03-12-2017, 18:45 | #182 (permalink) |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | RKT FORMET DONE Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK3066 Read Info Ok! Format FS/Reset Settings accepted by User! Operation : FormatFS / ResetSettings [ v1.0 ] Init UserData Init Cache Init IntSD Init Ok! Format prepare Done! Wait, until device reboot Elapsed: 00:00:00 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! |
03-31-2017, 11:08 | #183 (permalink) |
Freak Poster Join Date: Jun 2010 Location: MEXICO
Member: 1318721 Status: Offline Thanks Meter: 166 | read pattern lock and flash rk2928 Read flash rock chip infinite rk2929 and read pattern by infinity look at the pictures by tecceljjr |
The Following User Says Thank You to kzafquiel For This Useful Post: |
04-07-2017, 15:39 | #187 (permalink) |
Insane Poster Join Date: Sep 2012 Location: belarus
Member: 1806875 Status: Offline Thanks Meter: 40 | Tablet pc Prestigio pmp7100D3g_quad Operation : ReadInfo [ v1.0 ] ======= Flash Info : Channel : 0x00 FlashType : EMMC FlashSize : 0x00000003A3E00000 FlashCaps : 524288/2048/40/0/0 ======= Device Info : Read Info Ok! Elapsed: 00:00:00 Operation : Read Flash [ v1.0 ] Collect InitData ... Reading now ... Reading : PARAMS Reading : MISC Reading : KERNEL Reading : BOOT Reading : RECOVERY Reading : BACKUP Reading : CACHE Reading : GSENSOR Reading failed! Send report to support with all logs! Elapsed: 00:00:22 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK3066 Read Info Ok! |
05-03-2017, 05:40 | #189 (permalink) |
Freak Poster Join Date: Sep 2009
Member: 1126839 Status: Offline Thanks Meter: 28 | my Infinity/cm2 RKT (rockchip tool) write button are disabled or more on tool button function are disabled? any solution? no problem for mtk, spd, lg, qualcom tools but for RKT button are disabled how to solve this? thanks in advance.. |
05-03-2017, 09:12 | #191 (permalink) | |
Member: 1126839 Status: Offline Thanks Meter: 28 | Quote:
i got the solution anyway.. pic | |
The Following User Says Thank You to mine4ever For This Useful Post: |
05-30-2017, 12:48 | #194 (permalink) |
Junior Member Join Date: Jan 2009
Member: 958990 Status: Offline Thanks Meter: 2 | Operation : Read Flash [ v1.0 ] Collect InitData ... Reading now ... Reading failed! Send report to support with all logs! Elapsed: 00:00:00 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Operation : ReadInfo [ v1.0 ] ======= Flash Info : Channel : 0x00 FlashType : ADDE14A742 FlashSize : 0x0000000212000000 FlashCaps : 4194304/16384/32/40/2 ======= Device Info : CPU : RK312X Android : v4.4.4 Project : eng.bnd_lhj.20150916.172342 Name : rk312x_esp8089 Brand : SuperTab Device : rk312x_esp8089 Model : SuperTabK7 Read Info Ok! Elapsed: 00:00:00 Detected : RK312X Read Info Ok! Operation : Read Flash [ v1.0 ] Collect InitData ... Reading now ... Reading failed! Send report to support with all logs! Elapsed: 00:00:00 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK312X Read Info Ok! |
06-07-2017, 21:44 | #195 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2206266 Status: Offline Thanks Meter: 21 | Collect InitData ... Reading now ... Reading : PARAMS Reading : UBOOT Reading failed! Send report to support with all logs! Elapsed: 00:00:01 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK312X Read Info Ok! Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! need help rk3128 |
