Chinese Miracle-2 (Test Version) Reports: SPD/Spreadtrum Dear Friends, Please, post here your test reports with Chinese Miracle-2 (Test Version) SPD/Spreadtrum software. This software is a Test Version so always make a backup before any operation ! How to Download and Activate Chinese Miracle-2 (Test Version) software (for FREE) for Main Infinity-Box: http://forum.gsmhosting.com/vbb/f296...ocess-1867818/ Updates and support for SPD/Sreadtrum software: 1. Where to send flash files and links: [email protected] 2. If you have any SPD CPU based phone and want to see it supported - post here your request. 3. If you have any SPD CPU based phone with some kind of software damage/problem - post here your questions and we will try to adjust our software to fix that problems. 4. We need new phone samples for research: http://forum.gsmhosting.com/vbb/f296...earch-1786726/ |
1st i9500 spd 6531 flash done Card found: S/N xxxxxxxxxx Chinese Miracle II [SPD module] v 0.02 FastCheck : SPD65xx Load file... Platform : MOCOR_12B_6531.W13.07_Release Project : J6501 272X480 HWInfo : SC6531_PDA Compile : 11-23-2013 15:56:19 Load Ok Operation : Flash ======= Flash Files set for flashing : [ MCU ] : MOCOR_12B_6531.W13.07_Release_20140426_175308_Full Flash.bin 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 299 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0018 0000 Flash VEN : GigaDevice , GD25LQ128 Flash CAP : 01000000 ======= Flashing MCU Mapping file ... Mapping done Processing file : MOCOR_12B_6531.W13.07_Release_20140426_175308_Full Flash.bin Init ok, send data Flashing Done! Info : In some cases after flash required make "Format Fs / Reset Phone" Done! Elapsed: 00:05:03 Reconnect Power/Cable! |
@ABDULMANAN good test report but what is the result after flash ur phone repaired successfully or not ? |
Start at : [29/04/2014 / 02:50:27 p.m.] Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 53 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD 25LQ32.bin Done! Elapsed: 00:00:38 ************************************************** ************* perfect full flash read ************************************************** ************** sucessfull flash back up ======= Flash Files set for flashing : [ MCU ] : SPD6531_00400000_GD25LQ32.bin 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 53 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 ======= Flashing MCU Mapping file ... Mapping done Processing file : SPD6531_00400000_GD25LQ32.bin Init ok, send data Flashing Done! Info : In some cases after flash required make "Format Fs / Reset Phone" Done! Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 53 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! *************************************** sucessfull format wow model tested gomobile 177 movistar Nicaragua |
BM50 , over COM , SPD6530 Read Flash Code: Operation : Read FullFlash Code: FastCheck : SPD65xx Code: Operation : Format File System Code: Operation : Check/Read Info Code: Operation : Repair Security Code: Operation : Check/Read Info |
Micromax X267 , USB , SPD6531 Check Code: Operation : Check/Read Info Code: Operation : Read User Code Code: Operation : Read FullFlash Code: Operation : Format File System Code: FastCheck : SPD65xx Code: Operation : Check/Read Info |
you're support more text and link alternate :) |
i am not spamming,. sorry but now it is all ok.. sorry for making noise here... |
bro must add spd 6810 & 6820 |
Cherry mobile t19 Cherry mobile t19 phone status dead read in boot Quote:
@MARVZ_TG , please, read flash from it and send me. Need check it. |
Check my pm............... |
