Old 09-01-2015, 12:16   #24796 (permalink)
Member: 2446652
infinty calculater is not working it says connect doungle which i already do
Old 09-01-2015, 12:53   #24797 (permalink)
ij_cell's Avatar
Member: 1937038
Sonork: QQ 2045657399
Thanks Meter: 4,492
Nokia 230 flash done.
Connect phone on selected interface...
Core : v2.10 , BB5XG FlashEngine : v9.9
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm987_14.0.5.mcusw.fls
PPM : rm987_14.0.1_059V2R4_m3_2030_01_423819.rofs.fls
CNT : rm987_14.0.1_059V2R4_m3_2030_01_423819.image.fls
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len : 0x16
IF xCPUID : XGOLD 221 [XMM2210 QIMING]
IF uCHIPID : 19421C0992D45064
IF Resp Data : 194200021C030101
Wait for user action : Insert battery
Sending EBL Loader ...
EBL Loader Ok
EBL Loader ready
Sending EBL ...
EBL sent Ok
EBL : 1_1336.500_MKEYSKEY
QIMING EEP config Ok
FLASHID : 52F00000 , [ NOR ]
Boot conf set, Target Ready
Boot done!
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI : 351739060748116
Phone Product Code : 059V8T7
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\351739060748116_XG 221_CRT.rpl
===Flashing [MCU]===
Processing file : rm987_14.0.5.mcusw.fls
Region count : 2
00 : [ PSI ] : rm987_14.0.5.mcusw.fls.fls
01 : [ Code ] : rm987_14.0.5.mcusw.fls.fls
Parse done , flashing now
Flash : 00 : rm987_14.0.5.mcusw.fls.fls
Sending Sec-Pack
SecInfo Area : 0x0000 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x40000000 , Len : 0x00020000
Erase done
Region Start : 0x40000000 , Data Len : 0x00020000
Region Load done
Wait for phone write all data ...
Write done
rm987_14.0.5.mcusw.fls.fls image flash done
Flash : 01 : rm987_14.0.5.mcusw.fls.fls
Sending Sec-Pack
SecInfo Area : 0x0001 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x40040000 , Len : 0x00020000
Erase done
Erase area 0x01 , Start 0x40060000 , Len : 0x00160000
Erase done
Erase area 0x02 , Start 0x40340000 , Len : 0x023C0000
Erase done
Erase area 0x03 , Start 0x47E00000 , Len : 0x00040000
Erase done
Region Start : 0x40040000 , Data Len : 0x00020000
Region Load done
Write done
Region Start : 0x40060000 , Data Len : 0x00160000
Region Load done
Write done
Region Start : 0x40340000 , Data Len : 0x01E84B74
Region Load done
Write done
===Flashing [PPM]===
Processing file : rm987_14.0.1_059V2R4_m3_2030_01_423819.rofs.fls
Region count : 1
00 : [ Cust ] : rofs_ebl_psi.fls
Flash : 00 : rofs_ebl_psi.fls
Sending Sec-Pack
Erase area 0x00 , Start 0x42880000 , Len : 0x00F80000
Erase done
Region Start : 0x42880000 , Data Len : 0x007E7AD8
Region Load done
Write done
rofs_ebl_psi.fls image flash done
===Flashing [CNT]===
Processing file : rm987_14.0.1_059V2R4_m3_2030_01_423819.image.fls
Region count : 1
00 : [ Cust ] : rm987_14.0.1_059V2R4_m3_2030_01_423819.image.fls.i mage.fls
Flash : 00 : rm987_14.0.1_059V2R4_m3_2030_01_423819.image.fls.i mage.fls
Sending Sec-Pack
Erase area 0x00 , Start 0x43800000 , Len : 0x04600000
Erase done
Erase area 0x01 , Start 0x47E40000 , Len : 0x000E0000
Erase done
Region Start : 0x43800000 , Data Len : 0x02B60000
Region Load done
Write done
rm987_14.0.1_059V2R4_m3_2030_01_423819.image.fls.i mage.fls image flash done
Flashing done!
Total flash time : 00:02:13
Reboot phone now...
Reading Phone Info....
Connected phone - 230
Software Info: V 14.0.5 21-04-14 RM-987 (c) Nokia
IMEI: 351739060748116
PPM version : ec8642ff589b4bbe806a63df2e59aaeb36d5f929
Product code: 059V8T7
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Check and Upload User Certificates ...
Total - 59 certs
Certificates found, skip upload ...
Battery voltage is enough for start
AfterFlash operations done ;D
Done!
Elapsed: 00:02:48
Phone found!
Series 40 Device detected!
read info... - Ok
Old 09-01-2015, 12:54   #24798 (permalink)
Member: 2377394
Thanks Meter: 31
a119 hang on logo recover by format
Card found: S/N 53A5:0129
Chinese Miracle II  [MTK module] v 1.26
Operation : Format FileSystem [ v1.26 ]
Wait for phone...
Phone found! [ 89 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164048602A3CE3C7147
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A4834473164048602A3CE3C7147
[eMMC] : FLASH_LEN : 0x00000000E7000000
INT RAM    : 0x00020000
EXT RAM    : 0x20000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Backup : Skipped by user request
FMT Mode set to : 0
Format : Cache and UserData (Full Factory Reset)
Format CACHE block
Format block Ok!
Format UDA block
Format block Ok!
Done!
Elapsed: 00:00:33
Reconnect Power/Cable!
Old 09-01-2015, 13:12   #24799 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
QMobile X35
Chinese Miracle II  [MTK module] v 1.28
Operation : Read Flash [ v1.28 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
DA Ver : MTK_AllInOne_DA_v7.1533.03
eMMC_ID : 45010053454D3034473A53FADBA79133
[eMMC] : FLASH_VEN : 0045 , OEM : 0100
[eMMC] : FLASH_INF : G40ME
[eMMC] : FLASH_CID : 45010053454D3034473A53FADBA79133
[eMMC] : FLASH_LEN : 0x00000000EC000000
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
Brand     : QMobile
ProdName  : QMobile X35
ProdModel : QMobile X35
Device    : QMobile
AndroidVer: 4.4.2
MTKxCPU   : MT6572
MTKxPRJ   : QMobileX35_MP_2014_0829
[Read Ok] : preloader_ztenj72_we_72_m536_kk.b
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[Read Ok] : fat.img
[ScatCFG] : MT6572 / V1.1.1 / ztenj72_we_72_m536_ / EMMC
FW Size : 854 MiB
Scatter saved to : C:\Documents and Settings\SAEED\Desktop\MT6572__QMobile__QMobile X35__QMobile__4.4.2__QMobileX35_MP_2014_0829\
All done!
Done!
Elapsed: 00:04:18
Old 09-01-2015, 13:19   #24800 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
Qmobile A8
Operation : Flash [ v1.28 ]
======= Flash
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
BB_CPU_NM : [MediaTek] MT6575|MT6577_S00
i2c Init : 0300771F
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
DA Stat : v3.2 on BBID : 0x84
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : M00U5
[eMMC] : FLASH_CID : 1501004E355530304D0297996E9380C7
[eMMC] : FLASH_LEN : 0x00000000E9000000
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC
Setting : AFF verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000008000
Erase : 0x0000000000F28000-0x00000000766C0200
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_gionee77_cu_jb.bin
Preloader Sent , Init passed
PartCount : 0012
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Image Flash Ok
Flash Write Done, time used : 00:02:09
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Verify Passed : FAT
Data Verify Done, time used : 00:00:59
Update RomInfo done
Done!
Elapsed: 00:03:28
Old 09-01-2015, 13:26   #24801 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
Gt-i8262
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 1501004E3958524D4200EA78D03D81BB
[eMMC] : FLASH_INF : BMRX9
[eMMC] : FLASH_CID : 1501004E3958524D4200EA78D03D81BB
[eMMC] : FLASH_LEN : 0x0000000070000000
EXT RAM    : 0x10000000
SOC VERIFY : C1
Boot Ok!
Brand     : samsung
ProdName  : GT-I8262
ProdModel : GT-I8262
Device    : GT-I8262
AndroidVer: 4.1.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.JB3.MP.V1
[Read Ok] : preloader_mbk72_wet_lca.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : fat.img
[ScatCFG] : MT6572 / V1.1.1 / mbk72_wet_lca / EMMC
FW Size : 476 MiB
Scatter saved to : C:\Documents and Settings\SAEED\Desktop\MT6572__samsung__GT-I8262__GT-I8262__4.1.2__ALPS.JB3.MP.V1\
All done!
Done!
Elapsed: 00:03:04
Old 09-01-2015, 13:27   #24802 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Huawei-C2601 SP-unlock
COM9 [VCP0] selected
module v2.05
Device: Huawei-C2601
operation: SP-unlock
Phone should be Switched ON !
connecting...
OFFLINE...
disable minlock...
Phones should be restarting now...
Finished, time used: 5 sec
The Following User Says Thank You to .::THE ROCK::. For This Useful Post:
Old 09-01-2015, 13:37   #24803 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
M550 v2
Operation : Read UserCode [ v1.28 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 33 ]
Sync...
Sync Ok, read regs...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : ECC1EC94E082B20E85D43F18C073D889
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : C200 2500 3800 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G
[0] : FLASH_DIE : 00C2 0025 0038 0000
[0] : FLASH_LEN : 0x01000000
SDS : 0x00000000 , 0x00000000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 1589
Privacy Lock :;
Done!
Elapsed: 00:00:25
Old 09-01-2015, 14:00   #24804 (permalink)
Member: 2406517
Sonork: 100.1641481
Thanks Meter: 38
q mobile x80 pattren lockread
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 1501004E35585A4D420170C1D66571D9
[eMMC] : FLASH_INF : BMZX5
[eMMC] : FLASH_CID : 1501004E35585A4D420170C1D66571D9
SOC VERIFY : C1
Boot Ok!
Reading data ...
FS Size : 1023 MiB
Magic Ok
Mount point : /data
Get PatternLock ...
PatternLock Sequnce : 41257863
Done!
GSMBOSS
Old 09-01-2015, 14:17   #24805 (permalink)
DUNIYA JAMAL's Avatar
Member: 192810
Sonork: Some people NEED change
Thanks Meter: 860
Qmobile R220 Read User Code Done
Operation : Read UserCode [ v1.27 ]
Wait for phone...
Phone found! [ 166 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : F890813D533C9341D345F196088910C6
Setting...
BROM stage done
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8E
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x0112 ,
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS : 0x003FE000 , 0x00002000
Read ExtData
Sorting ExtData
Reading UserCode
Active : No , Code : 1211
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:05
Old 09-01-2015, 14:19   #24806 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
Qmobile X2
Operation : Format FileSystem [ v1.28 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6571_S00
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
NAND_ID : 009800BC009000660076001600080000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x8B
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
BOOT TYPE  : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Format : UserData Only (Factory Reset)
Format UDA block
Format block Ok!
Done!
Elapsed: 00:00:16
Old 09-01-2015, 14:22   #24807 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
Qmobile B30
Operation : Check / Read Info [ v1.28 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : EB0A75DB3D46982B09AB1AAFA94D4803
Setting...
BROM stage done
InitRes : 00000000
DEV[0] : EF00 4000 1600 0000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00300000
Done!
Elapsed: 00:00:06
Load File
File_Info   : HEXING60M_11B_PCB01_gsm_MT6260_S00.5125_QMOBILE_B30_EN_UR_PE_TF_BT_FM_240X320_SC_V04_140325_0959.bin
FileVersion : 5125_QMOBILE_B30_EN_UR_PE_TF_BT_FM_240X320_SC_V04_140325_0959
Load File Ok
======= Flash
Files set for flashing :
[ MCU ] : HEXING60M_11B_PCB01_GSM_MT6260_S00.5125_QMOBILE_B30_EN_UR_PE_TF_BT_FM_240X320_SC_V04_140325_0959.BIN
Wait for phone...
Phone found! [ 22 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Flash now
Erase region , wait ...
Write data , wait ...
Write : HEXING60M_11B_PCB01_GSM_MT6260_S00.5125_QMOBILE_B30_EN_UR_PE_TF_BT_FM_240X320_SC_V04_140325_0959.BIN
Done!
Elapsed: 00:00:37
Old 09-01-2015, 14:24   #24808 (permalink)
Member: 192810
Thanks Meter: 860
Samsung Grand Repair Security Done
Operation : Check / Read Info [ v1.27 ]
Wait for phone...
Phone found! [ 113 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
i2c Init : 00000000
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
[eMMC] : FLASH_VEN : 0011 , OEM : 0100
[eMMC] : FLASH_INF : 09G40
[eMMC] : FLASH_CID : 1101003030344739305111642206318D
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
ProdName  : GT-I9082
ProdModel : GT-I9082
Device    : GT-I9082
AndroidVer: 4.2.2
MTKxCPU   : MT6575
MTKxPRJ   : ALPS.JB.MP.V1.16
MODEM :
BaseBand  : MT6575_S01_MAUI_11AMD_W12_22_SP_V23
Done!
Elapsed: 00:00:09
Operation : Repair Security [ v1.27 ]
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
i2c Init : 00000000
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
IMEI [00] : 358688000000158
IMEI [01] : 358688000000158
IMEI [02] : 358688000000158
IMEI [03] : 358688000000158
Set IMEI [00] : 3586xxxxxxx9027
Set IMEI [01] : 3586xxxxxxx9035
Prepare finished. Security check required!
Wait for phone...
Sync...
PostCheck Ok! Repair done!
Done!
Elapsed: 00:00:28
Old 09-01-2015, 14:26   #24809 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,405
intex y2pro privacy code remove done
Operation : Reset Privacy Lock [ v1.27 ]
Wait for phone...
Phone found! [ 12 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : FE014E50314A39344812F90B49F661F5
[eMMC] : FLASH_VEN : 00FE , OEM : 014E
[eMMC] : FLASH_INF : H49J1
[eMMC] : FLASH_CID : FE014E50314A39344812F90B49F661F5
[eMMC] : FLASH_LEN : 0x00000000E9800000
SOC VERIFY : C1
Boot Ok!
Checking data ...
Privacy Lock reset Ok!
Done!
Elapsed: 00:00:30
Old 09-01-2015, 14:27   #24810 (permalink)
Member: 192810
Thanks Meter: 860
Gfive A5 Read full info,NVRM & Read Factory File Done
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
eMMC_ID : 7001004D4D4330344758038A1EF911C9
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00A8
DRAM Init Ok , 0x20000000
[eMMC] : FLASH_VEN : 0070 , OEM : 0100
[eMMC] : FLASH_INF : G40CM
[eMMC] : FLASH_CID : 7001004D4D4330344758038A1EF911C9
[eMMC] : FLASH_LEN : 0x00000000E6800000
SOC VERIFY : C1
Boot Ok!
Brand     : alps
ProdName  : Z35CL
ProdModel : GFIVE A5
Device    : Z35CL
AndroidVer: 4.2.2
MTKxCPU   : MT6572
MODEM :
BaseBand  : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V1_1_2g_n
EXTRA :
LCD [0] : hx8357d_hsd35_hlt_hvga
LCD [1] : ili9488_ivo35_wuyang_hvga
LCD Res : 480x320
TOUCH [0] : GT9XX
TOUCH [1] : ft5306
CAM [0] : gc2035_yuv
CAM [1] : gc0328_yuv
CAM [2] : gc0311_yuv
MODEM : vanzo72_wet_jb3_gsm
LOCALE : en_US af_ZA am_ET ar_EG ar_IL bg_BG bn_IN ca_ES cs_CZ da_DK de_DE el_GR en_GB es_ES es_US fa_IR fi_FI fr_BE fr_CA fr_CH fr_FR hi_IN hr_HR hu_HU in_ID it_CH it_IT iw_IL ja_JP ko_KR lt_LT lv_LV ms_MY my_MM nb_NO nl_BE nl_NL pl_PL pt_BR pt_PT rm_CH ro_RO ru_RU sk_SK sl_SI sr_RS sv_SE sw_TZ th_TH tl_PH tr_TR uk_UA ur_PK vi_VN zh_CN zh_TW zu_ZA
Done!
Elapsed: 00:00:16
Operation : Read Flash [ v1.27 ]
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand     : alps
ProdName  : Z35CL
Device    : Z35CL
AndroidVer: 4.2.2
MTKxCPU   : MT6572
[Read Ok] : preloader_vanzo72_wet_jb3.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : fat.img
[ScatCFG] : MT6572 / V1.1.1 / vanzo72_wet_jb3 / EMMC
FW Size : 677 MiB
Scatter saved to : C:\Users\Fahad Irfan\Desktop\Gfive A5\MT6572__alps__GFIVE A5__Z35CL__4.2.2__ALPS.JB3.MP.V1\
All done!
Done!
Elapsed: 00:03:53
Operation : Read NVRAM [ v1.27 ]
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[Info] : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V1_1_2g_n
Read Ok, MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V1_1_2g_n_eMMC.spnv saved
Done!
Elapsed: 00:00:34
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.72372 seconds with 10 queries
