Old 04-15-2014, 16:38   #166 (permalink)
sultan_'s Avatar
Member: 770299
Sonork: 100.1603105
Thanks Meter: 1,029
ANOKING x202 format done
Card found: S/N
Chinese Miracle II [RDA module] v 0.06
Operation : Format File System
Settings : SmartFormat is On
Com Port Opened
Press and hold POWER button!
Waiting phone
Init Ok
1st boot Ok
==== CPU
CPU_ID : 8809 , rev : 4005
CPU_CN : RDA Mirco CT , RDA8851
==== FLASH
FL_VEN : 40C8 , rev : 1600
FL_CNM : GigaDevice , GD25Q32
FL_CAP : 00400000
==== Booting
Sending RamRun Loader...
Use : 8809_00400000.fp
Sending HdrConf ...
Sending LdrData ...
Loader sent, starting...
Loader run
Boot Ok
Release Power button!
Boot Done!
NVMFAT Area : 0x003A0000 , Len : 0x0005C000
Range as Factory Defined
Format User Area ...
CSD WR : 81C05C48 , 81C05C5C
CSD DR : A2000000 , A2008000 , A2010000
CSD MB : 00008000
Format Done
Elapsed: 00:01:14
Reconnect Power/Cable!
COM2 : Open port failed!
The Following 2 Users Say Thank You to sultan_ For This Useful Post:
Old 04-16-2014, 17:34   #167 (permalink)
sultan_'s Avatar
Member: 770299
Sonork: 100.1603105
Thanks Meter: 1,029
CORN T20 dead recover by format
Card found: S/N
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
CPU_ID : 8809 , rev : 4006
CPU_CN : RDA Micro CT , RDA8851
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
CSD MB : 00008000
Format Done
Elapsed: 00:01:09
The Following User Says Thank You to sultan_ For This Useful Post:
Old 04-19-2014, 13:53   #168 (permalink)
pradyumnasahoo's Avatar
Member: 1267573
Thanks Meter: 144
x2 -00 read flash ,after read flashing ok but not power on ,plz give og flash file or any solucation plz help me............
Old 04-19-2014, 14:30   #169 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
So, for start - nee know phone info. After need try format FS. If still no luck - need try seek FW. So, lets start from logs.
Originally Posted by uvrajs View Post
in here shows CM2RRDA activated but the software not working it says u have to activate by online what can i do
Upgrade dongle FW.
Old 04-19-2014, 19:38   #170 (permalink)
chimed09's Avatar
Member: 479816
Thanks Meter: 851
Arrow nokia N200
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
CSD MB : 00008000
Format Done
Elapsed: 00:01:08
The Following 2 Users Say Thank You to chimed09 For This Useful Post:
Old 04-23-2014, 11:46   #171 (permalink)
shantilal's Avatar
Member: 62820
Thanks Meter: 175
vellcom v07
dead set I try three file after write this file set on but white display
rda 8851a ve-o7 full flash backup with1.8.5
Operation : Flash
======= Settings
Settings : BIN : NVwrite Enabled
Settings : Factory Settings Enabled
======= Flash
Files set for flashing :
[ MCU ] : rda 8851a ve-o7 full flash backup with1.8.5.bin
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_VEN : 60C8 , rev : 1600
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
======= Flashing MCU
Processing file : rda 8851a ve-o7 full flash backup with1.8.5.bin
CSD MB : 00008000
Flash Done
======= Setting Factory Defaults
Calculating new values...
CSD MB : 00008000
Format Done
Elapsed: 00:06:08
Finish at : [4/23/2014 / 4:03:36 PM]
Old 04-23-2014, 11:52   #172 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
CMRDA can determine file info, check it and try find something same.
Not need flash file for check, just open it via bin button and you will know it info.
Old 04-23-2014, 12:12   #173 (permalink)
shantilal's Avatar
Member: 62820
Thanks Meter: 175
I check file verson but cannot find v07 flash backup all file ve-07 8851 ,8852,8853 set on with 8851
Old 04-23-2014, 14:27   #174 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
So, need make thread with file request. Better with phone photo , because all current "chinese" tools users not know about correct file specify and else.
Old 04-24-2014, 05:22   #175 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
X6 Micro Phone (RDA 8851L)
Flash Read
Operation : Read FullFlash
======= Settings
Settings : SafeMode is Off [Fast]
Settings : Make IFF (MCU) file
Settings : Make Calibration file
Waiting phone ...
Connect battery, press and hold '0' button
Connect USB cable and keep hold button, until phone will be detected
Init  : 19C42A0C
Settings registers ...
1st boot Ok
==== CPU
CPU_ID : 8809 , rev : 4007
CPU_CN : RDA Micro CT , RDA8851L
==== FLASH
FL_CAP : 00400000
Initial : 81C0024C
==== Booting
Sending RamRun Loader ...
Use : 8809_00400000_usb.fp
Sending HdrConf ...
Sending LdrData ...
Flush : 0400F000
Loader run
Boot Done!
Read Flash now ...
Read Ok, 4194304 bytes read
Verify file...
Target BbCpu : CT8851C
Target Flash : flsh_spi32m
Project Name : EN_2013_10_11_V2
Project Info : mc609_8851c_baoma_a_gprs
Compile Date : 20131011Fri2055
[BIN] Saved as : EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.bin
Make FlashFiles
FATNV Check passed
FSCSC Check passed
CALIB Check passed
[IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.iff
[CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.ifc
Build done
Done
Elapsed: 00:00:20
Format
Waiting phone ...
Init  : 19C42A0C
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
Initial : 81C0024C
==== Booting
Sending HdrConf ...
Sending LdrData ...
Flush : 0400F000
Loader run
Boot Done!
CSD WR : 81C05CA8 , 81C05CBC
CSD MB : 00008000
Format Done
Elapsed: 00:00:25
Flashing
Load file...
IFF (MCU) : EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.iff
Load Ok
Load file...
IFC (CALIB) : EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.ifc
Load Ok
Operation : Flash
======= Settings
Settings : BIN : NVwrite Disabled
======= Flash
[ MCU ] : EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.iff
[ CFP ] : EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.ifc
Waiting phone ...
Init  : 19C42A0C
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
Initial : 81C0024C
==== Booting
Sending HdrConf ...
Sending LdrData ...
Flush : 0400F000
Loader run
Boot Done!
Processing file : EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.iff
CSD MB : 00008000
Flash Done
======= Flashing CFP
Processing file : EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.ifc
CSD MB : 00008000
Flash Done
CSD MB : 00008000
Format Done
Elapsed: 00:00:36
The Following 3 Users Say Thank You to Dzirt For This Useful Post:
Old 04-24-2014, 19:52   #176 (permalink)
Member: 130995
Thanks Meter: 35,227
We request all users to send GOOD WORKING flash files to [email protected] or upload somewhere and send to us links (or post links here).
We will check each file and later files will be uploaded in support area.
Old 04-26-2014, 06:41   #177 (permalink)
shantilal's Avatar
Member: 62820
Thanks Meter: 175
I send to 3file [email protected] 2good working and 1 network searching check
Old 04-26-2014, 08:45   #178 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
"Network Problem" phones only MCU is good , ifc file in 90% cases damaged.
Old 04-30-2014, 14:11   #179 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Thanks Infinitybox my
1- Question is What is the right Flash file iff format or bin format???
2-Can you flash a phone with a file read from another phone without sending to Infinity server for processing as it was???
Old 04-30-2014, 14:44   #180 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Hello.
1. IFF - it is prepared working MCU file. It can be used for : Repair/Upgrade SW WITHOUT destroy phone unique RF settings and security data. Also can be used BIN (fullflash) with right settings to preserve data (Skip NV/Misc)
IFC - RF settings. It saved also for repair purposes , for ex - write to another phone , but if it really need to do.
2. Sure! You have as readout : BIN , IFF and IFC. You can use any file, which you want now and here.
The Following 2 Users Say Thank You to Dzirt For This Useful Post:
Page generated in 0.28022 seconds with 9 queries
