05-20-2014, 11:01 | #196 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | YESTEL LUMIA 630 FORMAT DONE Code: Card found: S/N 000000000 Chinese Miracle II [RDA module] v 0.06 Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x00700000 , Len : 0x000FC000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:02:50 Reconnect Power/Cable! |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
05-21-2014, 13:07 | #197 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | gfive u320 unlock done while gpg dragon and miracle box feiled to read correct password infinity done it Card found: S/N Chinese Miracle II [RDA module] v 0.06 Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Error on boot , check cable, try again Reconnect Power/Cable! Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Error on boot , Init Failed (Power Button release to early) Hold Power Button until 'Release button' message appear in log, try again Reconnect Power/Cable! Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Error on boot , Init Failed (Power Button release to early) Hold Power Button until 'Release button' message appear in log, try again Reconnect Power/Cable! Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : VDS0 Item : NVRAM Required data found, extracting code UserCode : 10000 Elapsed: 00:01:04 Done Reconnect Power/Cable! |
The Following User Says Thank You to rehmani For This Useful Post: |
05-21-2014, 15:02 | #198 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 672823 Status: Offline Thanks Meter: 6 | bocoin nokia 302 please help me in flash fille for bocoin nokia 302 dead after format her is log Start at : [20/05/2014 / 20:43:11] Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:01:11 Reconnect Power/Cable! |
05-23-2014, 05:11 | #201 (permalink) |
No Life Poster Join Date: Feb 2008 Location: ATI atheeq technical(srilanka)
Member: 709520 Status: Offline Thanks Meter: 275 | Card found: Chinese Miracle II [RDA module] v 0.06 Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : VDS0 Item : NVRAM Required data found, extracting code UserCode : 24278 Elapsed: 00:01:04 Done Reconnect Power/Cable! |
05-29-2014, 07:27 | #204 (permalink) |
Banned Join Date: Sep 2007
Member: 583468 Status: Offline Sonork: 100.1592004 Thanks Meter: 106 | Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT8851A Target Flash : flsh_spi32m Project Name : 2013032001 Project Info : X02A_3216_QQVGA_YINGPAIER Compile Date : 2013032001 [BIN] Saved as : 2013032001_X02A_3216_QQVGA_YINGPAIER_CT8851A_flsh_ spi32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\2013032001_X02A_32 16_QQVGA_YINGPAIER_CT8851A_flsh_spi32m.iff [CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\2013032001_X02A_32 16_QQVGA_YINGPAIER_CT8851A_flsh_spi32m.ifc Build done Done Elapsed: 00:18:14 Reconnect Power/Cable! Card found: S/N ****:**** Chinese Miracle II [RDA module] v 0.06 Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run InitERR : 00000001 Boot Error , check cable, HW Reconnect Power/Cable! Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT8851A Target Flash : flsh_spi32m Project Name : 2013032001 Project Info : X02A_3216_QQVGA_YINGPAIER Compile Date : 2013032001 [BIN] Saved as : 2013032001_X02A_3216_QQVGA_YINGPAIER_CT8851A_flsh_ spi32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\2013032001_X02A_32 16_QQVGA_YINGPAIER_CT8851A_flsh_spi32m.iff [CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\2013032001_X02A_32 16_QQVGA_YINGPAIER_CT8851A_flsh_spi32m.ifc Build done Done Elapsed: 00:18:14 Reconnect Power/Cable! Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:01:09 Reconnect Power/Cable! Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Elapsed: 00:00:04 Done Reconnect Power/Cable! Operation : Factory Area Rebuild [Repair IMEI] Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Factory Sector ... Read Ok , verify Detected 2 Sim Slot(s) Current Phone IMEI : IMEI1 : 352944042257025 IMEI2 : 352947042257036 New Phone IMEI : IMEI1 : 35294704225702-8 IMEI2 : 35294704225703-6 Build Factory Sector Write Factory Sector CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Verify Factory Sector Sector Verifyed! IMEI Write Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to jmzboudh For This Useful Post: |
05-29-2014, 13:00 | #205 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | GIVILL TOCH PROBLEM SOLVE BY FORMAT Code: Card found: S/N 0000:0000 Chinese Miracle II [RDA module] v 0.06 Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1800 FL_CNM : GigaDevice , GD25Q128 FL_CAP : 01000000 ==== Booting Sending RamRun Loader... Use : 8809_01000000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x00E00000 , Len : 0x001FC000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:06:24 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to VIJAY2U2 For This Useful Post: |
05-31-2014, 19:31 | #206 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 (Test Version) RDA/Coolsand v0.07 released .8808, 8806 Series support improved .Macronix Series FlashIC detection revised ."FactorySets" procedure after flash improved .Firmware info detection improved .Flash Partition detection improved ."Smart Format" improved .Boot procedure revised .Non-standard paged flash files writing supported .FactoryArea rebuild revised for 8806 series .User Code read improved for 8806 series |
06-01-2014, 15:48 | #207 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | YESTEL LUMIA 808 PROBLEM- TOCH ACTION- FORMAT Code: Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x00700000 , Len : 0x000FC000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:02:50 Reconnect Power/Cable! |
06-04-2014, 09:03 | #208 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | GI-VILL NEW FLASH ID FORMAT DONE Code: Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 25C2 , rev : 3800 FL_CNM : Macronix , MX25U128 FL_CAP : 01000000 ==== Booting Sending RamRun Loader... Set : 8809 , 01000000 Use : 8809_01000000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x00E00000 , Len : 0x001FC000 Recalculate Format Range Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:04:37 Reconnect Power/Cable! |
06-04-2014, 09:39 | #209 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Dynamic range and 16mb Macronix flash ic P.S. If possible, when you alive phones, readout flash from it via usb (because it fast) and sent us. It will help us in future work and making strong support file area. BR | |
06-04-2014, 13:51 | #210 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Hi Read done only 4 u take 1 hour bcz it have P12 connector so can't use usb Here it is -GVill_G808 - Download - 4shared Code: Card found: S/N 0000:0000 Chinese Miracle II [RDA module] v 0.07 Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 25C2 , rev : 3800 FL_CNM : Macronix , MX25U128 FL_CAP : 01000000 ==== Booting Sending RamRun Loader... Set : 8809 , 01000000 Use : 8809_01000000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Read Ok, 16777216 bytes read Verify file... Target BbCpu : CT8851E Target Flash : flsh_spi128m Project Name : R116_KSD_8851E_QVGA_PDA_12864_V8_8_2 Compile Date : 2013.01.26.18.09 [BIN] Saved as : R116_KSD_8851E_QVGA_PDA_12864_V8_8_2_CT8851E_flsh_spi128m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\R116_KSD_8851E_QVGA_PDA_12864_V8_8_2_CT8851E_flsh_spi128m.iff [CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\R116_KSD_8851E_QVGA_PDA_12864_V8_8_2_CT8851E_flsh_spi128m.ifc Build done Done Elapsed: 01:13:21 Reconnect Power/Cable! |
