04-29-2014, 17:02 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 (Test Version) Reports: SPD/Spreadtrum Please, post here your test reports with Chinese Miracle-2 (Test Version) SPD/Spreadtrum software. This software is a Test Version so always make a backup before any operation ! How to Download and Activate Chinese Miracle-2 (Test Version) software (for FREE) for Main Infinity-Box: http://forum.gsmhosting.com/vbb/f296...ocess-1867818/ Updates and support for SPD/Sreadtrum software: 1. Where to send flash files and links: [email protected] 2. If you have any SPD CPU based phone and want to see it supported - post here your request. 3. If you have any SPD CPU based phone with some kind of software damage/problem - post here your questions and we will try to adjust our software to fix that problems. 4. We need new phone samples for research: http://forum.gsmhosting.com/vbb/f296...earch-1786726/ Last edited by YellowBoss; 10-12-2014 at 07:26. |
The Following 55 Users Say Thank You to YellowBoss For This Useful Post: |
04-29-2014, 17:55 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: LOVE A L L AH LOVE ALQURAN
Member: 754324 Status: Offline Sonork: LOVE MOHAMMAD (S.A.W) Thanks Meter: 500 | 1st i9500 spd 6531 flash done Card found: S/N xxxxxxxxxx Chinese Miracle II [SPD module] v 0.02 FastCheck : SPD65xx Load file... Platform : MOCOR_12B_6531.W13.07_Release Project : J6501 272X480 HWInfo : SC6531_PDA Compile : 11-23-2013 15:56:19 Load Ok Operation : Flash ======= Flash Files set for flashing : [ MCU ] : MOCOR_12B_6531.W13.07_Release_20140426_175308_Full Flash.bin 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 299 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0018 0000 Flash VEN : GigaDevice , GD25LQ128 Flash CAP : 01000000 ======= Flashing MCU Mapping file ... Mapping done Processing file : MOCOR_12B_6531.W13.07_Release_20140426_175308_Full Flash.bin Init ok, send data Flashing Done! Info : In some cases after flash required make "Format Fs / Reset Phone" Done! Elapsed: 00:05:03 Reconnect Power/Cable! |
The Following 14 Users Say Thank You to ABDULMANAN For This Useful Post: |
04-29-2014, 17:56 | #3 (permalink) |
The Following 3 Users Say Thank You to ABDULMANAN For This Useful Post: |
04-29-2014, 18:11 | #4 (permalink) |
No Life Poster Join Date: Oct 2007 Location: pakistan
Member: 601913 Status: Offline Sonork: 100.1597350 Thanks Meter: 658 | @ABDULMANAN good test report but what is the result after flash ur phone repaired successfully or not ? |
The Following User Says Thank You to r-jcomm For This Useful Post: |
04-29-2014, 22:22 | #5 (permalink) |
Major Poster Join Date: Apr 2008 Location: Nicaragua
Member: 743172 Status: Offline Sonork: hjjert Thanks Meter: 6 | Start at : [29/04/2014 / 02:50:27 p.m.] Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 53 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD 25LQ32.bin Done! Elapsed: 00:00:38 ************************************************** ************* perfect full flash read ************************************************** ************** sucessfull flash back up ======= Flash Files set for flashing : [ MCU ] : SPD6531_00400000_GD25LQ32.bin 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 53 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 ======= Flashing MCU Mapping file ... Mapping done Processing file : SPD6531_00400000_GD25LQ32.bin Init ok, send data Flashing Done! Info : In some cases after flash required make "Format Fs / Reset Phone" Done! Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 53 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! *************************************** sucessfull format wow model tested gomobile 177 movistar Nicaragua |
04-30-2014, 02:30 | #6 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | BM50 , over COM , SPD6530 Read Flash Code: Operation : Read FullFlash Connect Powered Off phone. Insert battery ( If not used VPP ) ==== Wait for phone... Port Opened Wait for phone ... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info Saved to : C:\Infinity Box\CM2SPD\Read_out\SPD6530_00400000_GD25LQ32_2.bin Done! Elapsed: 00:01:25 Reconnect Power/Cable! Code: FastCheck : SPD65xx Load file... Not found any ExtInfo data (Compressed already) Load Ok Operation : Flash ======= Flash Files set for flashing : [ MCU ] : SPD6530_00400000_GD25LQ32.bin Connect Powered Off phone. Insert battery ( If not used VPP ) ==== Wait for phone... Port Opened Wait for phone ... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 ======= Flashing MCU Mapping file ... Mapping done Processing file : SPD6530_00400000_GD25LQ32.bin Init ok, send data Flashing Done! Info : In some cases after flash required make "Format Fs / Reset Phone" Done! Elapsed: 00:01:48 Reconnect Power/Cable! Code: Operation : Format File System Settings : SmartFormat is On Connect Powered Off phone. Insert battery ( If not used VPP ) ==== Wait for phone... Port Opened Wait for phone ... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:17 Reconnect Power/Cable! Code: Operation : Check/Read Info Connect Powered Off phone. Insert battery ( If not used VPP ) ==== Wait for phone... Port Opened Wait for phone ... Ack Ok! InitSvc Done Phone Initial Info : Platform : MOCOR_12C.W13.04.05_Debug ExtInfo : YZ18P_B185_32X32_160X128BAR_MEnRu Project : BM50_YZ18_B185_160X128_DUAL_MEnRuV01.01B03-P HWInfo : fp6500_bar Compile : 09-18-2013 14:43:21 Phone Security Info : IMEI [1] : 355347056333798 IMEI [2] : 355347056333806 BT_ADDR : 598908095927 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Code: Operation : Repair Security Connect Powered Off phone. Insert battery ( If not used VPP ) ==== Wait for phone... Port Opened Wait for phone ... Ack Ok! InitSvc Done Phone Initial Info : Platform : MOCOR_12C.W13.04.05_Debug ExtInfo : YZ18P_B185_32X32_160X128BAR_MEnRu Project : BM50_YZ18_B185_160X128_DUAL_MEnRuV01.01B03-P HWInfo : fp6500_bar Compile : 09-18-2013 14:43:21 Phone Security Info : IMEI [1] : 355347056333798 IMEI [2] : 355347056333806 BT_ADDR : 598908095927 Read Ok! Write new security data : IMEI1 : 355347056333889 IMEI2 : 355347056333897 Write done! Elapsed: 00:00:11 Reconnect Power/Cable! Code: Operation : Check/Read Info Connect Powered Off phone. Insert battery ( If not used VPP ) ==== Wait for phone... Port Opened Wait for phone ... Ack Ok! InitSvc Done Phone Initial Info : Platform : MOCOR_12C.W13.04.05_Debug ExtInfo : YZ18P_B185_32X32_160X128BAR_MEnRu Project : BM50_YZ18_B185_160X128_DUAL_MEnRuV01.01B03-P HWInfo : fp6500_bar Compile : 09-18-2013 14:43:21 Phone Security Info : IMEI [1] : 355347056333889 IMEI [2] : 355347056333897 BT_ADDR : 598908095927 Done! Elapsed: 00:00:07 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to Dzirt For This Useful Post: |
04-30-2014, 02:34 | #7 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Micromax X267 , USB , SPD6531 Check Code: Operation : Check/Read Info 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 68 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Code: Operation : Read User Code 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 68 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Check data... Can take some time User Code : 15253545 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Code: Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 68 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info ExtInfo : GST_SP27D_X267_M12_3232_ER_V08_20131111 Project : SC6531_BAR HWInfo : SC6531_BAR Compile : 11-11-2013 15:03:19 Saved to : C:\Infinity Box\CM2SPD\Read_out\SPD6531_00400000_GST_SP27D_X267_M12_3232_ER_V08_20131111_11112013150319.bin Done! Elapsed: 00:00:23 Reconnect Power/Cable! Code: Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 68 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:08 Reconnect Power/Cable! Code: FastCheck : SPD65xx Load file... ExtInfo : GST_SP27D_X267_M12_3232_ER_V08_20131111 Project : SC6531_BAR HWInfo : SC6531_BAR Compile : 11-11-2013 15:03:19 Load Ok Operation : Flash ======= Flash Files set for flashing : [ MCU ] : SPD6531_00400000_GST_SP27D_X267_M12_3232_ER_V08_20131111_11112013150319.bin 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 68 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 ======= Flashing MCU Mapping file ... Mapping done Processing file : SPD6531_00400000_GST_SP27D_X267_M12_3232_ER_V08_20131111_11112013150319.bin Init ok, send data Flashing Done! Info : In some cases after flash required make "Format Fs / Reset Phone" Done! Elapsed: 00:01:04 Reconnect Power/Cable! Code: Operation : Check/Read Info 1. Insert USB cable ( Use adapter or special cable ) 2. Insert battery 3. If boot not start - press 'Power' button shortly ==== Wait for phone... Phone found! [ 68 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : ExtInfo : GST_SP27D_X267_M12_3232_ER_V08_20131111 Project : SC6531_BAR HWInfo : SC6531_BAR Compile : 11-11-2013 15:03:19 Phone Security Info : IMEI [1] : 911330754730330 IMEI [2] : 911330754730348 BT_ADDR : 584B6BA192C6 Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
04-30-2014, 06:06 | #13 (permalink) | |||
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | Cherry mobile t19 Cherry mobile t19 phone status dead read in boot Quote:
