Old 06-18-2014, 13:29   #31 (permalink)
ajaystarin's Avatar
Member: 173081
Sonork: 100.1621322
Thanks Meter: 225
Micromax X282 Format & Imei Repair Success
Format :-
IMEI Repair :-
Regards
Ajay Gupta
The Following 2 Users Say Thank You to ajaystarin For This Useful Post:
Old 06-18-2014, 16:49   #32 (permalink)
Member: 221872
Thanks Meter: 6
Operation : Format FileSystem [ v0.02 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 50 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0000
BB_CPU_SN : 3789BBEECFE7A62AC47733CBAA5508C6
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : C200 2500 3800 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G
[0] : FLASH_DIE : 00C2 0025 0038 0000
[0] : FLASH_LEN : 0x01000000
SDS : 0x00FF0000 , 0x00010000
Backup exists , skip
Executing FFS FORMAT now...
FAT_RANGE : 0x00900000-0x00FEFFFF , LEN : 0x006F0000
DA_RET : DA_IN_PROGRESS
0000000B
DA_RET : FORMAT_FAILED
Done!
Elapsed: 00:00:17
Reconnect Power/Cable!
zte g-r255 but the phone worked
The Following 2 Users Say Thank You to hilton For This Useful Post:
Old 06-19-2014, 05:47   #33 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 374
need mtk module stop and com port selector
Old 06-19-2014, 06:19   #34 (permalink)
ajaystarin's Avatar
Member: 173081
Sonork: 100.1621322
Thanks Meter: 225
Yxtel c900 format & imei repair success
YXTEL C900 FORMAT SUCCESS
PROBLEM IN HANDSET :- PHONE LOCK
FORMAT :-
IMEI REPAIR :-
FLASH FILE LINK (READ BY InfinityBox CM2MTK) :-
I READ THIS FILE AFTER FORMAT & IMEI REPAIR)
https://www.mediafire.com/?3hylodq5458nfo7
REGARDS
AJAY GUPTA
The Following User Says Thank You to ajaystarin For This Useful Post:
Old 06-19-2014, 09:19   #35 (permalink)
ZIYAAD STRYKER's Avatar
Member: 175945
Sonork: ziiyyaad
Thanks Meter: 697
wiko lubi2 log readed by another soft, does infinity mtk support this model thx?
Plug the USB cable into the powered off phone...
USB Modem Driver (COM116), Provider: Media Tek Inc., Driver ver.: 6.0.6000.16386, Date: 15/10/2008, USB\VID_0E8D&PID_0003&REV_0100
Baud rate: 19200
Release "Power on" button!
Baseband Processor:MT625A, HW Rev. A.01, SW Rev. 0.01
Serial number: 1C8495D4CBA1FACD
Testing external RAM...4 Mb
Detecting flash...SPI, ID: 00EF4016-00000000
Flash size: 4 Mb, block size: 4 Kb
File system: 236 Kb @ 002C5000
Firmware: TINNO50M_3232_11B_PCB01_gsm_MT6250_S00.B1080_MP_F2 F3F5F8_FR_06_11
Hardware IMEI: Not found
Old 06-19-2014, 12:08   #36 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 13,435
It should support, will try add other way of port detection in near version.
Old 06-19-2014, 12:38   #37 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 209
Yes, it will be released but some time later.
Old 06-19-2014, 13:28   #38 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 398
please add stop button in all mtk spd & mstar
Old 06-19-2014, 13:44   #39 (permalink)
ajaystarin's Avatar
Member: 173081
Sonork: 100.1621322
Thanks Meter: 225
Micromax x254 format & imei success
MICROMAX X254 FORMAT & IMEI SUCCESS
READ FLASH :-
FORMAT :-
IMEI REPAIR :-
FLASH FILE LINK ( READ BY InfinityBox CM2MTK) :-
https://www.mediafire.com/?n6lso2g0jod6coa
REGARDS
AJAY GUPTA
Old 06-19-2014, 13:58   #40 (permalink)
ajaystarin's Avatar
Member: 173081
Sonork: 100.1621322
Thanks Meter: 225
X258 format & imei success
X258 FORMAT & IMEI SUCCESS :-
FORMAT :-
IMEI REPAIR :-
https://www.mediafire.com/?37d3e836es8bfd0
REGARDS
AJAY GUPTA
Old 06-20-2014, 07:35   #41 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 13,795
Cool QMOBiLE E50 MTK 6260 FULLY SUPPORTED
QMOBiLE E50 FULLY SUPPORTED
READ INFO
Chinese Miracle II  [MTK module] v 0.02
Operation : Check / Read Info [ v0.02 ]
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : 0D596B10EFD6738D614BA64DB240E98C
Setting...
BROM stage done
InitRes : 00000000
DEV[0] : EF00 4000 1600 0000
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS : 0x003FE000 , 0x00002000
Done!
Elapsed: 00:00:09
RESET USER CODE
Operation : Reset UserCode [ v0.02 ]
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:12
FORMAT FS
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
FAT_RANGE : 0x003A4000-0x003FDFFF , LEN : 0x0005A000
DA_RET   : FORMAT_DONE
Done!
Elapsed: 00:00:14
READ FLASH
Operation : Read Flash [ v0.02 ]
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CA00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Read Flash now
Read Ok , 4194304 bytes read
Check and collect compile info
File_Info   : BESTONE60D_11B_PCB01_gsm_MT6260_S00.A8_D_YH_QMB_L2412_EUAP_V0_0_4.bin
FileVersion : A8_D_YH_QMB_L2412_EUAP_V0.0.4
Saved to : C:\InfinityBox\CM2MTK\Read_out\BESTONE60D_11B_PCB01_gsm_MT6260_S00.A8_D_YH_QMB_L2412_EUAP_V0_0_4.bin
Done!
Elapsed: 00:00:12
WRITE FLASH
Load File
Load File Ok
Operation : Flash [ v0.02 ]
======= Flash
Files set for flashing :
[ MCU ] : BESTONE60D_11B_PCB01_gsm_MT6260_S00.A8_D_YH_QMB_L2412_EUAP_V0_0_4.bin
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : 0000
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Erase region , wait ...
Write data , wait ...
Write : BESTONE60D_11B_PCB01_gsm_MT6260_S00.A8_D_YH_QMB_L2412_EUAP_V0_0_4.bin
Done!
Elapsed: 00:00:39
New firmware detected by akhtar ali jatt
The Following 5 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 06-20-2014, 07:55   #42 (permalink)
Member: 953334
Sonork: 100.1614005
Cool QMoBILE E4 MTK 625A FULLY SUPPORTED
READ iNFO
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : 962B77458E6ADB670E17882BC973DC5F
Setting...
BROM stage done
InitRes : 00000000
DEV[0] : C200 2500 3600 0000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E
[0] : FLASH_DIE : 00C2 0025 0036 0000
SDS : 0x00000000 , 0x00000000
Done!
Elapsed: 00:00:05
READ FLASH
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Read Flash now
File_Info   : WBG1307QM_0202_PCB01_gprs_MT6250_S00.1307QM_0202_V0770.bin
FileVersion : 1307QM_0202_V0770
Saved to : C:\InfinityBox\CM2MTK\Read_out\WBG1307QM_0202_PCB01_gprs_MT6250_S00.1307QM_0202_V0770.bin
Done!
Elapsed: 00:00:18
WRITE FLASH
======= Flash
[ MCU ] : WBG1307QM_0202_PCB01_gprs_MT6250_S00.1307QM_0202_V0770.bin
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : DONE
[ERROR] : DA_BLANK_FLASH
Write : WBG1307QM_0202_PCB01_gprs_MT6250_S00.1307QM_0202_V0770.bin
Done!
Elapsed: 00:00:26
Old 06-20-2014, 14:39   #43 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 1,656
LAVA KKT42
Wait for phone...
Phone found! [ 65 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : 676BEF1F99B44295A7DD2718058EE56B
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_LEN : 0x00300000
SDS : 0x002FE000 , 0x00002000
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
Done!
Elapsed: 00:00:09
IMEI REPAIR
Operation : Repair Security [ v0.02 ]
Wait for phone...
Phone found! [ 65 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting Service Mode ...
Init Ok, waiting for phone ...
Phone Initial Info :
BB : MT6260
SW : LAVA_KKT42_S108
HW : FARSIGHTED60M_BU1_11B_HW
IMEI[1] : 358688000000158
IMEI[2] : 359688000000159
Update IMEI[1] to : 91135885198****
Update IMEI[2] to : 91135885208****
Done!
Done!
Elapsed: 00:00:35
The Following User Says Thank You to VIJAY2U2 For This Useful Post:
Old 06-20-2014, 15:56   #44 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
@All
Please, try with v3 , if you have some problems with connecting or something like that :
Chinese Miracle-2 (Test Version) MTK/MediaTek v0.02 released
The Following User Says Thank You to Dzirt For This Useful Post:
Old 06-21-2014, 06:58   #45 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 939
FORMAT :-
IMEI REPAIR :-
REGARDS
AJAY GUPTA
Thanks but Upload flashfiles and phone images
Page generated in 0.47079 seconds with 8 queries
