06-16-2014, 09:34 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,853 | Chinese Miracle-2 (Test Version) Reports: MTK/MediaTek Please, post here your test reports with Chinese Miracle-2 (Test Version) MTK/MediaTek software. This software is a Test Version so always make a backup before any operation ! How to Download and Activate Chinese Miracle-2 (Test Version) software (for FREE) for Main Infinity-Box: http://forum.gsmhosting.com/vbb/f296...ocess-1867818/ Updates and support for MTK/MediaTek software: 1. Where to send flash files and links: [email protected] 2. If you have any MTK CPU based phone and want to see it supported - post here your request. 3. If you have any MTK CPU based phone with some kind of software damage/problem - post here your questions and we will try to adjust our software to fix that problems. 4. We need new phone samples for research: http://forum.gsmhosting.com/vbb/f296...earch-1786726/ Last edited by YellowBoss; 10-12-2014 at 07:27. |
The Following 24 Users Say Thank You to YellowBoss For This Useful Post: |
06-16-2014, 11:36 | #2 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,213 | Octenn T1130 Read Info Code: Chinese Miracle II [MTK module] v 0.02 Start at : [6/16/2014 / 4:25:10 PM] Operation : Check / Read Info [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 92 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 75EC689866843363AF8ACAC85305DA66 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Done! Code: Operation : Reset UserCode [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 92 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 75EC689866843363AF8ACAC85305DA66 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:15 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 92 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 75EC689866843363AF8ACAC85305DA66 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Backup exists , skip Executing FFS FORMAT now... FAT_RANGE : 0x002BC000-0x002FDFFF , LEN : 0x00042000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:28 Reconnect Power/Cable! Code: Operation : Read Flash [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 92 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 75EC689866843363AF8ACAC85305DA66 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Read Flash now Read Ok , 3145728 bytes read Check and collect compile info File_Info : FARSIGHTED60M_11B_PCB01_gsm_MT6260_S00.S31_HM01_P10_V0_3.bin FileVersion : S31_HM01_P10_V0.3 Saved to : C:\InfinityBox\CM2MTK\Read_out\FARSIGHTED60M_11B_PCB01_gsm_MT6260_S00.S31_HM01_P10_V0_3.bin Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to mbiborna For This Useful Post: |
06-16-2014, 11:42 | #3 (permalink) |
Freak Poster Join Date: Apr 2010
Member: 1280685 Status: Offline Thanks Meter: 59 | Cherry Mobile Q9TV Check/Info Code: Start at : [6/16/2014 / 6:35:40 PM] Operation : Check / Read Info [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 42 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 555658C8F86F17638C4ADD95C89FF09E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Done! Elapsed: 00:00:13 Reconnect Power/Cable! Finish at : [6/16/2014 / 6:35:54 PM] Code: Start at : [6/16/2014 / 6:36:10 PM] Operation : Read Flash [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 42 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 [ERROR] : DONE BB_CPU_SN : UNKNOW [ READ ERROR ] BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : A_TEAM_PCB01_gprs_MT6250_S00.11BW1132.bin FileVersion : 11BW1132 Saved to : C:\InfinityBox\CM2MTK\Read_out\A_TEAM_PCB01_gprs_MT6250_S00.11BW1132.bin Done! Elapsed: 00:00:25 Reconnect Power/Cable! Finish at : [6/16/2014 / 6:36:36 PM] |
The Following 4 Users Say Thank You to @ndoy For This Useful Post: |
06-16-2014, 11:56 | #4 (permalink) |
Member: 770503 Status: Offline Thanks Meter: 1,213 | Symphony B3i Read Flash Code: Operation : Read Flash [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 92 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : F9F5D61425DF41FCEBB2E457465BDA20 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Read Flash now Read Ok , 3145728 bytes read Check and collect compile info File_Info : FARSIGHTED50M_11B_PCB01_gsm_MT6250_S00.SYMPHONY_B3I_SOFTWARE_V0_5.bin FileVersion : Symphony_B3i_Software_V0.5 Saved to : C:\InfinityBox\CM2MTK\Read_out\FARSIGHTED50M_11B_PCB01_gsm_MT6250_S00.SYMPHONY_B3I_SOFTWARE_V0_5.bin Done! Elapsed: 00:00:16 Reconnect Power/Cable! Code: Operation : Check / Read Info [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 92 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : F9F5D61425DF41FCEBB2E457465BDA20 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW NOT Found :( Boot Error! Elapsed: 00:00:04 Reconnect Power/Cable! Operation : Reset UserCode [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 92 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 0000 BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MTxxx BB_CPU_SN : F9F5D61425DF41FCEBB2E457465BDA20 BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Elapsed: 00:00:02 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to mbiborna For This Useful Post: |
06-16-2014, 12:08 | #5 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | @mbiborna , something wrong with connection. Install drivers from CM2MTK folder, restart PC and try again. Should works. |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
06-16-2014, 13:01 | #6 (permalink) |
Freak Poster Join Date: Apr 2010 Location: BARGARH Age: 33
Member: 1291109 Status: Offline Sonork: 100.1607039 Thanks Meter: 19 | Operation : Check / Read Info [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 30 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : BBFFAA388185FBC7D035961CDDFF9E1D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to ankit9090117706 For This Useful Post: |
06-16-2014, 13:18 | #7 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2151029 Status: Offline Sonork: [email protected] Thanks Meter: 4 | is it going to work in my android 4.2(samsung dues) version mobile ? |
The Following 3 Users Say Thank You to Osvaldo2461 For This Useful Post: |
06-16-2014, 14:19 | #8 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | Lava kkt14+ Read info Operation : Check / Read Info [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 7D26DDF323DA1DA95DC0DD80568008E2 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Done! Elapsed: 00:00:20 Reconnect Power/Cable!READ FLASH Operation : Read Flash [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 7D26DDF323DA1DA95DC0DD80568008E2 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Read Flash now Read Ok , 3145728 bytes read Check and collect compile info File_Info : R025_LAVA_V_PCB01_gsm_MT6260_S00.LAVA_KKT14_S004_2 0130606.bin FileVersion : LAVA_KKT14_S004_20130606 Saved to : C:\InfinityBox\CM2MTK\Read_out\R025_LAVA_V_PCB01_g sm_MT6260_S00.LAVA_KKT14_S004_20130606.bin Done! Elapsed: 00:00:12 Reconnect Power/Cable! READ USER CODE Operation : Reset UserCode [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 7D26DDF323DA1DA95DC0DD80568008E2 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to ishant For This Useful Post: |
06-16-2014, 14:25 | #9 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india
Member: 1140831 Status: Online Sonork: no Thanks Meter: 231 | wow very nice update i hope all mtk , spd and coolsend full ver working step by step |
The Following User Says Thank You to parmodparmod For This Useful Post: |
06-16-2014, 19:59 | #12 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,825 | Karbonn K51 Test Report Operation : Check / Read Info [ v0.02 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 96370605719DEDE8FBDABFE07FBDDB4D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Read Flash [ v0.02 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 96370605719DEDE8FBDABFE07FBDDB4D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Read Flash now Read Ok , 3145728 bytes read Check and collect compile info File_Info : SANSTAR60M_KARBONN51_PCB01_gprs_MT6260_S00.MAUI_11B_W13_08_MP_V3_F3.bin FileVersion : MAUI.11B.W13.08.MP.V3.F3 Saved to : C:\InfinityBox\CM2MTK\Read_out\SANSTAR60M_KARBONN51_PCB01_gprs_MT6260_S00.MAUI_11B_W13_08_MP_V3_F3.bin Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Format FileSystem [ v0.02 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 96370605719DEDE8FBDABFE07FBDDB4D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x002CA000-0x002FFFFF , LEN : 0x00036000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Repair Security [ v0.02 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 0000 BB_CPU_HW : 0000 BB_CPU_SW : 0000 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MTxxx BB_CPU_SN : 00000000000000000000000000000000 BROM Protocol Version : FF Setting Service Mode ... Init Service mode failed, something went wrong :( Reconnect Power/Cable! I Can't Select Interface/Come For Write Security. |
06-17-2014, 04:43 | #14 (permalink) |
No Life Poster Join Date: Jan 2004 Location: india
Member: 50772 Status: Offline Sonork: 100.1590990 Thanks Meter: 318 | i got this error Operation : Format FileSystem [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 30 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : A5A5 BB_CPU_HW : A5A5 BB_CPU_SW : 5678 BB_CPU_SB : 5678 BB_CPU_NM : [MediaTek] MTxxx BB_CPU_SN : 6F1885BBB2D69C42AB1F8CFDA904732C BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Elapsed: 00:00:04 Reconnect Power/Cable! |
