Old 06-17-2014, 09:33   #16 (permalink)
Member: 739328
Thanks Meter: 26
Samsung i9300
Check / Read Info
Chinese Miracle II  [MTK module] v 0.02
Operation : Check / Read Info [ v0.02 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 22 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0000
BB_CPU_SN : 685527CD88535BBA57885208C3033890
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : C200 2500 3700 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00DC , [MX] MX25U6435E
[0] : FLASH_DIE : 00C2 0025 0037 0000
[0] : FLASH_LEN : 0x00800000
SDS : 0x00000000 , 0x00000000
Done!
Elapsed: 00:00:40
Reconnect Power/Cable!
Format FileSystem
Operation : Format FileSystem [ v0.02 ]
Wait for phone...
Phone found! [ 29 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x00750000-0x007FFFFF , LEN : 0x000B0000
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
Done!
Elapsed: 00:00:14
Repair Security
Operation : Repair Security [ v0.02 ]
Wait for phone...
Phone found! [ 29 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting Service Mode ...
Init Ok, waiting for phone ...
Phone Initial Info :
BB : MT6250
SW : R5001C_93_L2_V02
HW : RT50_6464_11B_HW
IMEI[1] : 352012080850018
IMEI[2] : 352012080850018
Update IMEI[1] to : 3556***********
Done!
Done!
Elapsed: 00:00:26
The Following 2 Users Say Thank You to desiderium82 For This Useful Post:
Old 06-17-2014, 10:35   #17 (permalink)
DUNIYA JAMAL's Avatar
Member: 192810
Sonork: Some people NEED change
Thanks Meter: 880
Qmobile E890 Repair Imei Done by Infinity Box
The Following 2 Users Say Thank You to DUNIYA JAMAL For This Useful Post:
Old 06-17-2014, 12:17   #18 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 934
Free File Sharing and Storage made Simple.
Old 06-17-2014, 12:20   #19 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 934
Old 06-17-2014, 12:44   #20 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 934
TECNO T342 BY INFINITYBOX
UL11_T342_PCB01_gprs_MT6260_S00.V08_M131126_UL11_T 342_MP
Old 06-17-2014, 12:49   #21 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 934
Old 06-17-2014, 12:52   #22 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 934
The Following User Says Thank You to Kirumira For This Useful Post:
Old 06-17-2014, 12:54   #23 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 934
PLEASE SOLVE THAT PROBLEM
Old 06-17-2014, 13:24   #24 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
1. I accept ONLY CM2MTK logs, other not interest for me at all.
2. Reset UserCode set it to Phone Default , and it can vary from 0000 , 1122, 1234 , 12345. Customer sure know it. If phone still ask code - repeat reset once more time and it must work.
Old 06-17-2014, 21:48   #25 (permalink)
Member: 205346
Thanks Meter: 26
Old 06-18-2014, 03:49   #26 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
Alcatel , like and Nokia, is protected and it not supported with CM2MTK module.
Old 06-18-2014, 04:33   #27 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,376
it is possible in future u add nokia alcatel zte etc in mtk module like u add samsung in spd module
Old 06-18-2014, 06:10   #28 (permalink)
Member: 1222089
Sonork: 100.1583019
Thanks Meter: 2,678
zte is not Protected . Should be Work . if you have zte with 652A or 6250 CPU with infinity box
Old 06-18-2014, 07:00   #29 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 13,794
Smile Qmobile g200 fully supported
READ INFO
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : DA7F1BD52799E12975FEB0D79492A96F
Setting...
BROM stage done
InitRes : 00000000
DEV[0] : C200 2500 3600 0000
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E
[0] : FLASH_DIE : 00C2 0025 0036 0000
[0] : FLASH_LEN : 0x00300000
Done!
Elapsed: 00:00:04
FORMAT
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Backup done
FAT_RANGE : 0x002B6000-0x002FFFFF , LEN : 0x0004A000
Done!
Elapsed: 00:00:12
RESET USER CODE
Operation : Reset UserCode [ v0.02 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Backup exists , skip
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:46
WRITE SECURITY
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB : MT6260
SW : R021_QMOBILE_V01.14_20131218
HW : R023_V01
IMEI[1] : 354485015672079
IMEI[2] : 354485015672079
Update IMEI[1] to : 359418050034447
Update IMEI[2] to : 359418050034439
Done!
Done!
Elapsed: 00:02:15
READ FLASH
Operation : Read Flash [ v0.02 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Read Flash now
Read Ok , 3145728 bytes read
Check and collect compile info
File_Info   : R021_QMOBILE_PCB01_gsm_MT6260_S00.R021_QMOBILE_V01_14_20131218.bin
FileVersion : R021_QMOBILE_V01.14_20131218
Saved to : C:\InfinityBox\CM2MTK\Read_out\R021_QMOBILE_PCB01_gsm_MT6260_S00.R021_QMOBILE_V01_14_20131218.bin
Done!
Elapsed: 00:00:19
WRITE FLASH
Load File
Load File
File_Info   : R021_QMOBILE_PCB01_gsm_MT6260_S00.R021_QMOBILE_V01_08_20130924.bin
FileVersion : R021_QMOBILE_V01.08_20130924
Load File Ok
Operation : Flash [ v0.02 ]
======= Flash
Files set for flashing :
[ MCU ] : qmobile g200 ok r021_qmobile_pcb01_gsm_mt6260_s00.r021_qmobile_v01_08_20130924.bin
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Erase region , wait ...
Write data , wait ...
Write : qmobile g200 ok r021_qmobile_pcb01_gsm_mt6260_s00.r021_qmobile_v01_08_20130924.bin
Done!
Elapsed: 00:00:55
http://forum.gsmhosting.com/vbb/f425...l#post10382734
The Following 5 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 06-18-2014, 07:06   #30 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
If will be phones - why not?
Will try. But will be great, if someone can make " list " with MTKx based phones, which are not supported by MModule.
Page generated in 0.41058 seconds with 8 queries
