03-29-2014, 10:54 | #91 (permalink) |
No Life Poster Join Date: Jan 2011 Location: ISLD
Member: 1489021 Status: Offline Sonork: 100.1620946 Thanks Meter: 831 | Card found: S/N 7209:0118 Chinese Miracle II [RDA module] v 0.05 Operation : Read User Code Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Phone not found Operation : Read User Code Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Phone not found Operation : Read User Code Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 55555555 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! Read done, sorting EXTData Following items found : Item : VDS0 Item : CSW Item : VDS1 Item : NVRAM Required data found, extracting code UserCode : 1234 Elapsed: 00:00:20 Done Reconnect Power/Cable! Last edited by ihsan.khan.gsm; 03-29-2014 at 11:02. |
The Following 3 Users Say Thank You to ihsan.khan.gsm For This Useful Post: |
03-29-2014, 11:03 | #92 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
03-29-2014, 11:13 | #93 (permalink) |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,030 | Yestel asha308 hang done with format Card found: S/N Chinese Miracle II [RDA module] v 0.05 Operation : Format File System Settings : SmartFormat is Off Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x00700000 , Len : 0x000FC000 Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:02:38 Reconnect Power/Cable! |
The Following User Says Thank You to sultan_ For This Useful Post: |
03-29-2014, 12:33 | #94 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,030 | |
03-29-2014, 12:43 | #95 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,030 | Yestel 308 write ime done Card found: S/N Chinese Miracle II [RDA module] v 0.05 Operation : Factory Area Rebuild [Repair IMEI] Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Factory Sector ... Read Ok , verify Detected 2 Sim Slot(s) Current Phone IMEI : IMEI1 : 000000000000000 IMEI2 : 000000000000000 New Phone IMEI : IMEI1 : 35498434984136-8 IMEI2 : 35494815679846-6 Build Factory Sector Write Factory Sector CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Verify Factory Sector Sector Verify Error! Reconnect power and try again! Elapsed: 00:00:12 Reconnect Power/Cable! |
03-29-2014, 13:18 | #96 (permalink) | |
03-29-2014, 15:05 | #101 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,030 | How to Activate Chinese Miracle-2 (Test Version) software (for FREE) for Main Infinity-Box: 1. Login to your Infinity Online Service (IOS) account: Infinity-Box - Online Service 2. Go to "Products" menu 3. Select "Software activations" item 4. Select "Chinese Miracle-2 (Test Version) software activation for Main Infinity-Box" 5. Click to "Buy" button 6. You will see a confirmation and Activation status 7. Follow by given instruction and update your Smart-Card firmware - Smart-Card Update Manual 8. Now you can use new software |
03-29-2014, 16:42 | #102 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,030 | MTK m500 read code done Card found: S/N Chinese Miracle II [RDA module] v 0.05 Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read done, sorting EXTData Following items found : Item : NVRAM Required data found, extracting code UserCode : 3333 Elapsed: 00:00:52 Done Reconnect Power/Cable! |
The Following 2 Users Say Thank You to sultan_ For This Useful Post: |
03-29-2014, 16:50 | #103 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,030 | MTK model 206 repair ime done Card found: S/N Chinese Miracle II [RDA module] v 0.05 Operation : Factory Area Rebuild [Repair IMEI] Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Factory Sector ... Read Ok , verify Detected 2 Sim Slot(s) Current Phone IMEI : IMEI1 : 354685643165468 IMEI2 : 354697564312649 New Phone IMEI : IMEI1 : 35618305839022-4 IMEI2 : 35618305869022-7 Build Factory Sector Write Factory Sector CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Verify Factory Sector Sector Verifyed! IMEI Write Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
