09-30-2014, 14:31 | #556 (permalink) | |||
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | Read info Quote:
Read user code Quote:
Flash file link SPD6531_00800000_MOCOR_12B_6531.W13.07_Release_092 72013175210__Kailinuo-K925 - Download - 4shared | |||
The Following User Says Thank You to ishant For This Useful Post: |
10-02-2014, 07:49 | #558 (permalink) |
Insane Poster Join Date: Jan 2014 Location: India
Member: 2110293 Status: Offline Sonork: 12312345 Thanks Meter: 103 | lemon B169 SPD6531 Read Flash File Done Download : SPD6531_00400000_GD25LQ32_English__Lemon -B169 - Download - 4shared - Akash India B.R., Mobile_CareŽ |
The Following User Says Thank You to Mobile_CareŽ For This Useful Post: |
10-03-2014, 10:32 | #559 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | CELKON C7040 Code: Operation : Format File System [ v0.07 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
10-18-2014, 15:00 | #561 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | e 2200 Operation : Format File System [ v1.00 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 30 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 [1] Flash DIE : 00EF 0060 0018 0000 [1] Flash VEN : Winbond , W25Q128 [1] Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:04:18 Reconnect Power/Cable! |
The Following User Says Thank You to genci titi 2002 For This Useful Post: |
10-29-2014, 21:15 | #564 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, We are very glad to see you here too. You can buy Infinity-Box products here: Infinity-Box - Multibrand Unlock & Repair Tools |
11-16-2014, 06:55 | #565 (permalink) |
Member: 2110293 Status: Offline Sonork: 12312345 Thanks Meter: 103 | Yxtel Q636 SPD6531 Flash File Read Done Code: ==== Wait for phone... Phone found! [ 143 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C2 0025 0038 0000 [0] Flash VEN : Macronix , MX25 [0] Flash CAP : 01000000 Read Flash Content Read Ok , collect info Platform : MOCOR_12B.W13.07_Release ExtInfo : 2014-06-05 21:13:49 Project : SC6530_PDA HWInfo : SC6530_PDA Compile : 2014-06-05 21:13:49 Set FileInfo : Model Vendor : Yxtel Model Name : Q636 ExtInfo Data : English Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_01000000_MOCOR_12B.W13.07_Release__English__Yxtel -Q636.bin Done! Elapsed: 00:02:05 Reconnect Power/Cable! Mobile_CareŽ |
11-16-2014, 07:00 | #567 (permalink) |
Member: 2110293 Status: Offline Sonork: 12312345 Thanks Meter: 103 | Vinko Z10 SPD6531 Restart Problem & Read Flash File Done Code: Phone found! [ 147 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0017 0000 [0] Flash VEN : Winbond , W25Q64 [0] Flash CAP : 00800000 Read Flash Content Read Ok , collect info Platform : MOCOR_12B_6531.W13.07_Release ExtInfo : VINKO Project : SC6531_PDA HWInfo : SC6531_PDA Compile : 06-06-2014 22:19:07 Set FileInfo : Model Vendor : Vinko Model Name : Z10 ExtInfo Data : English Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MOCOR_12B_6531.W13.07_Release_06062014221907_English__Vinko-Z10.bin Done! Elapsed: 00:01:15 Reconnect Power/Cable! Mobile_CareŽ |
11-20-2014, 17:39 | #568 (permalink) |
No Life Poster Join Date: May 2005 Location: bridgetown Age: 59
Member: 146939 Status: Offline Sonork: 100.1609615 Thanks Meter: 245 | blu 6571 Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 002C00BC009000660054000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B Configure emi settings DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x007A , [Micron] NAND_MT29C4G48MAAHBAAKS [NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! i have backup from working phone but is not writing to this phone |
