08-27-2015, 13:40 | #197 (permalink) |
Junior Member Join Date: Aug 2013
Member: 1993758 Status: Offline Sonork: sudan Thanks Meter: 6 | Card-Reader: FT SCR2000 0 Token HWID: 00098C8510321292 Box/Dongle type: [BEST] Box/Dongle Serial No (S/N): 61128C85 Firmware version: 0122.02 Box/Dongle status: 48 "UK edition" status: Off Last launched application: 0000 v.0000 Active modules: - 03: [BEST] v.0122 Online Service Account: Infinity-Box - Online Service - Username: 0361128C85 - Password: xxxx Box/Dongle key: 7FB5C52FCA4705FD Box/Dongle [61128C85] identification data is damaged, error code #30 contact to support: [email protected] Last edited by YellowBoss; 08-27-2015 at 14:43. Reason: password removed |
08-27-2015, 14:44 | #198 (permalink) | |
Send fault.bin file from BEST folder to [email protected] | |
08-28-2015, 14:12 | #199 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Kampala,Uganda
Member: 2294589 Status: Offline Thanks Meter: 116 | M t n s620 unlock done Searching phone; Phone detected (@oem5.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on MediaTek USB VCOM (Android) (COM242); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V47 Hw Version: HEXING72_CWET_KK_HSPA_HW Reading phone info; IMEI: 359767-05-540351-4 Reading simlock info; Locked to: 460-00 code_cat_n: 12345678 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:02:55 Log file saved to: LOG_28_08_2015_15_54_39.txt |
09-06-2015, 11:17 | #200 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: Setif
Member: 1020097 Status: Offline Sonork: 100.1612690 Thanks Meter: 83 | Quote:
10-11-2015, 10:30 | #201 (permalink) |
Freak Poster Join Date: Nov 2005 Location: no idea
Member: 196076 Status: Offline Sonork: 1000.1603124 Thanks Meter: 65 | connecting any phone show error 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 11 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Elapsed: 00:00:09 Reconnect Power/Cable! |
10-26-2015, 14:24 | #202 (permalink) | |
Crazy Poster Join Date: Sep 2007
Member: 587029 Status: Offline Thanks Meter: 8 | Quote:
which tool did u use for the unlock? | |
11-06-2015, 08:02 | #204 (permalink) |
No Life Poster Join Date: May 2014 Location: Peshwar, Pakistan
Member: 2192793 Status: Offline Thanks Meter: 188 | Salam Infinity team, sir i have best dongle (nokia) & i have some query that can i use this dongle on infinity best box software (Chinese Miracle 2) or that is different. if Chinese Miracle 2 is change then plz tell me from where i can buy that box in Pakistan on best price . thanks |
11-06-2015, 08:33 | #205 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Yes, you can activate CM2 on Infinity BEST dongle. For more info read here- http://forum.gsmhosting.com/vbb/f641...ongle-1973526/ For buying contact any reseller- http://forum.gsmhosting.com/vbb/f296...stock-1976320/ Infinity-Box - How to buy Also you can buy Infinity Dongle separately from any Reseller if you don't want to activate CM2 on your Infinity BEST dongle. More info about Infinity Dongle here- http://forum.gsmhosting.com/vbb/f296...llers-1943689/ Br. | |
11-06-2015, 16:21 | #206 (permalink) |
Freak Poster Join Date: Jul 2012 Location: gujranwala pakistan Age: 31
Member: 1787195 Status: Offline Sonork: 100.1617895 Thanks Meter: 29 | Operation : Remove Viruses [SmartAV] [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004D344731464103930FF423CF89 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : AF1G4 [eMMC] : FLASH_CID : 1501004D344731464103930FF423CF89 [eMMC] : FLASH_EXT : 00100000/00020000 [eMMC] : FLASH_LEN : 0x00000000EE800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 137 AVVerify : Too much data! Break! Send report to support Error! Check previous message for more info! Check battery, cable, charge! Before try again, check result! Operation Failed Elapsed: 00:00:48 Reconnect Power/Cable! how to fix this error |
11-24-2015, 06:50 | #208 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Inside Universe
Member: 442808 Status: Offline Thanks Meter: 195 | Micromax A089 Sucessfully repair Hang on Logo Code: Operation : Check / Read Info [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 50 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D433034470206683E6A5197 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D433034470206683E6A5197 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E2C00000 [eMMC] : FLASH_UCP : 3628 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : Micromax A089 ProdModel : Micromax A089 Device : A089 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 EXTRA : LCD [0] : otm8018b_wvga_dsi_vdo_ljj_6572 LCD [1] : ili9806e_wvga_dsi_vdo_s308_6572 LCD Res : 800x480 TOUCH [0] : ft6206 CAM [0] : gc2035_yuv CAM [1] : gc0308_yuv CAM [2] : gc0329_yuv CAM [3] : CAM [4] : s5k4ecgx_mipi_yuv s5k8aayx_yuv MODEM : s308_jb3_hspa LOCALE : en_US hi_IN hdpi Done! Elapsed: 00:00:12 Reconnect Power/Cable! Code: Operation : Read NVRAM [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 50 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D433034470206683E6A5197 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D433034470206683E6A5197 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E2C00000 [eMMC] : FLASH_UCP : 3628 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : Can't identify BB version! Read Ok, MT6572_eMMC.spnv saved Done! Elapsed: 00:00:26 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 50 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D433034470206683E6A5197 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D433034470206683E6A5197 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E2C00000 [eMMC] : FLASH_UCP : 3628 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Micromax ProdName : Micromax A089 ProdModel : Micromax A089 Device : A089 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_s308.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : bytcfg.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / s308 / EMMC FW Size : 682 MiB Scatter saved to : C:\Users\JeeT\Desktop\A089\MT6572__Micromax__Micromax A089__A089__4.2.2__ALPS.JB3.MP.V1\ All done! Done! Elapsed: 00:03:21 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 50 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D433034470206683E6A5197 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D433034470206683E6A5197 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E2C00000 [eMMC] : FLASH_UCP : 3628 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
The Following User Says Thank You to situ_saraf For This Useful Post: |
11-28-2015, 04:55 | #209 (permalink) |
Member: 442808 Status: Offline Thanks Meter: 195 | Intex Aqua Y2 Pro Sucessfully Read Pattern Lock. Code: Operation : Check / Read Info [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 50 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447583E4AD5DAB15B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447583E4AD5DAB15B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Intex ProdName : Aqua_Y2_Pro ProdModel : Aqua Y2 Pro Device : Aqua_Y2_Pro AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : Intex_Aqua_Y2_Pro_V08_Indian MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V43_1_wg_n EXTRA : LCD [0] : ili9806e_dsi_vdo LCD Res : 854x480 TOUCH [0] : ft6x06new TOUCH [1] : nt11004 TOUCH [2] : msg2133a CAM [0] : gc2145_yuv CAM [1] : nt99252_yuv CAM [2] : gc0329_yuv MODEM : wingtech72kk_wet_jb3_hspa_97055_band18_gps LOCALE : en_US hi_IN bn_IN gu_IN mr_IN pa_IN -sw600dp -sw720dp hdpi Done! Elapsed: 00:00:14 Reconnect Power/Cable! Code: Operation : Read NVRAM [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 50 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447583E4AD5DAB15B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447583E4AD5DAB15B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V43_1_wg_n Read Ok, MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V43_1_wg_n_eMMC.spnv saved Done! Elapsed: 00:00:24 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 50 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447583E4AD5DAB15B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447583E4AD5DAB15B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Intex ProdName : Aqua_Y2_Pro ProdModel : Aqua Y2 Pro Device : Aqua_Y2_Pro AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : Intex_Aqua_Y2_Pro_V08_Indian [Read Ok] : preloader_wt97057.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / wt97057 / EMMC FW Size : 705 MiB Scatter saved to : C:\Users\JeeT\Desktop\Y2 Pro\MT6572__Intex__Aqua Y2 Pro__Aqua_Y2_Pro__4.4.2__Intex_Aqua_Y2_Pro_V08_Indian\ All done! Done! Elapsed: 00:03:30 Reconnect Power/Cable! Code: Operation : Read PatternLock [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 50 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447583E4AD5DAB15B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447583E4AD5DAB15B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 1323 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 35789 Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
11-28-2015, 11:47 | #210 (permalink) | |
