Old 08-27-2014, 01:33   #151 (permalink)
Crazy Poster
Member: 1711990
Sonork: jmgcommgroup
I try to read a full flash for BLU D161a and recieve the following error:
Operation : Read Flash [ v0.03 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 156 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : A5A5
BB_CPU_HW : A5A5
BB_CPU_SW : 5678
BB_CPU_SB : 5678
BB_CPU_NM : [MediaTek] MTxxx
BB_CPU_SN : 2C61C1B6C4960A11EDEEADADAFF601AB
BROM Protocol Version : 05
Setting...
RTC/PowerLatch Settings Failed #1 (HW/Connection Error)
Boot Error!
Elapsed: 00:00:12
Reconnect Power/Cable!
Old 08-27-2014, 09:18   #152 (permalink)
Member: 130995
Thanks Meter: 35,227
Originally Posted by .:iTRi:. View Post
Operation : Format FileSystem [ v0.03 ]
Wait for phone...
Phone found! [ 176 ]
Sync...
Boot Info :
BB_CPU_ID : A5A5
BB_CPU_HW : A5A5
BB_CPU_SW : 5678
BB_CPU_SB : 5678
BB_CPU_SN : 04F21C76D09AEC505CCBB37709439318
Setting...
Boot Error!
Elapsed: 00:00:04
need to format this set any solution
Hello,
There is a chance that its a problem with cable or with initial connection.
Try to repeat operatiion several times and post here more operation logs.
Old 08-27-2014, 09:18   #153 (permalink)
Member: 130995
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : A5A5
BB_CPU_HW : A5A5
BB_CPU_SW : 5678
BB_CPU_SB : 5678
Setting...
Boot Error!
Elapsed: 00:00:12
Hello,
Old 08-27-2014, 14:23   #154 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Probably - it is MTK SP. Not supported in "test" releases.
Old 08-30-2014, 09:23   #155 (permalink)
niloy2007's Avatar
Member: 1426012
Sonork: ICQ#618627674
Thanks Meter: 886
Yxtel-c9-6260 16mb(new)
Chinese Miracle II  [MTK module] v 0.03
Start  at : [8/30/2014 / 11:54:21 AM]
Wait for phone...
Phone found! [ 34 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : EB73EE996DA9414B59B6E44E18970B1B
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : C800 6000 1800 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128
[0] : FLASH_DIE : 00C8 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
SDS : 0x00000000 , 0x00000000
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x00E80000-0x00FFFFFF , LEN : 0x00180000
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
Done!
Elapsed: 00:00:19
Finish at : [8/30/2014 / 11:54:41 AM]
Start  at : [8/30/2014 / 11:54:59 AM]
Wait for phone...
Phone found! [ 34 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Read Flash now
Read Ok , 16777216 bytes read
Check and collect compile info
File_Info   : PCB01_MT6260_S00.E903YXBR1912864240320ENFRPTVIARPSTHHI1309241150.1309241150.bin
FileVersion : E903YXBR191309241150
Saved to : C:\InfinityBox\CM2MTK\Read_out\PCB01_MT6260_S00.E903YXBR1912864240320ENFRPTVIARPSTHHI1309241150.1309241150.bin
Done!
Elapsed: 00:01:13
The Following User Says Thank You to niloy2007 For This Useful Post:
Old 08-31-2014, 11:15   #156 (permalink)
.:iTRi:.'s Avatar
Member: 240068
Thanks Meter: 201
wiko lubi2 read flash ok
Wait for phone...
Phone found! [ 143 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0000
BB_CPU_SN : A4E3BBB1AB6596F68F1838611EFDE282
Setting...
BROM stage done
InitRes : 00000000
DEV[0] : EF00 4000 1600 0000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00300000
Read Flash now
Read Ok , 3145728 bytes read
File_Info : TINNO50M_3232_11B_PCB01_gsm_MT6250_S00.B1080_MP_F2 F3F5F8_FR_06_12.bin
FileVersion : B1080_MP_F2F3F5F8_FR_06_12
Saved to : C:\InfinityBox\CM2MTK\Read_out\TINNO50M_3232_11B_P CB01_gsm_MT6250_S00.B1080_MP_F2F3F5F8_FR_06_12.bin
Done!
Elapsed: 00:00:15
i will upload flash if needed
The Following User Says Thank You to .:iTRi:. For This Useful Post:
Old 08-31-2014, 11:20   #157 (permalink)
jupizet's Avatar
Member: 154427
Thanks Meter: 61
Its software support mt6276 with 256mb size.if its support where i can buy this product?thanks.
Old 08-31-2014, 11:51   #158 (permalink)
Member: 1043909
Thanks Meter: 60,926
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Read Flash now
Done!
Elapsed: 00:00:15
Hello,
Yes, please, upload this firmware somewhere and post here link.
Thank you !
Old 08-31-2014, 12:03   #159 (permalink)
.:iTRi:.'s Avatar
Member: 240068
Thanks Meter: 201
wiko lubi2 flash file
Old 08-31-2014, 15:21   #160 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
LAVA Dis128
Wait for phone...
Phone found! [ 106 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : C3352252F11AAE3CAA9E4292D69F64C8
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Backup done
FAT_RANGE : 0x00E70000-0x00FFFFFF , LEN : 0x00190000
Done!
Elapsed: 00:00:25
IMEI
Operation : Repair Security [ v0.03 ]
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting Service Mode ...
Init Ok, waiting for phone ...
Phone Initial Info :
BB : MT6250
SW : LAVA_DISCOVER128_S200_20130703
HW : LAVA50_11B_HW
IMEI[1] read error
IMEI[2] info not exist
Update IMEI[1] to : 91124040060++++
Update IMEI[2] to : 91124040071++++
Done!
Done!
Elapsed: 00:00:41
The Following User Says Thank You to VIJAY2U2 For This Useful Post:
Old 09-01-2014, 13:40   #161 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
Spice_M-5006_MT6260M_MTK lock done
The Following 2 Users Say Thank You to .::TEJARAM::. For This Useful Post:
Old 09-02-2014, 11:44   #162 (permalink)
niloy2007's Avatar
Member: 1426012
Thanks Meter: 886
Mtk- 625a
Wait for phone...
Phone found! [ 34 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : 333F37E7357390744E64A0D3B66CBB68
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Backup done
FAT_RANGE : 0x00DE0000-0x00FFFFFF , LEN : 0x00220000
The Following 2 Users Say Thank You to niloy2007 For This Useful Post:
Old 09-02-2014, 15:07   #163 (permalink)
niloy2007's Avatar
Member: 1426012
Thanks Meter: 886
Maxx-mx240
Wait for phone...
Phone found! [ 34 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : C1BD4DC9D2C211235E4752479EFA416C
Setting...
BROM stage done
InitRes : 00000000
DEV[0] : C200 2500 3600 0000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : DONE
[0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E
[0] : FLASH_DIE : 00C2 0025 0036 0000
[ERROR] : DA_BLANK_FLASH
Erase region , wait ...
Write data , wait ...
Write : maxx mx240 pass-645374 FARSIGHTED60M_11B_PCB01_GSM_MT6260_S00_2.S31_ANX01_P03_MX240_V0_2
Done!
Elapsed: 00:00:37
Old 09-04-2014, 14:39   #164 (permalink)
niloy2007's Avatar
Member: 1426012
Thanks Meter: 886
Geotel-champion
M5203_QVGA_XH_EHP_224_2_PCB01_GPRS_MT6252_S01.KABM 5203_XH_EHP_1.01.224(GEOTEL-CHAMPION)
Old 09-04-2014, 21:50   #165 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Phillips W732 , MTK 6575 Android
Read Info
Operation : Check / Read Info [ v1.00 ]
Wait for phone...
Phone found! [ 85 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
BB_CPU_NM : [MediaTek] MT6575_S00
Processing BROM stage
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
DA Stat : v3.2 on BBID : 0x84
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : HYNIX
[eMMC] : FLASH_CSD : DD109B454EA11648594E4958204A0190
[eMMC] : FLASH_LEN : 0x00000000E7000000
INT RAM    : 0x00020000
EXT RAM    : 0x20000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Initial info read Ok!
Format , Read FW operations enabled now
Done!
Elapsed: 00:00:24
Safe Format
Operation : Format FileSystem [ v1.00 ]
Wait for phone...
Phone found! [ 85 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
FMT Mode set to : 0x0007
Format CACHE block
Format block Ok!
Format UDA block
Format block Ok!
Done!
Elapsed: 00:00:13
The Following 2 Users Say Thank You to Dzirt For This Useful Post:
Page generated in 0.28465 seconds with 9 queries
