Old 04-30-2014, 06:43   #16 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 397
Micromax X329
With Regards
Avtarkaint
The Following 2 Users Say Thank You to avtarkaint For This Useful Post:
Old 04-30-2014, 06:47   #17 (permalink)
tolski's Avatar
Member: 34750
Thanks Meter: 177
where to download spd driver?
Old 04-30-2014, 06:57   #18 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 407
blueberry S111 Read flash and format without tension.
Read Flash
peration : Read FullFlash
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 26 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0000
Flash DIE : 00C2 0025 0038 0000
Flash VEN : Macronix , MX25
Flash CAP : 01000000
Read Flash Content
Read Ok , collect info
Platform : MOCOR_12B_6531.W13.07_Debug
X9_shengkailong_S12_blu
Project : SC6531_PDA
HWInfo : SC6531_PDA
Compile : 08-05-2013 10:22:09
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_01000000_MO COR_12B_6531.W13.07_Debug
X9_shengkailong_S12_blu_08052013102209.bin
Done!
Elapsed: 00:01:29
Reconnect Power/Cable!
Format
Operation : Format File System
Settings : SmartFormat is On
3. Insert battery
Phone found! [ 26 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:41
WBR
Siddeque.
The Following User Says Thank You to .:MobileLife:. For This Useful Post:
Old 04-30-2014, 06:59   #19 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
Inside CM2SPD/Drivers/ folder.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 04-30-2014, 07:06   #20 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Sonork: 100.1674275
Thanks Meter: 12,362
boss what about sc6820 phones?
Old 04-30-2014, 07:09   #21 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
The more complicated and We work on them to make correct and safe way for them.
Old 04-30-2014, 07:11   #22 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 407
Sir, means team is working on SPD and MTK Android phones?
Old 04-30-2014, 07:38   #23 (permalink)
irfan_gsm's Avatar
Member: 709520
Thanks Meter: 263
PHONE IS ON PHONE LOCK . READ CODE, FORMAT FAILED
Phone found! [ 278 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Flash DIE : 00C8 0060 0018 0000
Flash VEN : GigaDevice , GD25LQ128
Check data... Can take some time
User Code : Active Code not found (Standard : 1234 , 0000 , 1122)
3. Insert battery
Port Opened
Sync...
Sending boot ...
Boot Ok
Error while prepare!
Format error, something went wrong
Old 04-30-2014, 07:49   #24 (permalink)
Member: 1043909
Thanks Meter: 47,041
Chinese Miracle-2 (Test Version) SPD/Spreadtrum v0.02 released
.Supported CPU: SPD6530, SPD6531
.Supported Interface: USB, COM/UART
.Supported FlashIc: 4/8/16/32 Mb
.Supported operations:
1. Read Info
2. Check
3. Flash Read (Plain Bin)
4. Flash Write (Plain Bin)
5. Read UserCode
6. Repair IMEI
7. Format/Reset Settings
Old 04-30-2014, 08:02   #25 (permalink)
Member: 1043909
Originally Posted by ihsan.khan.gsm View Post
bro must add spd 6810 & 6820
We are working step-by-step.
The Following 3 Users Say Thank You to YellowBoss For This Useful Post:
Old 04-30-2014, 08:36   #26 (permalink)
mrrobin's Avatar
Member: 888712
Thanks Meter: 283
sir plz support new cpu mtk & spd
br
robin
Old 04-30-2014, 08:44   #27 (permalink)
Member: 1043909
br
robin
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 04-30-2014, 08:51   #28 (permalink)
Member: 160069
Sonork: 100.1622432
Thanks Meter: 30
Phone found! [ 128 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Flash DIE : 00EF 0040 0016 0000
Flash VEN : Winbond , W25Q32
Flash CAP : 00400000
Format Block Done!
Done!
Elapsed: 00:00:19
karbonn k72+ format and code read success no dead risk at all... really a great update by infinity team
Old 04-30-2014, 09:00   #29 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
Port Opened
Sync...
Sending boot ...
Boot Ok
3. Insert battery
Port Opened
Sync...
Sending boot ...
Boot Ok
Hello! I sent in PM link, change exe to new one and try again. Let us know result.
Old 04-30-2014, 10:16   #30 (permalink)
Member: 1043909
Chinese Miracle-2 (Test Version) SPD/Spreadtrum v0.03 released
.Improved Flash detection
.Improved UserCode reading for some original brands (Explay, Phillips)
.Improved Format/Reset setting for some original brands (Explay, Phillips)
.Improved Dual-Type structure support (16mb Touch phones)
.Improved Repair Security (No Ack Error) on some phones
.Minor bugs fixed
The Following 2 Users Say Thank You to YellowBoss For This Useful Post:
Page generated in 0.36390 seconds with 8 queries
