10-10-2015, 13:57 | #46 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Check manually in SW installation folder. Something wrong with links. That mostly seems as HW problem. I try kill WiFi by much ways, but it gives me no any result. It work. After Full erase - also. | |
10-10-2015, 17:08 | #47 (permalink) |
Insane Poster Join Date: Nov 2012 Location: COLOMBIA
Member: 1842053 Status: Offline Thanks Meter: 30 | titan 7010ME 16GB Found active FlashInterface , connecting ... Detected : RK2929 Read Info Ok! Operation : ReadInfo [ v1.0 ] ======= Flash Info : Channel : 0x00 FlashType : 2C88044BA9 FlashSize : 0x0000000200000000 FlashCaps : 2097152/8192/33/24/4 ======= Device Info : CPU : ROCKCHIP Android : v4.0.3 Project : eng.dong.20120724.200340 Name : rk29sdk Brand : Android Device : rk29sdk Model : 720F Read Info Ok! Elapsed: 00:00:05 Format FS/Reset Settings accepted by User! Operation : FormatFS / ResetSettings [ v1.0 ] Init UserData Init Cache Init IntSD Init Ok! Format prepare Done! Wait, until device reboot Elapsed: 00:00:00 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK2929 Read Info Ok! Operation : ReadInfo [ v1.0 ] ======= Flash Info : Channel : 0x00 FlashType : 2C88044BA9 FlashSize : 0x0000000200000000 FlashCaps : 2097152/8192/33/24/4 ======= Device Info : CPU : ROCKCHIP Android : v4.0.3 Project : eng.dong.20120724.200340 Name : rk29sdk Brand : Android Device : rk29sdk Model : 720F Read Info Ok! Elapsed: 00:00:05 Format FS/Reset Settings accepted by User! Operation : FormatFS / ResetSettings [ v1.0 ] Init UserData Init Cache Init IntSD Init Ok! Format prepare Done! Wait, until device reboot Elapsed: 00:00:00 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! |
10-13-2015, 17:15 | #48 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 35
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | rk312x read info ok , format ok Code: Chinese Miracle II [RKT Module] v 1.0 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK312X Read Info Ok! Operation : ReadInfo [ v1.0 ] ======= Flash Info : Channel : 0x00 FlashType : 2C68044AA9 FlashSize : 0x0000000100000000 FlashCaps : 1048576/4096/32/24/4 ======= Device Info : CPU : RK312X Android : v4.4.4 Project : eng.zed.20141226.105601 Name : rk312x Brand : View_Tab Device : rk312x Model : VT700HD Read Info Ok! Elapsed: 00:00:00 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK312X Read Info Ok! Format FS/Reset Settings accepted by User! Operation : FormatFS / ResetSettings [ v1.0 ] Init UserData Init Cache Init IntSD Init Ok! Format prepare Done! Wait, until device reboot Elapsed: 00:00:00 |
The Following User Says Thank You to nori2007 For This Useful Post: |
10-13-2015, 21:47 | #52 (permalink) | |
Yes you can - http://forum.gsmhosting.com/vbb/f641...ongle-1973526/ | |
10-14-2015, 10:06 | #53 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: Gujarat
Member: 1528518 Status: Offline Sonork: 100.1641090 Thanks Meter: 26 | Quote:
Dear sir My antivirios is not in mistake. "your antivirus know nothing about software protection/packing algorithms." You know much more than antivirious i think. | |
10-14-2015, 11:40 | #56 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Do like it - Files & Folder >> Exclude Files & Folders & Exclude CM2 & CM2 installed folder . Br - srinibas | |
The Following User Says Thank You to srinibas For This Useful Post: |
10-14-2015, 11:58 | #57 (permalink) | |
Member: 1528518 Status: Offline Sonork: 100.1641090 Thanks Meter: 26 | Chinese Miracle-2 RKT/RockChip v1.00 - RockChip Service Module started Quote:
Yes bro. That i know and already did. But i posted to inform the team. But team member has only rubbish language. Thats why i post the send post. Thanks bro. Last edited by dilip_is; 10-14-2015 at 12:24. | |
10-14-2015, 13:00 | #58 (permalink) | |
If you not trust our sw and trust your antivirus - just remove our sw and be in safe. | |
10-14-2015, 18:07 | #59 (permalink) |
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | Code: Chinese Miracle II [RKT Module] v 1.0 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK2928 Read Info Ok! Operation : ReadInfo [ v1.0 ] ======= Flash Info : Channel : 0x00 FlashType : ADDE94DA74 FlashSize : 0x0000000200000000 FlashCaps : 2097152/8192/42/40/2 ======= Device Info : CPU : RK2928 Android : v4.1.1 Project : 20130119.093354 Name : rk2928sdk Brand : rk2928sdk Device : rk2928sdk Model : SIROCO 4 Read Info Ok! Elapsed: 00:00:05 Format FS/Reset Settings accepted by User! Operation : FormatFS / ResetSettings [ v1.0 ] Init UserData Init Cache Init IntSD Init Ok! Format prepare Done! Wait, until device reboot Elapsed: 00:00:00 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! |
