Old 06-16-2014, 09:34   #1 (permalink)
Member: 1043909
Thanks Meter: 60,926
Chinese Miracle-2 (Test Version) Reports: MTK/MediaTek
Dear Friends,
Please, post here your test reports with Chinese Miracle-2 (Test Version) MTK/MediaTek software.
This software is a Test Version so always make a backup before any operation !
How to Download and Activate Chinese Miracle-2 (Test Version) software (for FREE) for Main Infinity-Box:
http://forum.gsmhosting.com/vbb/f296...ocess-1867818/
Updates and support for MTK/MediaTek software:
1. Where to send flash files and links: [email protected]
2. If you have any MTK CPU based phone and want to see it supported - post here your request.
3. If you have any MTK CPU based phone with some kind of software damage/problem - post here your questions and we will try to adjust our software to fix that problems.
4. We need new phone samples for research: http://forum.gsmhosting.com/vbb/f296...earch-1786726/
The Following 24 Users Say Thank You to YellowBoss For This Useful Post:
Old 06-16-2014, 11:36   #2 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Octenn T1130
Read Info
Chinese Miracle II  [MTK module] v 0.02
Start  at : [6/16/2014 / 4:25:10 PM]
Operation : Check / Read Info [ v0.02 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 92 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : 75EC689866843363AF8ACAC85305DA66
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : EF00 4000 1600 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00300000
SDS : 0x002FE000 , 0x00002000
Done!
Read/Reset user code
Operation : Reset UserCode [ v0.02 ]
Wait for phone...
Phone found! [ 92 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:15
Reconnect Power/Cable!
Format FileSystem
Operation : Format FileSystem [ v0.02 ]
Wait for phone...
Phone found! [ 92 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Backup exists , skip
Executing FFS FORMAT now...
FAT_RANGE : 0x002BC000-0x002FDFFF , LEN : 0x00042000
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
Done!
Elapsed: 00:00:28
Read Flash
Operation : Read Flash [ v0.02 ]
Wait for phone...
Phone found! [ 92 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Read Flash now
Read Ok , 3145728 bytes read
Check and collect compile info
File_Info   : FARSIGHTED60M_11B_PCB01_gsm_MT6260_S00.S31_HM01_P10_V0_3.bin
FileVersion : S31_HM01_P10_V0.3
Saved to : C:\InfinityBox\CM2MTK\Read_out\FARSIGHTED60M_11B_PCB01_gsm_MT6260_S00.S31_HM01_P10_V0_3.bin
Done!
Elapsed: 00:00:15
The Following 4 Users Say Thank You to mbiborna For This Useful Post:
Old 06-16-2014, 11:42   #3 (permalink)
Member: 1280685
Thanks Meter: 59
Talking Cherry Mobile Q9TV
Check/Info
Start  at : [6/16/2014 / 6:35:40 PM]
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0000
BB_CPU_SN : 555658C8F86F17638C4ADD95C89FF09E
Setting...
BROM stage done
InitRes : 00000000
DEV[0] : C200 2500 3600 0000
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E
[0] : FLASH_DIE : 00C2 0025 0036 0000
[0] : FLASH_LEN : 0x00400000
SDS : 0x00000000 , 0x00000000
Done!
Elapsed: 00:00:13
Finish at : [6/16/2014 / 6:35:54 PM]
Read Full
Start  at : [6/16/2014 / 6:36:10 PM]
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
[ERROR] : DONE
BB_CPU_SN : UNKNOW [ READ ERROR ]
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Read Flash now
Read Ok , 4194304 bytes read
File_Info   : A_TEAM_PCB01_gprs_MT6250_S00.11BW1132.bin
FileVersion : 11BW1132
Saved to : C:\InfinityBox\CM2MTK\Read_out\A_TEAM_PCB01_gprs_MT6250_S00.11BW1132.bin
Done!
Elapsed: 00:00:25
Finish at : [6/16/2014 / 6:36:36 PM]
The Following 4 Users Say Thank You to @ndoy For This Useful Post:
Old 06-16-2014, 11:56   #4 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Symphony B3i
Read Flash
Wait for phone...
Phone found! [ 92 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : F9F5D61425DF41FCEBB2E457465BDA20
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Read Flash now
File_Info   : FARSIGHTED50M_11B_PCB01_gsm_MT6250_S00.SYMPHONY_B3I_SOFTWARE_V0_5.bin
FileVersion : Symphony_B3i_Software_V0.5
Saved to : C:\InfinityBox\CM2MTK\Read_out\FARSIGHTED50M_11B_PCB01_gsm_MT6250_S00.SYMPHONY_B3I_SOFTWARE_V0_5.bin
Done!
Elapsed: 00:00:16
Read info/Reset code Eror
Wait for phone...
Phone found! [ 92 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 0000
Setting...
BROM stage done
DownloadAgent matching HW NOT Found :(
Boot Error!
Elapsed: 00:00:04
Wait for phone...
Phone found! [ 92 ]
Sync...
Boot Info :
BB_CPU_ID : 0000
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MTxxx
Setting...
RTC/PowerLatch Settings Failed #1 (HW/Connection Error)
Boot Error!
Elapsed: 00:00:02
The Following 2 Users Say Thank You to mbiborna For This Useful Post:
Old 06-16-2014, 12:08   #5 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
@mbiborna , something wrong with connection.
Install drivers from CM2MTK folder, restart PC and try again. Should works.
The Following 2 Users Say Thank You to Dzirt For This Useful Post:
Old 06-16-2014, 13:01   #6 (permalink)
ankit9090117706's Avatar
Member: 1291109
Sonork: 100.1607039
Thanks Meter: 19
Wait for phone...
Phone found! [ 30 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : BBFFAA388185FBC7D035961CDDFF9E1D
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Done!
Elapsed: 00:00:17
The Following 3 Users Say Thank You to ankit9090117706 For This Useful Post:
Old 06-16-2014, 13:18   #7 (permalink)
Member: 2151029
Thanks Meter: 4
is it going to work in my android 4.2(samsung dues) version mobile ?
The Following 3 Users Say Thank You to Osvaldo2461 For This Useful Post:
Old 06-16-2014, 14:19   #8 (permalink)
ishant's Avatar
Member: 1763238
Thanks Meter: 370
Lava kkt14+
Read info
Wait for phone...
Phone found! [ 9 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : 7D26DDF323DA1DA95DC0DD80568008E2
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Done!
Elapsed: 00:00:20
Reconnect Power/Cable!READ FLASH
Wait for phone...
Phone found! [ 9 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Read Flash now
File_Info : R025_LAVA_V_PCB01_gsm_MT6260_S00.LAVA_KKT14_S004_2 0130606.bin
FileVersion : LAVA_KKT14_S004_20130606
Saved to : C:\InfinityBox\CM2MTK\Read_out\R025_LAVA_V_PCB01_g sm_MT6260_S00.LAVA_KKT14_S004_20130606.bin
Done!
Elapsed: 00:00:12
READ USER CODE
Wait for phone...
Phone found! [ 9 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
Done!
Elapsed: 00:00:11
The Following 2 Users Say Thank You to ishant For This Useful Post:
Old 06-16-2014, 14:25   #9 (permalink)
Member: 1140831
Sonork: no
Thanks Meter: 232
wow very nice update i hope all mtk , spd and coolsend full ver working step by step
The Following User Says Thank You to parmodparmod For This Useful Post:
Old 06-16-2014, 14:35   #10 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Our CoolSand/RDA module is strongest, than all existing. And it just half of it full potential.
More Platforms and models on way.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 06-16-2014, 19:07   #11 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 517
good decision now this time i hope yr product run very faster l
Old 06-16-2014, 19:59   #12 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Karbonn K51 Test Report
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : 96370605719DEDE8FBDABFE07FBDDB4D
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Done!
Elapsed: 00:00:14
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Read Flash now
File_Info   : SANSTAR60M_KARBONN51_PCB01_gprs_MT6260_S00.MAUI_11B_W13_08_MP_V3_F3.bin
FileVersion : MAUI.11B.W13.08.MP.V3.F3
Saved to : C:\InfinityBox\CM2MTK\Read_out\SANSTAR60M_KARBONN51_PCB01_gprs_MT6260_S00.MAUI_11B_W13_08_MP_V3_F3.bin
Done!
Elapsed: 00:00:16
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Backup done
FAT_RANGE : 0x002CA000-0x002FFFFF , LEN : 0x00036000
Done!
Elapsed: 00:00:20
Operation : Repair Security [ v0.02 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 0000
BB_CPU_HW : 0000
BB_CPU_SW : 0000
BB_CPU_SB : 0000
BB_CPU_SN : 00000000000000000000000000000000
BROM Protocol Version : FF
Setting Service Mode ...
Init Service mode failed, something went wrong :(
Why 1st Page (Settings) Hide ?
I Can't Select Interface/Come For Write Security.
Old 06-17-2014, 04:20   #13 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Because it is test version limitation.
By log - just try again. It was disconnected during boot by some reason.
Old 06-17-2014, 04:43   #14 (permalink)
Member: 50772
Sonork: 100.1590990
Thanks Meter: 318
i got this error
Wait for phone...
Phone found! [ 30 ]
Sync...
Boot Info :
BB_CPU_ID : A5A5
BB_CPU_HW : A5A5
BB_CPU_SW : 5678
BB_CPU_SB : 5678
BB_CPU_SN : 6F1885BBB2D69C42AB1F8CFDA904732C
Setting...
Boot Error!
Elapsed: 00:00:04
Old 06-17-2014, 05:32   #15 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
bro check ur usb cable ,change the part of usb and restart pc
Page generated in 0.37510 seconds with 10 queries
