01-17-2015, 15:49 | #46 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Quote:
Not supported 4 Nand flash type | |
01-17-2015, 15:58 | #47 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Alcatel One Touch 4010D read firmware done- Code: Chinese Miracle II [MTK module] v 1.09 Operation : Check / Read Info [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0074 , [HYNIX] H9DA4VH2GJAMCR_4EM [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:04 Reconnect Power/Cable! Operation : Read Flash [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0074 , [HYNIX] H9DA4VH2GJAMCR_4EM [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... NAND settings not exists, will check now ... Settings read Ok! - > Re-connect battery and start operation again! Done! Elapsed: 00:00:37 Reconnect Power/Cable! Operation : Read Flash [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0074 , [HYNIX] H9DA4VH2GJAMCR_4EM [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : TCT ProdName : Beetle_Lite ProdModel : ALCATEL ONE TOUCH 4010D Device : Beetle_Lite_GSM AndroidVer: 2.3.6 MTKxCPU : MT6575 MTKxPRJ : ALPS.GB2.MP.V2.24 Saved to : C:\InfinityBox\CM2MTK\Flash\MT6575__TCT__ALCATEL_ONE_TOUCH_4010D__Beetle_Lite__Beetle_Lite_GSM__ALPS.GB2.MP.V2.24__Android_2.3.6__20130510_090536.ispff Done! Elapsed: 00:06:08 Reconnect Power/Cable! |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
01-19-2015, 13:26 | #48 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Comilla
Member: 465069 Status: Offline Sonork: 100.1661026 Thanks Meter: 190 | Chinese Miracle II [MTK module] v 1.09 Operation : Check / Read Info [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35575A4D42012AC5CC21C075 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42012AC5CC21C075 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Read Flash [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35575A4D42012AC5CC21C075 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42012AC5CC21C075 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : G02 ProdName : G02 ProdModel : G02 Device : G02 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.2 [Read Ok] : preloader_m1.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / m1 / EMMC FW Size : 678 MiB Scatter saved to : E:\InfinityBox\CM2MTK\Flash\MT6572__G02__G02__G02_ _4.2.2__ALPS.JB3.MP.V1.2\ All done! Done! Elapsed: 00:03:38 Reconnect Power/Cable! Operation : Read PatternLock [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35575A4D42012AC5CC21C075 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42012AC5CC21C075 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 1323 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 42589 Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
01-20-2015, 11:10 | #50 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
"Invalid Imei" as and "Unknown BaseBand" can be fixed by flashing original rom in most times. NVRAM Read/Write in near plans. | |
The Following User Says Thank You to Dzirt For This Useful Post: |
01-20-2015, 12:09 | #51 (permalink) |
No Life Poster Join Date: Jan 2013 Location: (Tech land)
Member: 1864000 Status: Offline Thanks Meter: 2,893 | Qmobile A500 Noir format done easy Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4E0001154D5A57352A7501424180895C DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D4201752A5C898041 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
The Following User Says Thank You to ..:\\lucky//:.. For This Useful Post: |
01-20-2015, 12:10 | #52 (permalink) |
Member: 1864000 Status: Offline Thanks Meter: 2,893 | A500 noir Qmobile read emmc dump Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4E0001154D5A57352A7501424180895C DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D4201752A5C898041 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : QMobile ProdName : QMobile ProdModel : A500 Device : QMobile AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.2 Saved to : C:\Users\Amin\Desktop\New Folder\MT6589__QMOBILE__A500__ALPS.JB2.MP.V1.2__An droid_4.2.1__20130724_165220.ispff Done! Elapsed: 00:15:26 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to ..:\\lucky//:.. For This Useful Post: |
01-20-2015, 13:25 | #53 (permalink) |
Freak Poster Join Date: Nov 2012 Location: batna.algeria
Member: 1834802 Status: Offline Sonork: 100.1659078 Thanks Meter: 89 | porblem in this version wiko lenny read info and Read Factory Firmware done Chinese Miracle II [MTK module] v 1.09 Operation : Check / Read Info [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 37 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A15A129161 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A15A129161 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Read Flash [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 37 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A15A129161 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A15A129161 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : WIKO ProdName : s5201ap ProdModel : LENNY Device : s5201ap AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 [Read Ok] : preloader_s5201ap.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / s5201ap / EMMC FW Size : 801 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__WIKO__LENNY__s 5201ap__4.4.2__ALPS.KK1.MP7.V1\ All done! Done! Elapsed: 00:03:38 Reconnect Power/Cable! but wen i want to test scater file in sp flash_tool i safe error and phone dead i want to reflash full falsh i have this error [img]http://im65.******.com/ch2t8z.jpg[/img] i reanstal version v1.08 and reflash the phone error but phone alive Operation : Flash [ v1.08 ] ======= Flash Files set for flashing : [ MCU ] : MT6572__WIKO__LENNY__ALPS.KK1.MP7.V1__Android_4.4. 2__20141014_030450.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 37 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A15A129161 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A15A129161 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : WIKO ProdName : s5201ap ProdModel : LENNY Device : s5201ap AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 ISPFF ID : 6572 TARGET ID : 6572 Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : MT6572__WIKO__LENNY__ALPS.KK1.MP7.V1__Android_4.4. 2__20141014_030450.ispff Init Ok , Sending blocks ... Write failed Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:07:01 Reconnect Power/Cable! |
01-20-2015, 14:43 | #54 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. What error FT gives? I need more info. About writing - on some PC's that can happen on 95% or so. Not change result in fact, all data will be write anyway. |
01-20-2015, 15:55 | #55 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | Intex__Style VX Operation : Read Flash [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:39 Reconnect Power/Cable! Operation : Read Flash [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201A942CCA4A11D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201A942CCA4A11D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Intex ProdName : Intex ProdModel : Style VX Device : StyleVX AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_v9_e324_3gb15_qhd_cq415 [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6582 / V1.1.1 / v9_e324_3gb15_qhd_c / EMMC FW Size : 808 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6582__Intex__Style VX__StyleVX__4.4.2__ALPS.KK1.MP1.V2.10\ |
The Following 2 Users Say Thank You to sunny_luthras99 For This Useful Post: |
01-20-2015, 15:56 | #56 (permalink) |
Member: 1066865 Status: Offline Thanks Meter: 593 | note 3 GT-n9000 Operation : Read Flash [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7901004D4D43303447450768B9007111 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0079 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7901004D4D43303447450768B9007111 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : alps ProdName : GT-N9000 ProdModel : GT-N9000 Device : GT-N9000 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.2 [Read Ok] : preloader_lightning89_wet_jb3.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / lightning89_wet_jb3 / EMMC FW Size : 678 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__alps__GT-N9000__GT-N9000__4.2.2__ALPS.JB3.MP.V1.2\ All done! |
The Following User Says Thank You to sunny_luthras99 For This Useful Post: |
01-21-2015, 12:10 | #57 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | Samsung Galaxy TAB 3 P1000 Code: Card found: S/N C5**** Chinese Miracle II [MTK module] v 1.09 Operation : Check / Read Info [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A2058494E594816B45DEAC14F45 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816B45DEAC14F45 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Brand : JTY ProdName : joytech72_wet_jb3 ProdModel : KT07 Device : joytech72_wet_jb3 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.10 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Read Flash [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A2058494E594816B45DEAC14F45 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816B45DEAC14F45 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : JTY ProdName : joytech72_wet_jb3 ProdModel : KT07 Device : joytech72_wet_jb3 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.10 [Read Ok] : preloader_joytech72_wet_jb3.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / joytech72_wet_jb3 / EMMC FW Size : 678 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__JTY__ KT07__joytech72_wet_jb3__4.2.2__ALPS.JB3.MP.V1.10\ All done! Done! Elapsed: 00:03:46 Reconnect Power/Cable! Operation : Repair Security [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : BB : MT6572, E01 HW : JOYTECH72_WET_JB3_HSPA_HW SW : MOLY.WR8.W1315.MD.WG.MP.V4.P2 MM : 2000.00.00 VR : 1.0 SN : 10 Security Info : IMEI [1] : Damaged! IMEI [2] : Damaged or not exists Read Ok! Update IMEI[1] to : 357557********* done! Update IMEI[2] to : 357557********* done! Done! Elapsed: 00:00:56 Reconnect Power/Cable! Code: Hardware : MT6572 Model : KT07 Build number : KT07.3G-20140603 Build date UTC : 20140603-101341 Android v : 4.2.2 Baseband v: MOLY.WR8.W1315.MD.WG.MP.V4.P2, 2013/11/01 19:32 Kernel v : 3.4.5 (azhuo@azhuo-desktop) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP Tue Jun 3 18:11:13 CST 2014 |
The Following User Says Thank You to Abzal For This Useful Post: |
01-21-2015, 12:26 | #58 (permalink) |
Insane Poster Join Date: Dec 2005 Location: Alien Nation
Member: 210581 Status: Offline Thanks Meter: 25 | Wait for phone... Phone found! [ 175 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : BB : MT6589 HW : LENOVO89_WET_JB2_MD1_HSPA_HW SW : S820.V21 MM : 2000.00.00 VR : 1.0 Security Info : IMEI [1] : Damaged! IMEI [2] : Damaged or not exists Read Ok! Update IMEI[1] to : 865xxxxxxxxxxxxx done! Update IMEI[2] to : 865xxxxxxxxxxxxx done! Done! Elapsed: 00:01:19 Reconnect Power/Cable! |
The Following User Says Thank You to titan_mael For This Useful Post: |
01-21-2015, 12:29 | #59 (permalink) |
Member: 210581 Status: Offline Thanks Meter: 25 | vandroid s3c Operation : Check / Read Info [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 175 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00C800BC009000550054007F007F0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008E , [Acsip] A5R4GA41ATS [NAND] : FLASH_DIE : 00C8 00BC 0090 0055 0054 007F 007F [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Format FileSystem [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 175 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00C800BC009000550054007F007F0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008E , [Acsip] A5R4GA41ATS [NAND] : FLASH_DIE : 00C8 00BC 0090 0055 0054 007F 007F [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
01-22-2015, 10:37 | #60 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Micromax A110Q Read Factory Firmware By Infinity CM2MTK Operation : Check / Read Info [ v1.09 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 204A0190594E4958A1A1164895A0EDCF DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A1A1CFEDA095 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Brand : Micromax ProdName : Micromax A110Q ProdModel : Micromax A110Q Device : Micromax A110Q AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.2 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Read Flash [ v1.09 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 204A0190594E4958A1A1164895A0EDCF DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A1A1CFEDA095 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Micromax ProdName : Micromax A110Q ProdModel : Micromax A110Q Device : Micromax A110Q AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.2 [Read Ok] : preloader_s9086b.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6589 / V1.0.0 / s9086b / EMMC FW Size : 546 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6589__Micromax__Micromax A110Q__Micromax A110Q__4.2.1__ALPS.JB2.MP.V1.2\ All done! Done! Elapsed: 00:02:43 Reconnect Power/Cable! |
