05-14-2014, 21:27 | #152 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Friends ! If you will send any flash files to Mr. Dzirt, please, send a copy to [email protected] or to [email protected] so we will be able to upload fkkash files into support area. Thank you ! |
05-15-2014, 10:12 | #155 (permalink) |
Banned Join Date: Sep 2007
Member: 583468 Status: Offline Sonork: 100.1592004 Thanks Meter: 106 | Karbonn K111* Sucessfully recover Code: Operation : Check/Read Info 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Done! Elapsed: 00:00:10 Reconnect Power/Cable! Code: Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:36 Reconnect Power/Cable! this is my 1st test report //lots coming through |
The Following User Says Thank You to jmzboudh For This Useful Post: |
05-15-2014, 11:52 | #156 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
http://forum.gsmhosting.com/vbb/f296...0/index13.html | |
The Following User Says Thank You to Kirumira For This Useful Post: |
05-16-2014, 14:20 | #160 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Depend what you want unlock : User code or SP code. Connect - need have modified cable ( check in docs ) or proper bootkey. All explained in docs folder about that things. |
05-16-2014, 15:21 | #161 (permalink) |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Mr Dzirt Is the File ready SIR? Send it to [email protected] |
05-16-2014, 15:47 | #162 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Kirumira , trying finish. One question - does phone asks for unlock code, or just not show network or show something other? Like : Invalid Sim , or Sim Error ? |
05-16-2014, 16:21 | #163 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Disko 5282 Screen Lock Done Via Format (Chines) Read Flash Code: Chinese Miracle II [SPD module] v 0.04 Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0017 0000 Flash VEN : GigaDevice , GD25LQ64 Flash CAP : 00800000 Read Flash Content Read Ok , collect info Platform : MOCOR_12B_6531.W13.07_Release Project : SC6716_PDA HWInfo : SC6716_PDA Compile : 11-27-2013 11:25:59 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MOCOR_12B_6531.W13.07_Release_11272013112559.bin Done! Elapsed: 00:01:45 Reconnect Power/Cable! Code: Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0017 0000 Flash VEN : GigaDevice , GD25LQ64 Flash CAP : 00800000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
The Following User Says Thank You to pradeep_kus For This Useful Post: |
