10-09-2015, 12:49 | #33 (permalink) | |
Freak Poster Join Date: Jun 2011
Member: 1607677 Status: Offline Thanks Meter: 272 | Quote:
10-09-2015, 15:26 | #34 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | this is log for a 3026 I have had for a while trying t5o find flash file to flash it. I was guessing it had the system damaged, since it is boot looping, it çonly shows 2 penguins for a while then reboots again. Code: Chinese Miracle II [RKT Module] v 1.0 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK3066 Read Info Ok! Code: Operation : ReadInfo [ v1.0 ] ======= Flash Info : Channel : 0x00 FlashType : ADDE94EB74 FlashSize : 0x0000000215000000 FlashCaps : 4194304/16384/32/40/2 ======= Device Info : CPU : RK3026 Android : v4.2.2 Project : eng.zengpq.20140728.203300 Name : rk3026 Brand : TUFSEN Device : rk3026 Model : OT-17DB8 Read Info Ok! Elapsed: 00:00:00 Code: Operation : Read Flash [ v1.0 ] Collect InitData ... Reading now ... Reading : PARAMS Reading : MISC Reading : KERNEL Reading failed! Send report to support with all logs! Elapsed: 00:00:31 Code: Format FS/Reset Settings accepted by User! Operation : FormatFS / ResetSettings [ v1.0 ] Error While Format Blocks! Elapsed: 00:00:05 |
10-09-2015, 15:36 | #36 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @yurais , by some reason, it disconnect or stop respond to commands. Try reset power ( by reset button ) , connect it again and do need operation directly - for ex. - connect, device catched by SW , press "Format FS" , or "Read FW". |
10-09-2015, 15:39 | #37 (permalink) |
Freak Poster Join Date: Aug 2010 Age: 38
Member: 1382268 Status: Offline Thanks Meter: 71 | This Is Realy First & Only In The Planet Master Jaydi And YellowBoss & All Infinity Team Members I Proud To Tel You This Is a Real First And Only In The Planet Thanks Infinity And Master Jaydi And Yellow Boss This Is The Real Chinese Miracle And No1 Can competition with you |
The Following 3 Users Say Thank You to aidin01 For This Useful Post: |
10-09-2015, 17:45 | #39 (permalink) | |
Member: 220595 Status: Offline Thanks Meter: 355 | Quote:
Read flash operation, after connecting external power supply to the tablet and also do as you instructed: operation directly as first Click after connect Code: Operation : Read Flash [ v1.0 ] Collect InitData ... Reading now ... Reading : PARAMS Reading : MISC Reading : KERNEL Reading : BOOT Reading : RECOVERY Reading : BACKUP Reading : CACHE Reading : USERDATA Reading : SYSTEM Read Ok! Firmware size : 570 MiB Saved as : RK3066__OT-17DB8__rk3026__eng.zengpq.20140728.203300.irkfw Done! Elapsed: 00:00:52 Format Code: Format FS/Reset Settings accepted by User! Operation : FormatFS / ResetSettings [ v1.0 ] Init UserData Init Cache Init IntSD Init Ok! Format prepare Done! Wait, until device reboot Elapsed: 00:00:00 Would like to flash firmware, but really I havent found a firmware for it. | |
10-09-2015, 18:05 | #40 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
About problem with this one - yes, need working firmware. | ||
10-09-2015, 19:52 | #41 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Yes, iknow, I just wanted to post some logs and tests. Great job Will post success stories as soon as I get a rock chip tablet with pattern, etc Enviado desde mi SM-N900T mediante Tapatalk |
10-09-2015, 21:23 | #42 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Algeria
Member: 158242 Status: Offline Sonork: 100.1591384 Thanks Meter: 194 | SUPERTAB S7 FACTORY RESET Code: Card found: S/N : XXXXXXXX , v0129 Chinese Miracle II [RKT Module] v 1.0 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK3066 Read Info Ok! Operation : ReadInfo [ v1.0 ] ======= Flash Info : Channel : 0x00 FlashType : ADDE14A742 FlashSize : 0x0000000212000000 FlashCaps : 4194304/16384/32/40/2 ======= Device Info : CPU : RK3026 Android : v4.4.2 Project : eng.wjw.20140917.102653 Name : rk3026 Brand : SuperTab Device : rk3026 Model : SuperTab.S7 Read Info Ok! Elapsed: 00:00:00 Format FS/Reset Settings accepted by User! Operation : FormatFS / ResetSettings [ v1.0 ] Init UserData Init Cache Init IntSD Init Ok! Format prepare Done! Wait, until device reboot Elapsed: 00:00:00 Code: Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK3066 Read Info Ok! Operation : Read Flash [ v1.0 ] Collect InitData ... Reading now ... Reading : PARAMS Reading : MISC Reading : KERNEL Reading : BOOT Reading : RECOVERY Reading : BACKUP Reading : CACHE Reading : USERDATA Reading : SYSTEM Read Ok! Firmware size : 821 MiB Saved as : RK3066__SUPERTAB.S7__rk3026__eng.wjw.20140917.102653.irkfw Done! AND REVIVE OTHER S7 DEAD WITH THIS DUMP Code: Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK3066 Read Info Ok! Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK3066 Read Info Ok! Selected : RK3066__SUPERTAB.S7__rk3026__eng.wjw.20140917.102653.irkfw FastVerify : Ok , 0x33598319 FwInfoBlk : 0x0009 Load Ok! Operation : Flash [ v1.0 ] INFRK Image : RK3066__SUPERTAB.S7__rk3026__eng.wjw.20140917.102653.irkfw Will flash INFRK image now... Update PMT ... Prepare ... Update ... Update Ok! Flashing now : MISC Prepare ... Writing ... Flash Ok! Flashing now : KERNEL Prepare ... Writing ... Flash Ok! Flashing now : BOOT Prepare ... Writing ... Flash Ok! Flashing now : RECOVERY Prepare ... Writing ... Flash Ok! Flashing now : BACKUP Prepare ... Writing ... Flash Ok! Flashing now : CACHE Prepare ... Writing ... Flash Ok! Flashing now : USERDATA Prepare ... Writing ... Flash Ok! Flashing now : ANDROID Writing ... Flash Ok! UIMG write finished sucessfully, resul : 0x09 Elapsed: 00:02:10 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! THANKS INFINITY TEAM GOOD WORKS |
The Following 5 Users Say Thank You to djlicks For This Useful Post: |
10-10-2015, 13:11 | #45 (permalink) |
Freak Poster Join Date: Nov 2012 Location: batna.algeria
Member: 1834802 Status: Offline Sonork: 100.1659078 Thanks Meter: 89 | not supported Chinese Miracle II [RKT Module] v 1.0 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK3066 Read Info Ok! Operation : ReadInfo [ v1.0 ] ======= Flash Info : Channel : 0x00 FlashType : 2C44444BA9 FlashSize : 0x000000010A000000 FlashCaps : 2097152/8192/32/40/4 ======= Device Info : CPU : RK3026 Android : v4.4.4 Project : eng.yuanye.20141105.151622 Name : TGW-706 Brand : condor Device : TGW-706 Model : TGW-706 Read Info Ok! Elapsed: 00:00:00 Operation : Read Flash [ v1.0 ] Collect InitData ... Reading now ... Reading failed! Send report to support with all logs! Elapsed: 00:00:00 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK3066 Read Info Ok! |
