06-21-2014, 15:47 | #46 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | YXTEL W666 DONE WITH CM2 MTKv03:- Code: Card found: S/N 0000:0000 Chinese Miracle II [MTK module] v 0.03 Start at : [6/21/2014 / 8:09:28 PM] Operation : Check / Read Info [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : C3DDBD999A4F9A6D3E0E21137346E43F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Done! Elapsed: 00:00:09 Reconnect Power/Cable! FORMAT Code: Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : C3DDBD999A4F9A6D3E0E21137346E43F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Backup FFS error! Executing FFS FORMAT now... FAT_RANGE : 0x003B1000-0x003FFFFF , LEN : 0x0004F000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:15 REPAIR SECURITY Code: Operation : Repair Security [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : C3DDBD999A4F9A6D3E0E21137346E43F BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6260 SW : E919YXAR111305301715 HW : 3232240320 IMEI[1] read error IMEI[2] info not exist Update IMEI[1] to : 351851053029196 Update IMEI[2] to : 351851053029204 Done! Done! Elapsed: 00:00:40 Reconnect Power/Cable! READ FLASH Code: Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : C3DDBD999A4F9A6D3E0E21137346E43F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : PCB01_MT6260_S00.E919YXAR113232240320ENARPSFRPTTHHIRUESMY1305301715..bin FileVersion : E919YXAR111305301715 Saved to : C:\InfinityBox\MTKTEST\V3\Read_out\PCB01_MT6260_S00.E919YXAR113232240320ENARPSFRPTTHHIRUESMY1305301715..bin Done! Elapsed: 00:00:15 Reconnect Power/Cable! WBR sahil2000ind Last edited by sahil2000ind; 06-21-2014 at 15:56. |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
06-21-2014, 17:52 | #47 (permalink) |
No Life Poster Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 117 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B34F43117A215B29D726229D7A8AD3A5 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00ED , [GigaDevice] GD25LQ64 [0] : FLASH_DIE : 00C8 0060 0017 0000 [0] : FLASH_LEN : 0x00800000 SDS : 0x00000000 , 0x00000000 Read Flash now Read Ok , 8388608 bytes read Check and collect compile info File_Info : CELLTEL50_11B_PCB01_gprs_MT6250_S00.WG12BRONDI_F22 0H_V06_20130624.bin FileVersion : WG12BRONDI_F220H_V06_20130624 Saved to : C:\InfinityBox\CM2MTK\Read_out\CELLTEL50_11B_PCB01 _gprs_MT6250_S00.WG12BRONDI_F220H_V06_20130624.bin Done! Elapsed: 00:00:29 Reconnect Power/Cable! Start at : [6/21/2014 / 6:29:15 PM] Operation : Repair Security [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 117 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B34F43117A215B29D726229D7A8AD3A5 BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6250 SW : WG12BRONDI_F220H_V06_20130624 HW : ER_GD25LQ64B_HX8347D_FM(MT6250)_GC2035_BT_4P IMEI[1] info not exist Update IMEI[1] to : 3532------- Done! Operation : Reset UserCode [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 117 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B34F43117A215B29D726229D7A8AD3A5 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00ED , [GigaDevice] GD25LQ64 [0] : FLASH_DIE : 00C8 0060 0017 0000 [0] : FLASH_LEN : 0x00800000 SDS : 0x00000000 , 0x00000000 Backup exists , skip Read ExtData Sorting ExtData Seems as code not set Break operation Done! Elapsed: 00:00:14 Reconnect Power/Cable! Last edited by -=MR_Gsm=-; 06-21-2014 at 17:57. |
The Following User Says Thank You to -=MR_Gsm=- For This Useful Post: |
06-22-2014, 08:53 | #48 (permalink) |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | micromax x328 read flash and format done format Last edited by .::TEJARAM::.; 06-22-2014 at 08:58. |
The Following 4 Users Say Thank You to .::TEJARAM::. For This Useful Post: |
06-22-2014, 11:33 | #49 (permalink) |
Major Poster Join Date: Dec 2012 Location: P@K!$T@N
Member: 1849288 Status: Offline Sonork: 100.1592356 Thanks Meter: 14 | Qmobile E10 MT6250 Qmobile E10 MT6250 Format Fs successfully Code: Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 26 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : FE25E2D20F66E1EF252DE90638C8C4F7 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00E00000-0x00FFFFFF , LEN : 0x00200000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to M ASIF S For This Useful Post: |
06-22-2014, 13:56 | #50 (permalink) |
Product Supporter Join Date: May 2010 Location: alwar, rajasthan (india)
Member: 1306196 Status: Offline Sonork: 100.1654602 Thanks Meter: 1,567 | m 5162 hang logo done other tool fail Card found: S/N 0DA8:0118 Chinese Miracle II [MTK module] v 0.02 Operation : Format FileSystem [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 16 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : FA612A880D85338D0211F259F87BA98F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x002BF000-0x002FFFFF , LEN : 0x00041000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! |
The Following 2 Users Say Thank You to vishnudatt For This Useful Post: |
06-22-2014, 16:53 | #51 (permalink) |
Freak Poster Join Date: Aug 2005 Location: India
Member: 173081 Status: Offline Thanks Meter: 352 | Gfive w1 (4 sim) read flash, format, imei rebuild success GFIVE W1 (4 SIM) READ FLASH, FORMAT, IMEI REBUILD SUCCESS :- READ FLASH :- FORMAT :- IMEI REBUILD :- FLASH FILE LINK (READ BY CM2MTK) :- https://forum.gsmhosting.com/vbb/****************************/?fnaldgpu2atcbrs Infinity Support team, plz also add 4th imei option in next update, as u provide 3 imei option in tool, which perfectly works, but i have to use another tool for 4th imei repair for this mobile. REGARDS AJAY GUPTA |
The Following 2 Users Say Thank You to ajaystarin For This Useful Post: |
06-23-2014, 04:29 | #52 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Oh, thanks for info , because I not seen any info about 4 imei phones. Will be added. |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
06-23-2014, 10:29 | #53 (permalink) |
Member: 173081 Status: Offline Thanks Meter: 352 | Lava discover 132 format failed LAVA DISCOVER 132 FORMAT FAILED, WHILE OTHER OPERATION LIKE IMEI REBUILD & FLASH READ SUCCESS :- FORMAT :- IMEI REBUILD :- READ FLASH :- FLASH FILE LINK (READ BY INFINITY CM2MTK) :- LAVA50_11B_PCB01_gprs_MT6250_S00.LAVA_DISCOVER132_ S316_20120506 REGARDS AJAY GUPTA |
The Following User Says Thank You to ajaystarin For This Useful Post: |
06-23-2014, 13:55 | #54 (permalink) |
Freak Poster Join Date: May 2008 Location: Bangladesh (Sezan point) Age: 43
Member: 772645 Status: Offline Sonork: 100.1591509 Thanks Meter: 176 | Symphony FT46 Full Read/Write flash success. Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 24 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 9E4A7AF5110960AD07F01C4B2E09F08D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00FFE000 , 0x00002000 Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : DEWAV60C_11B_G3368_PCB01_gprs_MT6260_S00.G3366_DG3 3662_SYMPHONY-FT46_L102.bin FileVersion : G3366_DG33662_SYMPHONY-FT46_L102 Saved to : C:\InfinityBox\CM2MTK\Read_out\DEWAV60C_11B_G3368_ PCB01_gprs_MT6260_S00.G3366_DG33662_SYMPHONY-FT46_L102.bin Done! Elapsed: 00:01:12 Reconnect Power/Cable! Operation : Flash [ v0.03 ] ======= Flash Files set for flashing : [ MCU ] : DEWAV60C_11B_G3368_PCB01_gprs_MT6260_S00.G3366_DG3 3662_SYMPHONY-FT46_L102.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 24 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : ED6E88C733690F2AE878469842738D99 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : DONE NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 [ERROR] : DA_BLANK_FLASH SDS : 0x00000000 , 0x00000000 Erase region , wait ... Write data , wait ... Write : DEWAV60C_11B_G3368_PCB01_gprs_MT6260_S00.G3366_DG3 3662_SYMPHONY-FT46_L102.bin Done! Elapsed: 00:02:07 Reconnect Power/Cable! Br, dreams_bd |
The Following User Says Thank You to dreams_bd For This Useful Post: |
06-23-2014, 14:04 | #55 (permalink) |
No Life Poster Join Date: Apr 2008 Location: IN MY PC
Member: 745721 Status: Offline Sonork: 100.1605292 Thanks Meter: 2,390 | symphony b2 sucsessfully flash Files set for flashing : [ MCU ] : b2.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 99 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : E4223F1FA0402A950964D8703ECB0C1B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Erase region , wait ... Write data , wait ... Write : b2.bin |
The Following User Says Thank You to R@jusat For This Useful Post: |
06-24-2014, 07:47 | #58 (permalink) |
No Life Poster Join Date: Feb 2012 Location: india (rajasthan) Age: 32
Member: 1719279 Status: Offline Thanks Meter: 140 | INFINITY IS POWRFULL TOOL VERY FAST REPAIR SPICE 5020 here is full logs chek info logs http://s30.postimg.org/8gd3wvh41/screenshot_22.png read flash file http://s30.postimg.org/fib1j2kpt/screenshot_21.png imei repair logs http://s30.postimg.org/e5tch6na9/screenshot_23.png |
The Following User Says Thank You to jitendramobile. For This Useful Post: |
06-24-2014, 12:54 | #59 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | KARBONN K75_New FORMAT OK Code: Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : A6A3A6C83D720AAD270E0E888895FB8B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00E50000-0x00FFFFFF , LEN : 0x001B0000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:26 Reconnect Power/Cable! IMEI ERROR Code: Operation : Repair Security [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : A6A3A6C83D720AAD270E0E888895FB8B BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
