05-09-2014, 15:46 | #136 (permalink) | ||
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Quote:
Really world's best support team is Infinity box team. Write flash Quote:
Thanks Siddeque. | ||
The Following User Says Thank You to .:MobileLife:. For This Useful Post: |
05-09-2014, 17:03 | #137 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Thanks for test I will try implement one button recovery in some of next versions. Hope, it will work. If will be more sets, at least 4-5 - will be great, help well finish full tests. |
05-10-2014, 09:38 | #138 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Videocon V1565 llegal Use , Power Off Done !! Format FFS Code: Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0060 0017 0000 Flash VEN : Winbond , W25Q64 Flash CAP : 00800000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:24 Reconnect Power/Cable! Code: Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0060 0017 0000 Flash VEN : Winbond , W25Q64 Flash CAP : 00800000 Read Flash Content Read Ok , collect info Platform : MOCOR_12C.W13.04.03_Release ExtInfo : Videocon_V1565_V1.0_130917 Project : SC6531_BAR HWInfo : F536 V0.1 Compile : 09-17-2013 16:21:53 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MOCOR_12C.W13.04.03_Release_Videocon_V1565_V1.0_130917_09172013162153.bin Done! Elapsed: 00:00:50 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to pradeep_kus For This Useful Post: |
05-11-2014, 13:46 | #140 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Spice M-5032 Dead Recover Done !! Code: Chinese Miracle II [SPD module] v 0.04 Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:22 Code: Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info ExtInfo : ےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےے Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_ےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےےے_.bin Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
The Following User Says Thank You to pradeep_kus For This Useful Post: |
05-11-2014, 16:45 | #141 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn K62+ Test Report Operation : Read User Code Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0018 0000 Flash VEN : GigaDevice , GD25LQ128 Flash CAP : 01000000 Check data... Can take some time User Code : Active Code not found (Standard : 1234 , 0000 , 1122) Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Format File System Code: Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok Flash DIE : 00C8 0060 0018 0000 Flash VEN : GigaDevice , GD25LQ128 Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:50 Reconnect Power/Cable! Operation : Read FullFlash Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0018 0000 Flash VEN : GigaDevice , GD25LQ128 Flash CAP : 01000000 Read Flash Content Read Ok , collect info Platform : MOCOR_12B_6531.W13.07_Release Project : SC6531_PDA HWInfo : SC6531_PDA Compile : 12-25-2013 16:03:10 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_01000000_MOCOR_12B_6531.W13.07_Release_12252013160310.bin Done! Elapsed: 00:02:15 Reconnect Power/Cable! |
The Following User Says Thank You to MyGSM World For This Useful Post: |
05-12-2014, 12:51 | #143 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Yo Yo Y1 Read User Code Done (Chines-Model) Read Info Code: Operation : Check/Read Info 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Done! Elapsed: 00:00:56 Reconnect Power/Cable! Read Code Code: Operation : Read User Code 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Check data... Can take some time User Code : 5688 Done! Elapsed: 00:00:16 Read Flash Code: Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_W25Q32.bin Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
05-14-2014, 06:37 | #144 (permalink) | |||
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Rokea R3 SPD 6531A Dead phone alive. Read Info Quote:
Read flash Quote:
CM2SPD section is not opening since yesterday that's way I am posting here. WBR. Siddeque. | |||
05-14-2014, 08:49 | #145 (permalink) |
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | China iPhone 5 SPD 6530 IMEI repair problem? Reconnect Power/Cable! Operation : Repair Security 1. Insert USB cable ( Use adapter or special cable ) 2. Insert battery 3. If boot not start - press 'Power' button shortly ==== Wait for phone... Phone found! [ 40 ] Port Opened Sync... InitSvc Failed! Reconnect Power/Cable! WBR. Siddeuqe |
05-14-2014, 11:23 | #146 (permalink) | |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
The Following User Says Thank You to Dzirt For This Useful Post: |
05-14-2014, 13:02 | #148 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Intex Neno-2 SPD6531 User Code Done Read Code Code: Chinese Miracle II [SPD module] v 0.04 Operation : Read User Code 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Check data... Can take some time User Code : 0235 Done! Elapsed: 00:01:08 Code: Reconnect Power/Cable! Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_W25Q32.bin Done! Elapsed: 00:00:33 Reconnect Power/Cable! Code: Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
05-14-2014, 13:05 | #149 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Another Disko I9082 Read User Code Done (Chines) User Code Code: Operation : Read User Code 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0017 0000 Flash VEN : GigaDevice , GD25LQ64 Flash CAP : 00800000 Check data... Can take some time User Code : 9518 Done! Elapsed: 00:00:16 Reconnect Power/Cable! Read Flash Code: Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0017 0000 Flash VEN : GigaDevice , GD25LQ64 Flash CAP : 00800000 Read Flash Content Read Ok , collect info Platform : MOCOR_12B_6531.W13.07_Release Project : SC6716_PDA HWInfo : SC6716_PDA Compile : 07-15-2013 20:18:44 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MOCOR_12B_6531.W13.07_Release_07152013201844.bin Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
05-14-2014, 13:53 | #150 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | This file is read from a locked to network phone,any assistance to unlock this phone is highly appreciated link SPD6531_00400000_GD25LQ32[/QUOTE] Is the File ready SIR ???????????????? |
