12-24-2015, 16:37 | #16 (permalink) | |
Member: 1043909 Status: Online Thanks Meter: 60,926 | Quote:
Please next time post in right thread. Thank you ! -- DC-Unlocker 1 year and 2 years updates/support price reduced - Infinity-Box - Price | |
01-05-2016, 15:53 | #17 (permalink) |
Member: 541591 Status: Online Sonork: 100.1611509 Thanks Meter: 7,361 | Spice MI-348E hang at logo repaired by Format- Code: Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! Processing UBOT init ... UBOOT FCS Init Ok! Processing FL init ... Handshake with FL Ok! Factory Defaults : Will reset UserData and Settings! Format USERDATA partition ... Format USER Ok Reboot Phone Elapsed: 00:00:12 Reconnect Power/Cable! Infinity Box Support Team. |
01-24-2016, 14:12 | #18 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | spice mi 403e unable to formate formate Code: Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! Processing UBOT init ... Processing FL init ... Handshake with FL failed :( Factory Defaults : Will reset UserData and Settings! Format USERDATA partition ... Format USER Failed! Reboot Phone Elapsed: 00:00:39 |
01-24-2016, 16:35 | #19 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
01-28-2016, 13:23 | #20 (permalink) |
Member: 541591 Status: Online Sonork: 100.1611509 Thanks Meter: 7,361 | C381 read user code and backup firmware done- Read user code- Code: Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851B ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : VDS0 Item : NVRAM Required data found, extracting code UserCode : 8000 Elapsed: 00:00:21 Done Reconnect Power/Cable! Code: Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851B ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT8851A Target Flash : flsh_spi32m Project Name : C381_BH_T55_RDA8851A_U06_T4_ST3216_PCB30_QVGA_S_ENG_HIN_TEL_TAM_GAMELY_V03 Project Info : BH_C381_T55_RDA8851A_3216_QVGA Compile Date : 20130628Fri1534 [BIN] Saved as : C381_BH_T55_RDA8851A_U06_T4_ST3216_PCB30_QVGA_S_ENG_HIN_TEL_TAM_GAMELY_V03_BH_C381_T55_RDA8851A_3216_QVGA_CT8851A_flsh_spi32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\C381_BH_T55_RDA8851A_U06_T4_ST3216_PCB30_QVGA_S_ENG_HIN_TEL_TAM_GAMELY_V03_BH_C381_T55_RDA8851A_3216_QVGA_CT8851A_flsh_spi32m.iff [CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\C381_BH_T55_RDA8851A_U06_T4_ST3216_PCB30_QVGA_S_ENG_HIN_TEL_TAM_GAMELY_V03_BH_C381_T55_RDA8851A_3216_QVGA_CT8851A_flsh_spi32m.ifc Build done Done Elapsed: 00:04:50 Finish at : [1/24/2016 / 6:16:29 PM] Reconnect Power/Cable! |
04-30-2016, 18:13 | #26 (permalink) |
Member: 1043909 Status: Online Thanks Meter: 60,926 | New version released - http://forum.gsmhosting.com/vbb/f296...eased-2084381/ |
