
[PDLFlash] : Processing now BOOTLOADER
Flashing ...
[PDLFlash] : Flash region done!
Flashing ...
[PDLFlash] : Processing now SYSTEM
Flashing ...
[PDLFlash] : Processing now MODEM
Flashing ...
[PDLFlash] : Processing now CUSTOMER
Flashing ...
[PDLFlash] : Processing now RECOVERY
Flashing ...
Flashing Done!
Reboot Phone
Elapsed: 00:02:21
Page generated in 0.45366 seconds with 7 queries
