04-15-2014, 16:38 | #166 (permalink) |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | ANOKING x202 format done Card found: S/N Chinese Miracle II [RDA module] v 0.06 Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:01:14 Reconnect Power/Cable! COM2 : Open port failed! |
The Following 2 Users Say Thank You to sultan_ For This Useful Post: |
04-16-2014, 17:34 | #167 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | CORN T20 dead recover by format Card found: S/N Chinese Miracle II [RDA module] v 0.06 Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:01:09 Reconnect Power/Cable! |
The Following User Says Thank You to sultan_ For This Useful Post: |
04-19-2014, 14:30 | #169 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Upgrade dongle FW. | |
04-19-2014, 19:38 | #170 (permalink) |
No Life Poster Join Date: Mar 2007 Location: TUNISIA Age: 41
Member: 479816 Status: Offline Thanks Meter: 851 | nokia N200 Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:01:08 Reconnect Power/Cable! |
04-23-2014, 11:46 | #171 (permalink) |
No Life Poster Join Date: Apr 2004 Location: nagaur raj Age: 57
Member: 62820 Status: Offline Thanks Meter: 175 | vellcom v07 dead set I try three file after write this file set on but white display rda 8851a ve-o7 full flash backup with1.8.5 Operation : Flash ======= Settings Settings : BIN : NVwrite Enabled Settings : Factory Settings Enabled ======= Flash Files set for flashing : [ MCU ] : rda 8851a ve-o7 full flash backup with1.8.5.bin Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! ======= Flashing MCU Processing file : rda 8851a ve-o7 full flash backup with1.8.5.bin CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Flash Done ======= Setting Factory Defaults Calculating new values... NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:06:08 Reconnect Power/Cable! Finish at : [4/23/2014 / 4:03:36 PM] |
04-23-2014, 11:52 | #172 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | CMRDA can determine file info, check it and try find something same. Not need flash file for check, just open it via bin button and you will know it info. |
04-23-2014, 14:27 | #174 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | So, need make thread with file request. Better with phone photo , because all current "chinese" tools users not know about correct file specify and else. |
04-24-2014, 05:22 | #175 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | X6 Micro Phone (RDA 8851L) Flash Read Code: Chinese Miracle II [RDA module] v 0.06 Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 19C42A0C Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4007 CPU_CN : RDA Micro CT , RDA8851L ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT8851C Target Flash : flsh_spi32m Project Name : EN_2013_10_11_V2 Project Info : mc609_8851c_baoma_a_gprs Compile Date : 20131011Fri2055 [BIN] Saved as : EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.iff [CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.ifc Build done Done Elapsed: 00:00:20 Reconnect Power/Cable! Code: Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 19C42A0C Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4007 CPU_CN : RDA Micro CT , RDA8851L ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05CA8 , 81C05CBC CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:00:25 Reconnect Power/Cable! Code: Load file... IFF (MCU) : EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.iff Target BbCpu : CT8851C Target Flash : flsh_spi32m Project Name : EN_2013_10_11_V2 Project Info : mc609_8851c_baoma_a_gprs Compile Date : 20131011Fri2055 Load Ok Load file... IFC (CALIB) : EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.ifc Load Ok Operation : Flash ======= Settings Settings : BIN : NVwrite Disabled Settings : Factory Settings Enabled ======= Flash Files set for flashing : [ MCU ] : EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.iff [ CFP ] : EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.ifc Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 19C42A0C Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4007 CPU_CN : RDA Micro CT , RDA8851L ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! ======= Flashing MCU Processing file : EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.iff CSD WR : 81C05CA8 , 81C05CBC CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Flash Done ======= Flashing CFP Processing file : EN_2013_10_11_V2_mc609_8851c_baoma_a_gprs_CT8851C_flsh_spi32m.ifc CSD WR : 81C05CA8 , 81C05CBC CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Flash Done ======= Setting Factory Defaults NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Format User Area ... CSD WR : 81C05CA8 , 81C05CBC CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:00:36 Reconnect Power/Cable! Last edited by Dzirt; 04-24-2014 at 05:28. |
The Following 3 Users Say Thank You to Dzirt For This Useful Post: |
04-24-2014, 19:52 | #176 (permalink) | |
We will check each file and later files will be uploaded in support area. | |
04-26-2014, 06:41 | #177 (permalink) |
Member: 62820 Status: Offline Thanks Meter: 175 | I send to 3file [email protected] 2good working and 1 network searching check |
04-30-2014, 14:11 | #179 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Thanks Infinitybox my 1- Question is What is the right Flash file iff format or bin format??? 2-Can you flash a phone with a file read from another phone without sending to Infinity server for processing as it was??? |
04-30-2014, 14:44 | #180 (permalink) | |
1. IFF - it is prepared working MCU file. It can be used for : Repair/Upgrade SW WITHOUT destroy phone unique RF settings and security data. Also can be used BIN (fullflash) with right settings to preserve data (Skip NV/Misc) IFC - RF settings. It saved also for repair purposes , for ex - write to another phone , but if it really need to do. 2. Sure! You have as readout : BIN , IFF and IFC. You can use any file, which you want now and here. | |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
