10-17-2014, 23:45 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 (Release) MTK/MediaTek v1.04 released MediaTek SP Platform: .PatternLock Reading improved .MT6582 support improved .MT6571 eMMC support improved .FlashInit improved .FlashID database updated .Flash Read/Write speed improved - Official download link: server1 download area - Test report: hhttp://forum.gsmhosting.com/vbb/f29...debug-1868908/ Test reports: - Please post test reports (operation log text) in current thread or here http://forum.gsmhosting.com/vbb/f296...iatek-1862422/ Infinity-Box 9 (nine) years (2005 - 2014) non-stop regular updates and support, as nobody else: Infinity-Box - News New features, Unlock Codes (Huawei, Motorola, Samsung etc.), iPhone Unlock, Software Activations released for Infinity-Box Online Service - World biggest flash files database for several thousands brands/models - BB5 Easy Service Tool [BEST] Dongle - CDMA-Tool Dongle (fast and easy unlock) - Extract phonebook (and other content) from alive and dead phone - Follow us on Twitter |
The Following 18 Users Say Thank You to YellowBoss For This Useful Post: |
10-18-2014, 08:33 | #8 (permalink) | |
Two options available: 1. FREE: Chinese Miracle-2 v 0.XX + old software - http://forum.gsmhosting.com/vbb/f296...ocess-1867818/ 2. Not free: Chinese Miracle-2 v 1.XX + New Updates/Support - http://forum.gsmhosting.com/vbb/f296...012-a-1391471/ - http://forum.gsmhosting.com/vbb/f296...ocess-1865047/ Please check both and select what you need. | |
10-18-2014, 10:56 | #9 (permalink) |
Freak Poster Join Date: Jul 2014 Location: TOGO Age: 29
Member: 2218453 Status: Offline Sonork: JHJHJHJHJK Thanks Meter: 64 | hi original lg A390 need help to remove user code Chinese Miracle II [MTK module] v 1.04 Operation : Check / Read Info [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6255 BB_CPU_HW : CA03 BB_CPU_SW : 0002 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MTxxx BB_CPU_SN : 6C3A9BAAD60567C5417346F8E42A4917 BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
The Following User Says Thank You to BERCO For This Useful Post: |
10-18-2014, 12:42 | #10 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Model- IBall Andi4-B2 Operation : Read PatternLock [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3957524D4201896B7632B0F7 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D4201896B7632B0F7 [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 699 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 4521 Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
10-18-2014, 14:12 | #11 (permalink) |
No Life Poster Join Date: Jan 2006 Location: ES-Brazil
Member: 217679 Status: Offline Thanks Meter: 95 | I have two handsets SM-MT6571 Samsung G900 none of them work fullflash for reading or writing, the program is caught in the picture as shown below and not completes the procedure. Is expected to correct this failure? This much of this model appearing here in my assistance. |
10-18-2014, 16:18 | #12 (permalink) | ||
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Thanks for phone model hint Will try find one. Quote:
The Following User Says Thank You to Dzirt For This Useful Post: |
10-19-2014, 05:20 | #13 (permalink) |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | micromax A065 Identify Chinese Miracle II [MTK module] v 1.04 Operation : Check / Read Info [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 99 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D433034475848E89B4E918F DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D433034475848E89B4E918F [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:10 Reconnect Power/Cable! ************************************** Operation : Read Flash [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 99 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D433034475848E89B4E918F DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D433034475848E89B4E918F [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : Micromax ProdName : A065 ProdModel : Micromax A065 Device : A065 AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : MMX_A065_SW_V1.0_HW_V1.0_270614 Saved to : D:\InfinityBox\CM2MTK\Flash\MT6571__MICROMAX__Micr omax_A065__MMX_A065_SW_V1.0_HW_V1.0_270614__Androi d_4.4.2__20140629_075130.ispff Done! Elapsed: 00:18:04 Reconnect Power/Cable! |
The Following User Says Thank You to avtarkaint For This Useful Post: |
10-19-2014, 15:13 | #14 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | @Dzirt will be good if you add a STOP button |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
