Old 03-24-2014, 08:32   #31 (permalink)
ajaystarin's Avatar
Member: 173081
Sonork: 100.1621322
Thanks Meter: 220
Originally Posted by Dzirt View Post
ajaystarin , Thanks for test report! Please, upload Flash dump for further improvements
Here is Vell-com VE-1209 readed flash file,
https://www.mediafire.com/?0hb3to7zy5dc542
Regards
Ajay Gupta
Old 03-24-2014, 10:14   #32 (permalink)
Member: 1119248
Sonork: 000000000000000000000000
Thanks Meter: 128
CoolSand CT , RDA8853B (Iball I153) Read Write Done
Log's
Card found: S/N 5XXXXXX
Chinese Miracle II [RDA module] v 0.04
Start at : [3/24/2014 / 1:25:18 PM]
Operation : Read FullFlash
======= Settings
Settings : SafeMode is Off [Fast]
Settings : Make IFF (MCU) file
Settings : Make Calibration file
Com Port Opened
Press and hold POWER button!
Waiting phone
Init Ok
1st boot Ok
==== CPU
Current CPU is under test support!
Make 'FlashRead' before 'Format' or 'Flash Write' operations!
CPU_ID : 880A , rev : 7002
CPU_CN : CoolSand CT , RDA8853B
==== FLASH
FL_VEN : CB2C , rev : 1600
FL_CNM : Micron , N25W32
FL_CAP : 00400000
==== Booting
Sending RamRun Loader...
Use : 880A_00400000.fp
Sending HdrConf ...
Sending LdrData ...
Loader sent, starting...
Loader run
Boot Ok
Release Power button!
Boot Done!
Read Flash now ...
Read Ok, 4194304 bytes read
Verify file...
Target BbCpu : CT1128
Target Flash : flsh_spi32m
Project Name : test_version
Compile Date : 20121013Sat0920
[BIN] Saved as : test_version_CT1128_flsh_spi32m.bin
Make FlashFiles
FATNV Check passed
FSCSC Check passed
CALIB Check passed
[IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\test_version_CT112 8_flsh_spi32m.iff
[CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\test_version_CT112 8_flsh_spi32m.ifc
Build done
Done
Elapsed: 00:04:57
Finish at : [3/24/2014 / 1:30:16 PM]
Reconnect Power/Cable!
Start at : [3/24/2014 / 1:31:13 PM]
Operation : Read User Code
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Can't read required data from phone!
Seems as already erased NV
Finish at : [3/24/2014 / 1:31:26 PM]
Load file...
IFF (MCU) : test_version_CT1128_flsh_spi32m.iff
Load Ok
Start at : [3/24/2014 / 1:32:13 PM]
Operation : Flash
======= Settings
Settings : BIN : NVwrite Disabled
Settings : Factory Settings Enabled
======= Flash
Files set for flashing :
[ MCU ] : test_version_CT1128_flsh_spi32m.iff
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
======= Flashing MCU
Processing file : test_version_CT1128_flsh_spi32m.iff
CSD WR : 81C056FC , 81C05710
CSD DR : A0000000 , A0008000 , A0010000
CSD MB : 00008000
Flash Done
======= Setting Factory Defaults
Calculating new values...
NVMFAT Area : 0x003A0000 , Len : 0x0005C000
Format User Area ...
CSD MB : 00008000
Format Done
Elapsed: 00:04:56
Finish at : [3/24/2014 / 1:37:13 PM]
Old 03-24-2014, 10:26   #33 (permalink)
DUNIYA JAMAL's Avatar
Member: 192810
Sonork: Some people NEED change
Thanks Meter: 876
@Dzirt
First of all Thanks for the New update I want to know is it any solution "signal problem".
Its a common problem in RDA set.
Best Regards
Old 03-24-2014, 10:39   #34 (permalink)
Member: 572216
Thanks Meter: 3,613
Calme x200 rda8853b 4mb test report
READ INFO
Operation : Check Device / Info
======= Settings
Settings : Read AllInfo is On
Settings : Full Boot disabled by default
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Checking step 1, wait  ...
Checking step2, wait  ...
Elapsed: 00:00:18
Done
READ CODE but not show code
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
IMEI REPAIR
Operation : Factory Area Rebuild [Repair IMEI]
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Read Factory Sector ...
Read Ok , verify
Detected 2 Sim Slot(s)
Current Phone IMEI :
IMEI1 : 354758053241423
IMEI2 : 354758053241431
New Phone IMEI :
IMEI1 : 35020202185825-1
IMEI2 : 35218589969663-0
Build Factory Sector
Write Factory Sector
CSD MB : 00008000
Verify Factory Sector
Sector Verifyed! IMEI Write Done!
Elapsed: 00:00:13
READ FLASH
======= Settings
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Read Flash now ...
Verify file...
Project Name : C100B_DWS_X200_RDA8853AP_ST3216_PCB10_QCIF_S_ENG_PER_URD_CALME_YC_V02
Compile Date : 20121107Wed1130
[BIN] Saved as : C100B_DWS_X200_RDA8853AP_ST3216_PCB10_QCIF_S_ENG_PER_URD_CALME_YC_V02_CT1128_flsh_spi32m.bin
Make FlashFiles
FATNV Check passed
FSCSC Check passed
CALIB Check passed
[IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\C100B_DWS_X200_RDA8853AP_ST3216_PCB10_QCIF_S_ENG_PER_URD_CALME_YC_V02_CT1128_flsh_spi32m.iff
[CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\C100B_DWS_X200_RDA8853AP_ST3216_PCB10_QCIF_S_ENG_PER_URD_CALME_YC_V02_CT1128_flsh_spi32m.ifc
Build done
Done
Elapsed: 00:17:58
WRITE FLASH
Load file...
BIN (MCU) : C100B_DWS_X200_RDA8853AP_ST3216_PCB10_QCIF_S_ENG_PER_URD_CALME_YC_V02_CT1128_flsh_spi32m.bin
Load Ok
Operation : Flash
======= Settings
======= Flash
[ MCU ] : C100B_DWS_X200_RDA8853AP_ST3216_PCB10_QCIF_S_ENG_PER_URD_CALME_YC_V02_CT1128_flsh_spi32m.bin
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Processing file : C100B_DWS_X200_RDA8853AP_ST3216_PCB10_QCIF_S_ENG_PER_URD_CALME_YC_V02_CT1128_flsh_spi32m.bin
CSD MB : 00008000
Flash Done
CSD MB : 00008000
Format Done
Elapsed: 00:04:43
FORMAT
Operation : Format File System
Settings : SmartFormat is On
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Range as Factory Defined
CSD MB : 00008000
Format Done
Elapsed: 00:01:24
The Following 2 Users Say Thank You to saeedullah_khan For This Useful Post:
Old 03-24-2014, 11:07   #35 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,156
Originally Posted by DUNIYA JAMAL View Post
@Dzirt
Best Regards
Hello.
If you have 2-3 samples with such problem and can sell them us - yes. I now finish CALIB rebuild on 15-20% , still to much work and need alive samples with signal problem.
Originally Posted by saeedullah_khan View Post
READ INFO
Hello, yeah, will not show, because not have them. Please, accept in mobile 8 digit code , read fullflash and send me link. I plan add Read Code from FATNV for RDA 8853 in next update , but need more material for make it fully.
Old 03-24-2014, 11:23   #36 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,156
So called "new" RDA 8809 4007
 ======= Settings
 Settings : Read AllInfo is Off
 Com Port Opened
 Waiting phone
 Init Ok
 1st boot Ok
 ==== CPU
 CPU_ID : 8809 , rev : 4007
 CPU_CN : RDA Micro CT , RDA8851
 ==== FLASH
 FL_VEN : 60C8 , rev : 1600
 FL_CNM : GigaDevice , GD25Q32
 FL_CAP : 00400000
 ==== Booting
 Use : 8809_00400000.fp
 Sending HdrConf ...
 Sending LdrData ...
 Loader run
 Boot Ok
 Boot Done!
 Elapsed: 00:00:08
 Done
 ======= Settings
 Com Port Opened
 Waiting phone
 Init Ok
 1st boot Ok
 ==== CPU
 ==== FLASH
 FL_CAP : 00400000
 ==== Booting
 Sending HdrConf ...
 Sending LdrData ...
 Loader run
 Boot Ok
 Boot Done!
 Read Flash now ...
 Verify file...
 Target BbCpu : CT8851C
 Project Info : 8851C_NXD_W888
 Compile Date : 20130928Sat1518
 Con't collect Project Info , saving as default
 Saved as : 88094007_00400000.bin
 Done
 Elapsed: 00:17:52
Test has been done with first beta , so, now it support more well
Old 03-24-2014, 11:55   #37 (permalink)
sultan_'s Avatar
Member: 770299
Sonork: 100.1603105
Thanks Meter: 1,015
K mobile K828 reed code ok
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
CPU_ID : 8809 , rev : 4006
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Read done, sorting EXTData
Following items found :
Item : NVRAM
Required data found, extracting code
UserCode : 1234
Elapsed: 00:00:49
Done
Old 03-24-2014, 12:07   #38 (permalink)
Member: 572216
Thanks Meter: 3,613
@Dzirt
i set password on mobile 8 digit code and read for you
Calme x200 rda8853b - Download - 4shared
Old 03-24-2014, 12:18   #39 (permalink)
sultan_'s Avatar
Member: 770299
Sonork: 100.1603105
Thanks Meter: 1,015
Appo X777 formate done with infinity box
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
CPU_ID : 8809 , rev : 4005
CPU_CN : RDA Mirco CT , RDA8851
==== FLASH
FL_VEN : 40C8 , rev : 1600
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
CSD WR : 81C05C48 , 81C05C5C
CSD DR : A2000000 , A2008000 , A2010000
CSD MB : 00008000
Format Done
Elapsed: 00:01:08
Old 03-24-2014, 12:21   #40 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 33,232
@Dzirt
Hello,
What is that code ?
Old 03-24-2014, 12:31   #41 (permalink)
Member: 2084844
Sonork: 100.1611742
Thanks Meter: 14
Chines by2 s303 format sucess in infinity cm2
READ INFO
======= Settings
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Elapsed: 00:00:07
Done
FORMAT
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
CSD MB : 00008000
Format Done
Elapsed: 00:01:07
Old 03-24-2014, 12:32   #42 (permalink)
Member: 572216
Thanks Meter: 3,613
Originally Posted by InfinitySupport View Post
Hello,
What is that code ?
i set code 88888888 then read flash file
Old 03-24-2014, 13:02   #43 (permalink)
vampire13's Avatar
Member: 246444
Thanks Meter: 120
mito 260 can't open sms menu done with format
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
CSD MB : 00008000
Format Done
Elapsed: 00:01:08
Old 03-24-2014, 13:20   #44 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,156
Hello,
What is that code ?
I know it
All done for code reading for 8853 , thanks for material
The Following User Says Thank You to Dzirt For This Useful Post:
Old 03-24-2014, 14:03   #45 (permalink)
jhames47's Avatar
Member: 895644
Sonork: 098765
Thanks Meter: 134
how about mt625a cpu
Page generated in 0.44269 seconds with 8 queries
