07-03-2014, 09:51 | #92 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Code: rehmani;10414262]unable to reset privacy password in micromaxx x287 Operation : Reset UserCode [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 30FE127EACD66E57AD04DF76104A68DE BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Backup done Read ExtData Sorting ExtData Seems as code not set Break operation Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Reset UserCode [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 30FE127EACD66E57AD04DF76104A68DE BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Backup exists , skip Read ExtData Sorting ExtData Seems as code not set Break operation Done! Elapsed: 00:00:03 Reconnect Power/Cable! Operation : Reset UserCode [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 0000 BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MTxxx BB_CPU_SN : 30FE127EACD66E57AD04DF76104A68DE BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Elapsed: 00:00:03 Reconnect Power/Cable! Operation : Reset UserCode [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 30FE127EACD66E57AD04DF76104A68DE BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Backup exists , skip Read ExtData Sorting ExtData Seems as code not set Break operation Done! Elapsed: 00:00:08 Reconnect Power/Cable! read and format success Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 30FE127EACD66E57AD04DF76104A68DE BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : ZS626AA060_PCB01_gprs_MT6250_S00.ZS626AA_060A_V8_0_6.bin FileVersion : ZS626AA_060A_V8_0_6 Saved to : C:\InfinityBox\CM2MTK\Read_out\ZS626AA060_PCB01_gprs_MT6250_S00.ZS626AA_060A_V8_0_6.bin Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 30FE127EACD66E57AD04DF76104A68DE BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Backup exists , skip Executing FFS FORMAT now... FAT_RANGE : 0x003B5000-0x003FFFFF , LEN : 0x0004B000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:10 Reconnect Power/Cable! FLASH URE PHONE WITH THIS FILE WITH CM2MTK V0.03 100% PRIVACY PASSWORD WILL BE REMOVED ZS626AA060_PCB01_GPRS_MT6250_S00.ZS626AA_060A_V8_0 _6 - Download - 4shared - sahil roy WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
07-03-2014, 18:24 | #94 (permalink) |
No Life Poster Join Date: Mar 2006 Location: .:iTRi:.
Member: 240068 Status: Offline Thanks Meter: 201 | alcatel ot 1010x read info 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 53 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 27F792B694E99C19D6CF8367B5A72039 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... soft stop at sending da to traget |
The Following User Says Thank You to .:iTRi:. For This Useful Post: |
07-05-2014, 12:24 | #99 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | QMOBiLE E85 MTK 6260 FULLY SUPPORTED READ iNFO Code: Operation : Check / Read Info [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : A2F6B97C78A3C1A6D301A6A2099A9680 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Done! Elapsed: 00:00:09 Reconnect Power/Cable! READ FLASH Code: Chinese Miracle II [MTK module] v 0.03 Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : A2F6B97C78A3C1A6D301A6A2099A9680 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : ZS828PAA089_PCB01_gprs_MT6260_S00.ZS828PAA_089A_V8_0_9.bin FileVersion : ZS828PAA_089A_V8_0_9 Saved to : C:\InfinityBox\CM2MTK\Read_out\ZS828PAA089_PCB01_gprs_MT6260_S00.ZS828PAA_089A_V8_0_9.bin Done! Elapsed: 00:00:55 Reconnect Power/Cable! http://forum.gsmhosting.com/vbb/10418520-post34.html |
The Following 4 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
07-07-2014, 10:36 | #100 (permalink) |
Freak Poster Join Date: Apr 2010
Member: 1280685 Status: Offline Thanks Meter: 59 | MyPhone T29 TV Duo Check / Read Info Code: Start at : [7/7/2014 / 2:51:35 PM] Operation : Check / Read Info [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 39 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 2A1B602365DEEA141E32B0DE58124E02 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Done! Elapsed: 00:00:14 Reconnect Power/Cable! Finish at : [7/7/2014 / 2:51:50 PM] Code: Start at : [7/7/2014 / 2:52:14 PM] Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 39 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 2A1B602365DEEA141E32B0DE58124E02 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : TINNO50_6464_W1224_11B_PCB01_gprs_MT6250_S00.F5100A_T29TV_20121117_V12.bin FileVersion : F5100A_T29TV_20121117_V12 Saved to : C:\InfinityBox\CM2MTK\Read_out\TINNO50_6464_W1224_11B_PCB01_gprs_MT6250_S00.F5100A_T29TV_20121117_V12.bin Done! Elapsed: 00:00:48 Reconnect Power/Cable! Finish at : [7/7/2014 / 2:53:02 PM] |
The Following 2 Users Say Thank You to @ndoy For This Useful Post: |
07-07-2014, 16:26 | #101 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | VIdeocon V1585 Hang on Logo done (MT6260) Read Info Code: Operation : Check / Read Info [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 218 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 31B4950AF38CBDC1AADD41FBE60AC032 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00FF0000 , 0x00010000 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 218 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 31B4950AF38CBDC1AADD41FBE60AC032 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00FF0000 , 0x00010000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00E90000-0x00FEFFFF , LEN : 0x00160000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to himanshu taldar For This Useful Post: |
07-08-2014, 12:45 | #102 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Karbonn MT6260 phone read flash and user code done. Quote:
Siddeque. | |
The Following User Says Thank You to .:MobileLife:. For This Useful Post: |
07-08-2014, 16:37 | #103 (permalink) |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | q mobile M550 cannot format,read full flash done Card found: S/N Chinese Miracle II [MTK module] v 0.03 Operation : Check / Read Info [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Elapsed: 00:00:31 Reconnect Power/Cable! Operation : Check / Read Info [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Device boot not done Check Drivers Try again Boot Error! Elapsed: 00:00:40 Reconnect Power/Cable! Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Device boot not done Check Drivers Try again Boot Error! Elapsed: 00:00:40 Reconnect Power/Cable! Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Elapsed: 00:00:38 Reconnect Power/Cable! Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Device boot not done Check Drivers Try again Boot Error! Elapsed: 00:00:39 Reconnect Power/Cable! Operation : Check / Read Info [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : EFE4309866CA14164E664B0DBC51C3ED BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0x00 , Ver : 0.0 , BBID : 0x00 DA_CSTAT : 0x00 SOC_VERIFY : 0xDA BOOT_STYLE : FlashIc init failed! Error Code : Boot Error! Elapsed: 00:01:39 Reconnect Power/Cable! Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Initial Boot Failed (Sync Error) Boot Error! Elapsed: 00:00:00 Reconnect Power/Cable! Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : EFE4309866CA14164E664B0DBC51C3ED BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : LCSH60A_11B_PCB01_gprs_MT6260_S00.LGAEF10_11_32_1_ 1T04M1022_M001.bin FileVersion : LGAEF10.11.32.1.1T04M1022_M001 Saved to : C:\InfinityBox\CM2MTK\Read_out\LCSH60A_11B_PCB01_g prs_MT6260_S00.LGAEF10_11_32_1_1T04M1022_M001.bin Done! Elapsed: 00:01:29 Reconnect Power/Cable! Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : EFE4309866CA14164E664B0DBC51C3ED BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 0000 0000 0000 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0x00 , Ver : 0.0 , BBID : 0x00 DA_CSTAT : 0x00 SOC_VERIFY : 0xDA BOOT_STYLE : FlashIc init failed! Error Code : Boot Error! Elapsed: 00:02:06 Reconnect Power/Cable! |
The Following User Says Thank You to biochemistali For This Useful Post: |
07-08-2014, 16:46 | #104 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | and after many tries m550 format repair imei done. Card found: S/N Chinese Miracle II [MTK module] v 0.03 Operation : Check / Read Info [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Elapsed: 00:00:31 Reconnect Power/Cable! Operation : Check / Read Info [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Device boot not done Check Drivers Try again Boot Error! Elapsed: 00:00:40 Reconnect Power/Cable! Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Device boot not done Check Drivers Try again Boot Error! Elapsed: 00:00:40 Reconnect Power/Cable! Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Elapsed: 00:00:38 Reconnect Power/Cable! Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Device boot not done Check Drivers Try again Boot Error! Elapsed: 00:00:39 Reconnect Power/Cable! Operation : Check / Read Info [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : EFE4309866CA14164E664B0DBC51C3ED BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0x00 , Ver : 0.0 , BBID : 0x00 DA_CSTAT : 0x00 SOC_VERIFY : 0xDA BOOT_STYLE : FlashIc init failed! Error Code : Boot Error! Elapsed: 00:01:39 Reconnect Power/Cable! Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Initial Boot Failed (Sync Error) Boot Error! Elapsed: 00:00:00 Reconnect Power/Cable! Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : EFE4309866CA14164E664B0DBC51C3ED BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : LCSH60A_11B_PCB01_gprs_MT6260_S00.LGAEF10_11_32_1_ 1T04M1022_M001.bin FileVersion : LGAEF10.11.32.1.1T04M1022_M001 Saved to : C:\InfinityBox\CM2MTK\Read_out\LCSH60A_11B_PCB01_g prs_MT6260_S00.LGAEF10_11_32_1_1T04M1022_M001.bin Done! Elapsed: 00:01:29 Reconnect Power/Cable! Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : EFE4309866CA14164E664B0DBC51C3ED BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 0000 0000 0000 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0x00 , Ver : 0.0 , BBID : 0x00 DA_CSTAT : 0x00 SOC_VERIFY : 0xDA BOOT_STYLE : FlashIc init failed! Error Code : Boot Error! Elapsed: 00:02:06 Reconnect Power/Cable! Operation : Reset UserCode [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Device boot not done Check Drivers Try again Boot Error! Elapsed: 00:00:40 Reconnect Power/Cable! Operation : Reset UserCode [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : EFE4309866CA14164E664B0DBC51C3ED BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0x00 , Ver : 0.0 , BBID : 0x00 DA_CSTAT : 0x00 SOC_VERIFY : 0xDA BOOT_STYLE : FlashIc init failed! Error Code : Boot Error! Elapsed: 00:00:22 Reconnect Power/Cable! Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Initial Boot Failed (Sync Error) Boot Error! Elapsed: 00:00:00 Reconnect Power/Cable! Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : UNKNOW [ READ ERROR ] BROM Protocol Version : 00 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Device boot not done Check Drivers Try again Boot Error! Elapsed: 00:00:40 Reconnect Power/Cable! Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Initial Boot Failed (Sync Error) Boot Error! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : EFE4309866CA14164E664B0DBC51C3ED BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00E00000-0x00FFFFFF , LEN : 0x00200000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:30 Reconnect Power/Cable! Operation : Repair Security [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : EFE4309866CA14164E664B0DBC51C3ED BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6260 SW : LGAEF10.11.32.1.1T04M1022_M001 HW : LCSH60A_11B_HW IMEI[1] : 135790246811220 IMEI[2] : 358688000000158 Update IMEI[1] to : 342430087565558 Update IMEI[2] to : 342430087565566 Done! Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
07-09-2014, 13:45 | #105 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | HITECH H2i FORMAT Code: Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : F7406D871C0DD7EECDB1B4366A01CD4D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x003FE000 , 0x00002000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x003AF000-0x003FDFFF , LEN : 0x0004F000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:18 Reconnect Power/Cable! Code: Operation : Repair Security [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : F7406D871C0DD7EECDB1B4366A01CD4D BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6250 SW : S3_YHY01_P03_V0.3 HW : FARSIGHTED50D_3232_11B_HW IMEI[1] : 91131515000**** IMEI[2] : 91131515015**** Update IMEI[1] to : 91131875000**** Update IMEI[2] to : 91131875006**** Done! Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
