04-30-2014, 11:41 | #33 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Got, check. It seems interest. I found only 1234 code, nothing more. Continue checking. Sure, we work step-by-step. |
The Following 4 Users Say Thank You to Dzirt For This Useful Post: |
04-30-2014, 15:13 | #36 (permalink) | ||
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan
Member: 2138570 Status: Offline Sonork: 100.1611495 Thanks Meter: 301 | B-Fly model-B4 killed by volcano box by reading only info revived by CM-2_spd by reading file from same working phone read full flash Quote:
full flash Quote:
The Following User Says Thank You to Ismail khan1978 For This Useful Post: |
04-30-2014, 17:00 | #37 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2159186 Status: Offline Thanks Meter: 3 | smart s-400 unlock done ...... smart s-400 unlock done try gpgdragon not ok try volcono not ok try Infinity-Box 100% ok thanksss sir nice work........................................... |
04-30-2014, 17:29 | #40 (permalink) | |
No Life Poster Join Date: Jan 2011 Location: ISLD
Member: 1489021 Status: Offline Sonork: 100.1620946 Thanks Meter: 831 | Quote:
im so sory for post at wrong place im just aware him ,he is member each like team where are alraedy add in alot of tool but still not working well any way delete my post | |
04-30-2014, 17:31 | #41 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Chinese "I9300 Samsung" SPD6530 Read USerCode Code: Card found: S/N CB41:0126 Chinese Miracle II [SPD module] v 0.03 Operation : Read User Code 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 68 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 Flash DIE : 00C8 0060 0018 0000 Flash VEN : GigaDevice , GD25LQ128 Flash CAP : 01000000 Check data... Can take some time User Code : 552239 Done! Elapsed: 00:00:16 Reconnect Power/Cable! Format Code: Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 68 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 Flash DIE : 00C8 0060 0018 0000 Flash VEN : GigaDevice , GD25LQ128 Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
04-30-2014, 17:38 | #42 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Chinese "I9500 Samsung" SPD6531 Read UserCode Code: Operation : Read User Code 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 68 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0060 0017 0000 Flash VEN : Winbond , W25Q64 Flash CAP : 00800000 Check data... Can take some time User Code : 1234 Done! Elapsed: 00:00:17 Reconnect Power/Cable! Code: Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 68 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0060 0017 0000 Flash VEN : Winbond , W25Q64 Flash CAP : 00800000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
05-01-2014, 09:44 | #44 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Micromax X084 Flash Format Done Read Flash !! Code: Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32.bin Done! Elapsed: 00:00:54 Reconnect Power/Cable! Code: Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:14 Reconnect Power/Cable! Code: Operation : Read User Code 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Check data... Can take some time User Code : 2525 Done! Elapsed: 00:00:11 Code: FastCheck : SPD65xx Load file... Not found any ExtInfo data (Compressed already) Load Ok Operation : Flash ======= Flash Files set for flashing : [ MCU ] : SPD6531_00400000_GD25LQ32.bin 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 ======= Flashing MCU Mapping file ... Mapping done Processing file : SPD6531_00400000_GD25LQ32.bin Init ok, send data Flashing Done! Info : In some cases after flash required make "Format Fs / Reset Phone" Done! Elapsed: 00:01:26 Reconnect Power/Cable! |
The Following User Says Thank You to pradeep_kus For This Useful Post: |
