04-25-2017, 16:36 | #61 (permalink) |
Freak Poster Join Date: Jul 2004 Location: nigeria Age: 41
Member: 73254 Status: Offline Sonork: 100.1583566 Thanks Meter: 13 | telma RDA/COOLSAND 8851a, 8851cl network unlock, invalid sim or sim close i have 2000 pieces as well, please is urgent TELMA V034+ TELMA V034+DUO TELMA X034+ TELMA X034+DUO please find me solution.... is a small phone Feature phone |
04-25-2017, 17:01 | #62 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
04-28-2017, 10:06 | #63 (permalink) |
Member: 73254 Status: Offline Sonork: 100.1583566 Thanks Meter: 13 | [QUOTE=JayDi;12467078]Again : Read dumps from every model ( 1-2 dump for model line ) which need to be unlocked.[/QU https://www.4shared.com/rar/fDEoqksF..._Read_out.html |
04-29-2017, 13:46 | #64 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: saqez - iran
Member: 1474571 Status: Offline Sonork: 100.1614377 Thanks Meter: 72 | Quote:
05-01-2017, 14:02 | #66 (permalink) | |
Member: 73254 Status: Offline Sonork: 100.1583566 Thanks Meter: 13 | Quote:
https://www.4shared.com/rar/fDEoqksF..._Read_out.html please help me with the solution | |
05-16-2017, 07:45 | #69 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Celkon C109 not supported Code: Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : CCCCCCCC Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 0809 , 00000000 Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! Reconnect Power/Cable! |
06-09-2017, 14:58 | #70 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Ghana Akatsi Age: 40
Member: 853308 Status: Offline Thanks Meter: 61 | Siccoo s5614 cpu not supported Chinese Miracle II [RDA module] v 1.05 Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : CCCCCCCC Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 0809 , 00000000 Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! Reconnect Power/Cable! |
06-19-2017, 09:55 | #72 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2043843 Status: Offline Thanks Meter: 39 | spice Xlife 350 Flashing faild Code: Card found: S/N : 9185DB79 , v0135 Chinese Miracle II [RDA module] v 1.05 Load file... RDATotal : Xlife-350_IND_Ver1.6_20160607_rda_total.bin Load Ok Operation : Flash ======= Settings Settings : Factory Settings Enabled ======= Flash Files set for flashing : RDATotal File : Xlife-350_IND_Ver1.6_20160607_rda_total.bin Load Ok : PDL1 Load Ok : PDL2 Load Ok : bootloader Load Ok : boot Load Ok : system Load Ok : modem Load Ok : vendor Load Ok : recovery Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Phone not found :( Operation : Flash ======= Settings Settings : Factory Settings Enabled ======= Flash Files set for flashing : RDATotal File : Xlife-350_IND_Ver1.6_20160607_rda_total.bin Load Ok : PDL1 Load Ok : PDL2 Load Ok : bootloader Load Ok : boot Load Ok : system Load Ok : modem Load Ok : vendor Load Ok : recovery Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! [PDL] : Setting FlashMode ... [PDLBoot] : Sending First PDL ... [PDLBoot] : First Boot Ok! [PDLBoot] : Sending Second PDL ... [PDLBoot] : Second Boot Ok! Boot Finished! Handshake with FL Ok! Factory Defaults Enabled, will reset UserData and Settings! Format UDA partition ... Format USER Ok [PDLFlash] : Sending All Images [PDLFlash] : Processing now BOOTLOADER File : Xlife-350_IND_Ver1.6_20160607_rda_total.bin Flashing ... [PDLFlash] : Flash region done! [PDLFlash] : Processing now BOOT File : Xlife-350_IND_Ver1.6_20160607_rda_total.bin Flashing ... [PDLFlash] : ERROR! PartitionFinalize rejected! Check FlashFile and connection! Flashing Done! Reboot Phone Elapsed: 00:00:36 Reconnect Power/Cable! |
06-21-2017, 06:08 | #73 (permalink) | |
Member: 2043843 Status: Offline Thanks Meter: 39 | what kind of support is this ? no one reply for this Quote:
06-24-2017, 09:46 | #75 (permalink) | |
CM2 is just ordinary software update for Main Infinity-Box and Infinity-Dongle. If you want to use CM2 software you must buy Infinity-Dongle or renew support for Main Infinity-Box | |
