Chinese Miracle-2 (Test Version) Reports: MTK/MediaTek Dear Friends, Please, post here your test reports with Chinese Miracle-2 (Test Version) MTK/MediaTek software. This software is a Test Version so always make a backup before any operation ! How to Download and Activate Chinese Miracle-2 (Test Version) software (for FREE) for Main Infinity-Box: http://forum.gsmhosting.com/vbb/f296...ocess-1867818/ Updates and support for MTK/MediaTek software: 1. Where to send flash files and links: [email protected] 2. If you have any MTK CPU based phone and want to see it supported - post here your request. 3. If you have any MTK CPU based phone with some kind of software damage/problem - post here your questions and we will try to adjust our software to fix that problems. 4. We need new phone samples for research: http://forum.gsmhosting.com/vbb/f296...earch-1786726/ |
Octenn T1130 Read Info Code: Chinese Miracle II [MTK module] v 0.02 Code: Operation : Reset UserCode [ v0.02 ] Code: Operation : Format FileSystem [ v0.02 ] Code: Operation : Read Flash [ v0.02 ] |
Cherry Mobile Q9TV Check/Info Code: Start at : [6/16/2014 / 6:35:40 PM] Code: Start at : [6/16/2014 / 6:36:10 PM] |
Symphony B3i Read Flash Code: Operation : Read Flash [ v0.02 ] Code: Operation : Check / Read Info [ v0.02 ] |
@mbiborna , something wrong with connection. Install drivers from CM2MTK folder, restart PC and try again. Should works. |
Operation : Check / Read Info [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 30 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : BBFFAA388185FBC7D035961CDDFF9E1D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
is it going to work in my android 4.2(samsung dues) version mobile ? |
Lava kkt14+ Read info Operation : Check / Read Info [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 7D26DDF323DA1DA95DC0DD80568008E2 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Done! Elapsed: 00:00:20 Reconnect Power/Cable!READ FLASH Operation : Read Flash [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 7D26DDF323DA1DA95DC0DD80568008E2 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Read Flash now Read Ok , 3145728 bytes read Check and collect compile info File_Info : R025_LAVA_V_PCB01_gsm_MT6260_S00.LAVA_KKT14_S004_2 0130606.bin FileVersion : LAVA_KKT14_S004_20130606 Saved to : C:\InfinityBox\CM2MTK\Read_out\R025_LAVA_V_PCB01_g sm_MT6260_S00.LAVA_KKT14_S004_20130606.bin Done! Elapsed: 00:00:12 Reconnect Power/Cable! READ USER CODE Operation : Reset UserCode [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 7D26DDF323DA1DA95DC0DD80568008E2 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
wow very nice update i hope all mtk , spd and coolsend full ver working step by step |
More Platforms and models on way. |
Karbonn K51 Test Report Operation : Check / Read Info [ v0.02 ] Code: 1. Power Off Phone , Remove battery , Insert back Operation : Read Flash [ v0.02 ] Code: 1. Power Off Phone , Remove battery , Insert back Operation : Format FileSystem [ v0.02 ] Code: 1. Power Off Phone , Remove battery , Insert back Operation : Repair Security [ v0.02 ] Code: 1. Power Off Phone , Remove battery , Insert back I Can't Select Interface/Come For Write Security. |
Because it is test version limitation. By log - just try again. It was disconnected during boot by some reason. |
i got this error Operation : Format FileSystem [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 30 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : A5A5 BB_CPU_HW : A5A5 BB_CPU_SW : 5678 BB_CPU_SB : 5678 BB_CPU_NM : [MediaTek] MTxxx BB_CPU_SN : 6F1885BBB2D69C42AB1F8CFDA904732C BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Elapsed: 00:00:04 Reconnect Power/Cable! |
bro check ur usb cable ,change the part of usb and restart pc |
