04-06-2014, 10:02 | #136 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Rokia r212 rda8851 16mb format done Code: Chinese Miracle II [RDA module] v 0.05 Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1800 FL_CNM : GigaDevice , GD25Q128 FL_CAP : 01000000 ==== Booting Sending RamRun Loader... Use : 8809_01000000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x00E00000 , Len : 0x001FC000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:05:28 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to saeedullah_khan For This Useful Post: |
04-07-2014, 08:38 | #137 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 (Test Version) v0.06 uploaded in support area: .Boot files updated .RDA 8852/CT1129 support: Read/Write/ReadCode/Format/IMEI .RDA 8853 support improved .User Code read for RDA8853/RDA8851 series revised .Format procedure revised .Firmware info detection improved .Flash Partition detection improved .Internal improvements |
The Following 5 Users Say Thank You to YellowBoss For This Useful Post: |
04-08-2014, 17:52 | #138 (permalink) |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | Nestel 112 read code done Card found: Chinese Miracle II [RDA module] v 0.06 Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : NVRAM Required data found, extracting code UserCode : 4342 Elapsed: 00:00:43 Done Reconnect Power/Cable! |
The Following 3 Users Say Thank You to sultan_ For This Useful Post: |
04-09-2014, 08:13 | #139 (permalink) | ||
No Life Poster Join Date: Apr 2004 Location: nagaur raj Age: 57
Member: 62820 Status: Offline Thanks Meter: 175 | kiano e4 kiano e4 read info Quote:
now my set ok | ||
The Following 3 Users Say Thank You to shantilal For This Useful Post: |
04-09-2014, 08:22 | #140 (permalink) | |
Member: 62820 Status: Offline Thanks Meter: 175 | kiano e5 after format set on another kiano e5 after format set on I try volcano , miracal and gpg but not success after one year my two kiano e4 and e5 after format set on Quote:
04-09-2014, 09:13 | #141 (permalink) | ||
Member: 62820 Status: Offline Thanks Meter: 175 | aphone dt-10 another success story with infinty coolsand read ok Quote:
04-09-2014, 09:48 | #142 (permalink) | |
Member: 62820 Status: Offline Thanks Meter: 175 | vellcom ve-o7 I want readed with infinity good flash file can't write readed with miracal box here is log Quote:
04-09-2014, 12:14 | #143 (permalink) |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | CoolSand Code readed smoothly done. Card found: S/N 9176:0118 Chinese Miracle II [RDA module] v 0.06 Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 6800 FL_CNM : GigaDevice , GD25 FL_CAP : 00000000 ==== Booting Sending RamRun Loader... Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! Reconnect Power/Cable! Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : VDS0 Item : NVRAM Required data found, extracting code UserCode : 5809 Elapsed: 00:00:55 Done Reconnect Power/Cable! BR. Siddeque. |
The Following User Says Thank You to .:MobileLife:. For This Useful Post: |
04-09-2014, 13:33 | #144 (permalink) | |
Member: 62820 Status: Offline Thanks Meter: 175 | mogli fox1 boot file not found cpu not supported Quote:
The Following User Says Thank You to shantilal For This Useful Post: |
04-09-2014, 14:17 | #145 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello , Quote:
This is connection problem. Try reconnect cable, then power. Press and hold power button until message "release button" appears. | |
The Following User Says Thank You to Dzirt For This Useful Post: |
04-09-2014, 14:27 | #146 (permalink) | |
Member: 62820 Status: Offline Thanks Meter: 175 | I think vellcom is cpu problum but mogli fox 1 is not show about rem in gpg it show 16mb Quote:
04-10-2014, 05:44 | #147 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | I will improve initial detection, but will be good try few time again - boot it or not if hold power button longer. |
