Old 04-06-2014, 10:02   #136 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
Rokia r212 rda8851 16mb format done
Chinese Miracle II  [RDA module] v 0.05
Operation : Format File System
Settings : SmartFormat is On
Com Port Opened
Press and hold POWER button!
Waiting phone
Init Ok
1st boot Ok
==== CPU
CPU_ID : 8809 , rev : 4006
CPU_CN : RDA Micro CT , RDA8851
==== FLASH
FL_VEN : 60C8 , rev : 1800
FL_CNM : GigaDevice , GD25Q128
FL_CAP : 01000000
==== Booting
Sending RamRun Loader...
Use : 8809_01000000.fp
Sending HdrConf ...
Sending LdrData ...
Loader sent, starting...
Loader run
Boot Ok
Release Power button!
Boot Done!
NVMFAT Area : 0x00E00000 , Len : 0x001FC000
Range as Factory Defined
Format User Area ...
CSD WR : 81C05C48 , 81C05C5C
CSD DR : A2000000 , A2008000 , A2010000
CSD MB : 00008000
Format Done
Elapsed: 00:05:28
Reconnect Power/Cable!
The Following 3 Users Say Thank You to saeedullah_khan For This Useful Post:
Old 04-07-2014, 08:38   #137 (permalink)
Member: 1043909
Thanks Meter: 60,926
Chinese Miracle-2 (Test Version) v0.06 uploaded in support area:
.Boot files updated
.RDA 8852/CT1129 support: Read/Write/ReadCode/Format/IMEI
.RDA 8853 support improved
.User Code read for RDA8853/RDA8851 series revised
.Format procedure revised
.Firmware info detection improved
.Flash Partition detection improved
.Internal improvements
The Following 5 Users Say Thank You to YellowBoss For This Useful Post:
Old 04-08-2014, 17:52   #138 (permalink)
sultan_'s Avatar
Member: 770299
Sonork: 100.1603105
Thanks Meter: 1,029
Nestel 112 read code done
Card found:
Chinese Miracle II [RDA module] v 0.06
Operation : Read User Code
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_VEN : 40C8 , rev : 1600
FL_CNM : GigaDevice , GD25Q32
FL_CAP : 00400000
==== Booting
Use : 8809_00400000.fp
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Read UDA now , wait ...
Read done, sorting EXTData
Following items found :
Item : NVRAM
Required data found, extracting code
UserCode : 4342
Elapsed: 00:00:43
Done
The Following 3 Users Say Thank You to sultan_ For This Useful Post:
Old 04-09-2014, 08:13   #139 (permalink)
shantilal's Avatar
Member: 62820
Thanks Meter: 175
kiano e4
kiano e4 read info
ettings : Read AllInfo is Off
Settings : Full Boot disabled by default
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
Current CPU is under test support!
Make 'FlashRead' before 'Format' or 'Flash Write' operations!
CPU_ID : 8806 , rev : 3000
CPU_CN : CoolSand CT , RDA8852
==== FLASH
FL_CAP : 00400000
==== Booting
Use : 8806_00400000.fp
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Elapsed: 00:00:05
Done
Finish at : [4/9/2014 / 12:13:19 PM]
read flash ok
Start at : [4/9/2014 / 12:13:27 PM]
Operation : Read FullFlash
======= Settings
Settings : SafeMode is Off [Fast]
Settings : Make IFF (MCU) file
Settings : Make Calibration file
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Read Flash now ...
Read Ok, 4194304 bytes read
Verify file...
Target BbCpu : CT1128
Target Flash : flsh_gd25q32
Project Name : test_version
Compile Date : 20111109Wed1708
[BIN] Saved as : test_version_CT1128_flsh_gd25q32.bin
Make FlashFiles
FATNV Check passed
FSCSC Check passed
CALIB Check passed
[IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\test_version_CT112 8_flsh_gd25q32.iff
[CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\test_version_CT112 8_flsh_gd25q32.ifc
Build done
Done
Elapsed: 00:19:11
Finish at : [4/9/2014 / 12:32:39 PM]
format done
now my set ok
The Following 3 Users Say Thank You to shantilal For This Useful Post:
Old 04-09-2014, 08:22   #140 (permalink)
shantilal's Avatar
Member: 62820
Thanks Meter: 175
kiano e5 after format set on
another kiano e5 after format set on
I try volcano , miracal and gpg but not success
after one year my two kiano e4 and e5 after format set on
Start at : [4/9/2014 / 12:32:49 PM]
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
NVMFAT Area : 0x003A0000 , Len : 0x0005C000
CSD WR : 81C06640 , 81C06654
CSD DR : A0000000 , A0008000 , A0010000
CSD MB : 00008000
Format Done
Elapsed: 00:01:13
Finish at : [4/9/2014 / 12:34:02 PM]
Old 04-09-2014, 09:13   #141 (permalink)
shantilal's Avatar
Member: 62820
Thanks Meter: 175
aphone dt-10
another success story with infinty coolsand
read ok
Start at : [4/9/2014 / 1:17:42 PM]
======= Settings
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
CPU_ID : 8809 , rev : 4005
CPU_CN : RDA Mirco CT , RDA8851
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Read Flash now ...
Verify file...
Target BbCpu : CT8851A
Target Flash : flsh_spi32m
Project Name : SW_62518M_32X16_V010_M50_HTX_QVGA_APHONE_EN_HIN
Project Info : 62518M_HTX_QVGA_APHONE
Compile Date : 20130313Wed0931
[BIN] Saved as : SW_62518M_32X16_V010_M50_HTX_QVGA_APHONE_EN_HIN_62 518M_HTX_QVGA_APHONE_CT8851A_flsh_spi32m.bin
Make FlashFiles
FATNV Check passed
FSCSC Check passed
CALIB Check passed
[IFF] File saved to : D:\InfinityBox\CM2RDA\Flash\IFF\SW_62518M_32X16_V0 10_M50_HTX_QVGA_APHONE_EN_HIN_62518M_HTX_QVGA_APHO NE_CT8851A_flsh_spi32m.iff
[CAL] File saved to : D:\InfinityBox\CM2RDA\Flash\IFF\SW_62518M_32X16_V0 10_M50_HTX_QVGA_APHONE_EN_HIN_62518M_HTX_QVGA_APHO NE_CT8851A_flsh_spi32m.ifc
Build done
Done
Elapsed: 00:18:07
Finish at : [4/9/2014 / 1:35:49 PM]
format done
Start at : [4/9/2014 / 1:36:13 PM]
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
CSD MB : 00008000
Format Done
Elapsed: 00:01:15
Finish at : [4/9/2014 / 1:37:28 PM]
I throw out infinty after update policy but now test rda good result
The Following 2 Users Say Thank You to shantilal For This Useful Post:
Old 04-09-2014, 09:48   #142 (permalink)
shantilal's Avatar
Member: 62820
Thanks Meter: 175
vellcom ve-o7
I want readed with infinity good flash file
can't write readed with miracal box
here is log
Load file...
BIN (MCU) : vell-com ve-07 flash file.bin
Project Name : C01F_WEK_V43_RDA8852D_ST3216_PCB10_QQVGA_MUL3_VELL COM_V01
Compile Date : 20120815Wed1427
Load Ok
Start at : [4/9/2014 / 2:15:38 PM]
Operation : Flash
======= Settings
Settings : BIN : NVwrite Disabled
Settings : Factory Settings Enabled
======= Flash
Files set for flashing :
[ MCU ] : vell-com ve-07 flash file.bin
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
CPU_ID : 8808 , rev : 7000
CPU_CN : CoolSand CT , RDA8853C
==== FLASH
FL_VEN : CB2C , rev : 1600
FL_CNM : Micron , N25W32
FL_CAP : 00400000
==== Booting
Use : 8808_00400000.fp
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
======= Flashing MCU
Processing file : vell-com ve-07 flash file.bin
CSD WR : 00000004 , 00000018
CSD DR : 00000000 , 00000000 , 00000000
CSD MB : 00000000
Error while prepare FlashInit, flashing failed!
Check Power, HW, try again
Error at : AD0006FF0300000000FC
Elapsed: 00:00:00
Finish at : [4/9/2014 / 2:15:44 PM]
thanks for advanced
Old 04-09-2014, 12:14   #143 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
CoolSand Code readed smoothly done.
Card found: S/N 9176:0118
Operation : Check Device / Info
======= Settings
Settings : Read AllInfo is Off
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_VEN : 40C8 , rev : 6800
FL_CAP : 00000000
==== Booting
Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support!
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Item : VDS0
Item : NVRAM
UserCode : 5809
Elapsed: 00:00:55
Done
BR.
Siddeque.
The Following User Says Thank You to .:MobileLife:. For This Useful Post:
Old 04-09-2014, 13:33   #144 (permalink)
shantilal's Avatar
Member: 62820
Thanks Meter: 175
mogli fox1
boot file not found cpu not supported
Start at : [4/9/2014 / 6:00:37 PM]
======= Settings
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_VEN : 0000 , rev : 0000
FL_CNM :
FL_CAP : 00000000
==== Booting
Finish at : [4/9/2014 / 6:00:40 PM]
The Following User Says Thank You to shantilal For This Useful Post:
Old 04-09-2014, 14:17   #145 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Hello ,
here is log
thanks for advanced
It is CPU problem , mostly need change it , register "freeze" and not allow write to phone anything. Try resolder/rehot , if no luck - change it to another one CPU and it will be ok.
This is connection problem.
Try reconnect cable, then power.
Press and hold power button until message "release button" appears.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 04-09-2014, 14:27   #146 (permalink)
shantilal's Avatar
Member: 62820
Thanks Meter: 175
I think vellcom is cpu problum but mogli fox 1 is not show about rem
in gpg it show 16mb
Originally Posted by Dzirt View Post
Hello ,
Old 04-10-2014, 05:44   #147 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
I will improve initial detection, but will be good try few time again - boot it or not if hold power button longer.
Old 04-10-2014, 10:34   #148 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
@Dzirt,
Sir, Waiting for Mstar, SPD update.
BR.
Siddeque
Old 04-10-2014, 11:01   #149 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Originally Posted by .:MobileLife:. View Post
@Dzirt,
BR.
Siddeque
I not have any MStar , need few samples.
Old 04-10-2014, 13:52   #150 (permalink)
Digital EDGE's Avatar
Member: 1240161
Thanks Meter: 159
Please add Chinese Miracle paid activation for BEST Dongle users.
Page generated in 0.32413 seconds with 9 queries
