05-16-2014, 17:54 | #167 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Aha , thanks. That mean there is no code level lock and it implemented in firmware inside. It will take much time to determine that. I managed to run this FW on my phone, will continue research. If some result will be - let you know. |
The Following User Says Thank You to Dzirt For This Useful Post: |
05-16-2014, 19:43 | #169 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn K52Plus (K52+) Test Report Chinese Miracle II [SPD module] v 0.04 Operation : Check/Read Info Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Read FullFlash Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32_2.bin Done! Elapsed: 00:00:38 Reconnect Power/Cable! Operation : Read User Code Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Check data... Can take some time User Code : 1122 Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Format File System Code: Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
05-16-2014, 20:27 | #170 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn K52Star (K52*) V1.1.2 Test Report Chinese Miracle II [SPD module] v 0.04 Operation : Check/Read Info Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Read User Code Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Check data... Can take some time User Code : 1122 Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Read FullFlash Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info ExtInfo : B174A_Karbonn_K52*_V1.1.2_20140103 Project : S239_B164B_V1.1.2 HWInfo : SC6531_BAR Compile : 01-03-2014 18:05:28 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_B174A_Karbonn_K52*_V1.1.2_20140103_01032014180528.bin Done! Elapsed: 00:00:38 Reconnect Power/Cable! Operation : Format File System Code: Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following User Says Thank You to MyGSM World For This Useful Post: |
05-17-2014, 09:51 | #171 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,542 | Zen M7 Illegal Use Power Done Zen M7 Illegal Use Power Done Format FFS Code: Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:23 Reconnect Power/Cable! Code: Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info ExtInfo : نأ Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_نأ_.bin Done! Elapsed: 00:01:05 Reconnect Power/Cable! |
05-17-2014, 10:00 | #172 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,542 | Intex Alpha Dead Recover Done Write Flash !! Done Code: FastCheck : SPD65xx Load file... Not found any ExtInfo data (Compressed already) Load Ok Operation : Flash ======= Flash Files set for flashing : [ MCU ] : 6531A_GD27LQ32 intex ok 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 ======= Flashing MCU Mapping file ... Mapping done Processing file : 6531A_GD27LQ32 intex ok Init ok, send data Flashing Done! Info : In some cases after flash required make "Format Fs / Reset Phone" Done! Elapsed: 00:01:28 Reconnect Power/Cable! |
The Following User Says Thank You to pradeep_kus For This Useful Post: |
05-18-2014, 15:55 | #173 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,542 | Intex Leo Privery Code Read Done !! Read Code Code: Operation : Read User Code 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Check data... Can take some time User Code : 0751 Done! Elapsed: 00:00:38 Reconnect Power/Cable! Read Flash Code: Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32.bin Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
05-19-2014, 10:30 | #174 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn K75Plus (K75+) Test Report Operation : Check/Read Info Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C2 0025 0038 0000 Flash VEN : Macronix , MX25 Flash CAP : 01000000 Done! Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Read FullFlash Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C2 0025 0038 0000 Flash VEN : Macronix , MX25 Flash CAP : 01000000 Read Flash Content Read Ok , collect info Platform : MOCOR_12B_6531.W13.07_Release Project : SC6531_PDA HWInfo : SC6531_PDA Compile : 01-22-2014 11:38:01 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_01000000_MOCOR_12B_6531.W13.07_Release_01222014113801.bin Done! Elapsed: 00:02:02 Reconnect Power/Cable! Operation : Read User Code Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C2 0025 0038 0000 Flash VEN : Macronix , MX25 Flash CAP : 01000000 Check data... Can take some time User Code : 1122 Done! Elapsed: 00:00:22 Reconnect Power/Cable! Operation : Format File System Code: Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C2 0025 0038 0000 Flash VEN : Macronix , MX25 Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
05-19-2014, 12:28 | #175 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Samsung GT-E2202 , IMEI repair Code: Operation : Repair Security Normal Normal : Power On phone. Insert USB cable ( Normal USB cable ) ==== Wait for phone... Phone found! [ 100 ] Port Opened Sync... Phone Initial Info : Phone : GT-E2202 Platform : MOCOR_W12.15.01_EtonDS_R3.0.2_Debug ExtInfo : sc6530_samsung_EtonDS Project : SC6530_SAMSUNG HWInfo : SC6530_EtonDS Compile : 01-08-2013 10:45:14 Phone Security Info : IMEI [1] : 35394305445244 Read Ok! Write new security data : IMEI1 : 353943054452416 IMEI2 : 353944054452414 Write Items Ok Elapsed: 00:00:02 Reconnect Power/Cable! |
05-19-2014, 15:03 | #176 (permalink) | |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,542 | Quote:
05-20-2014, 17:36 | #177 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | read info.... Code: Operation : Check/Read Info 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0060 0018 0000 Flash VEN : Winbond , W25Q128 Flash CAP : 01000000 Done! Elapsed: 00:00:12 Code: econnect Power/Cable! Operation : Repair Security 1. Insert USB cable ( Use adapter or special cable ) 2. Insert battery 3. If boot not start - press 'Power' button shortly ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitSvc Failed! Reconnect Power/Cable! Operation : Repair Security 1. Insert USB cable ( Use adapter or special cable ) 2. Insert battery 3. If boot not start - press 'Power' button shortly ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitSvc Failed! Reconnect Power/Cab |
05-20-2014, 18:00 | #178 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello , please, try with new version. Power On phone fully. Select SPD6531 CPU. Connect phone to PC via USB cable. If phone ask for select mode - Select PC Connection (Transfer data) , not "Charging" or "Media Storage" , some phones not ask for mode and directly connect to PC without any request. Enter need data , pres "Write Security" Let me know result. CM2SPD v0.05 Link : CM2SPD_v5 - Download - 4shared HowTo update : just unpack archive files to your current CM2SPD folder. Installer will follow little later. |
05-21-2014, 05:13 | #179 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | MICROMAX X455I NO OUT GOING DONE BY FORMAT Code: Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 124 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0018 0000 Flash VEN : GigaDevice , GD25LQ128 Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
05-21-2014, 07:51 | #180 (permalink) | |
Member: 1146038 Status: Offline Thanks Meter: 196 | Quote:
thanks sir to replay Connect phone to PC via USB so ask 3 option chargin udisk and pc connecting so i select pc connecting so give me a pop up .. " Simcard is locked or does not exist " but sim is exist .... ans sim is show stk menu in phone so where is problem .... | |
