05-21-2014, 10:08 | #186 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Only solder Rx/Tx pads or use any as pinfinder. Android under work. | |
The Following User Says Thank You to Dzirt For This Useful Post: |
05-21-2014, 10:22 | #187 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | YXTEL MODEL:C802 phone status pass code Chinese Miracle II [SPD module] v 0.05 Quote:
05-21-2014, 13:12 | #191 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | @MARVZ_TG , Code is 1122. Will revise somethings and tomorrow it will be supported for rest things. |
05-21-2014, 13:46 | #192 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Corral de Bustos, Argentina
Member: 578880 Status: Offline Thanks Meter: 144 | Good Work Dzirt Please added SPD SC7710b Samsung E3300i Claro Argentina Unlock - IMEI repair - Read/write Full Flash Read with SPD6530 Press * key and connect USB cable without batery Card found: Chinese Miracle II [SPD module] v 0.05 Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 36 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot didn't start! Check model selection! Boot Error! Break Reconnect Power/Cable! Thanks Infinity Team nikita3000 |
05-21-2014, 14:11 | #194 (permalink) |
Freak Poster Join Date: Nov 2010 Location: CHOLOMAN
Member: 1440339 Status: Offline Sonork: 100.1616914;CHOLOMAN Thanks Meter: 116 | @ Dzirt what about 6531d ? Is it supported? Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! |
05-21-2014, 14:30 | #195 (permalink) |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | Mjphone m7500 read code success MJPHONE M7500 READ CODE SUCCESS Code: ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Check data... Can take some time User Code : 3894 Done! Elapsed: 00:00:14 tRRIEC |
