Old 04-30-2014, 11:03   #31 (permalink)
mrrobin's Avatar
Member: 888712
Thanks Meter: 308
please next update ,mtk 65xx,81xx android & spd 6820 ,8810,8825.
we are waiting sir
Old 04-30-2014, 11:12   #32 (permalink)
irfan_gsm's Avatar
Member: 709520
Thanks Meter: 275
i send the readed file pls check
Old 04-30-2014, 11:41   #33 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Got, check. It seems interest. I found only 1234 code, nothing more. Continue checking.
we are waiting sir
Sure, we work step-by-step.
The Following 4 Users Say Thank You to Dzirt For This Useful Post:
Old 04-30-2014, 13:17   #34 (permalink)
Member: 300759
Thanks Meter: 19
Good but infinity box is always too expensive for clients.
its good idea to make money.....
Old 04-30-2014, 14:36   #35 (permalink)
Member: 1140831
Sonork: no
Thanks Meter: 232
my box working thxxxxxxxx
i hope new update
add bro 6820 and 8810 ,8825 and all spd cpu plzzzzzzzzzzzzzzzzzzzzzzz
Old 04-30-2014, 15:13   #36 (permalink)
Member: 2138570
Sonork: 100.1611495
Thanks Meter: 301
B-Fly model-B4
killed by volcano box by reading only info
revived by CM-2_spd by reading file from same working phone
read full flash
Operation : Read FullFlash
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 15 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0000
Flash DIE : 00C2 0025 0037 0000
Flash VEN : Macronix , MX25U64
Flash CAP : 00800000
Read Flash Content
Read Ok , collect info
Platform : MOCOR_12B_6609.W13.07_Release
Project : SC6609_PDA
HWInfo : SC6609_PDA
Compile : 06-09-2013 21:54:09
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MO COR_12B_6609.W13.07_Release_06092013215409.bin
Done!
Elapsed: 00:00:46
Reconnect Power/Cable!
Finish at : [4/30/2014 / 6:50:45 PM]
full flash
Operation : Flash
======= Flash
Files set for flashing :
[ MCU ] : SPD6531_00800000_MOCOR_12B_6609.W13.07_Release_060 92013215409.bin
3. Insert battery
Phone found! [ 15 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Flash DIE : 00C8 0060 0017 0000
Flash VEN : GigaDevice , GD25LQ64
======= Flashing MCU
Mapping file ...
Mapping done
Processing file : SPD6531_00800000_MOCOR_12B_6609.W13.07_Release_060 92013215409.bin
Init ok, send data
Flashing Done!
Info : In some cases after flash required make "Format Fs / Reset Phone"
Done!
Elapsed: 00:03:07
Finish at : [4/30/2014 / 7:02:02 PM]
The Following User Says Thank You to Ismail khan1978 For This Useful Post:
Old 04-30-2014, 17:00   #37 (permalink)
Member: 2159186
Thanks Meter: 3
smart s-400 unlock done ......
try gpgdragon not ok
try volcono not ok
try
Infinity-Box 100% ok
thanksss sir nice work...........................................
The Following 2 Users Say Thank You to g_unlock For This Useful Post:
Old 04-30-2014, 17:13   #38 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
Originally Posted by SHIJILFONOTLY View Post
boss what about sc6820 phones?
why u ask about that i think u have still no solution yet
Old 04-30-2014, 17:23   #39 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
What about we talking? Please, if you have question to exactly person and it not related to thread subject - try talk in PM.
Old 04-30-2014, 17:29   #40 (permalink)
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
im so sory for post at wrong place im just aware him ,he is member each like team where are alraedy add in alot of tool but still not working well
any way delete my post
Old 04-30-2014, 17:31   #41 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Chinese "I9300 Samsung" SPD6530
Read USerCode
Card found: S/N CB41:0126
Chinese Miracle II  [SPD module] v 0.03
Operation : Read User Code
3. Insert battery
Phone found! [ 68 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
CPU ID : 6530 , FDLStat : 0000
Flash DIE : 00C8 0060 0018 0000
Flash VEN : GigaDevice , GD25LQ128
Flash CAP : 01000000
Check data... Can take some time
User Code : 552239
Done!
Elapsed: 00:00:16
CM2 not read 5-10-20 codes, which can be inside. It read only real user code.
Format
Operation : Format File System
Settings : SmartFormat is On
3. Insert battery
Phone found! [ 68 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Format Block Done!
Done!
Elapsed: 00:00:34
No dead. No problems.
Old 04-30-2014, 17:38   #42 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Chinese "I9500 Samsung" SPD6531
Read UserCode
3. Insert battery
Phone found! [ 68 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Flash DIE : 00EF 0060 0017 0000
Flash VEN : Winbond , W25Q64
User Code : 1234
Done!
Elapsed: 00:00:17
Format
3. Insert battery
Phone found! [ 68 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Format Block Done!
Done!
Elapsed: 00:00:21
Old 05-01-2014, 06:26   #43 (permalink)
Saulcell's Avatar
Member: 278939
Sonork: 100.1593095
Thanks Meter: 382
infinity box is the best in the world is not that had taken so long to get these updates
Old 05-01-2014, 09:44   #44 (permalink)
Member: 459784
Sonork: +91-9179403087
Thanks Meter: 1,543
Micromax X084 Flash Format Done
Read Flash !!
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Flash DIE : 00C8 0060 0016 0000
Flash VEN : GigaDevice , GD25LQ32
Flash CAP : 00400000
Read Flash Content
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32.bin
Done!
Elapsed: 00:00:54
Format Working Like Charm ( Other Team Still Shocked ) Infinity-Box Always Rock :-p
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:14
Read Code
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
User Code : 2525
Done!
Elapsed: 00:00:11
Flash Done !!
FastCheck : SPD65xx
Load file...
Not found any ExtInfo data (Compressed already)
Load Ok
Operation : Flash
======= Flash
[ MCU ] : SPD6531_00400000_GD25LQ32.bin
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Mapping file ...
Mapping done
Processing file : SPD6531_00400000_GD25LQ32.bin
Init ok, send data
Flashing Done!
Done!
Elapsed: 00:01:26
Gr8 Team Gr8 Update Waiting For 8810-6820-8825-7710-6825
The Following User Says Thank You to pradeep_kus For This Useful Post:
Old 05-01-2014, 10:23   #45 (permalink)
Member: 1894674
Thanks Meter: 2
Good update but spd 6531d still problematic tried with v 0.02 hope v 0.04 will be successful
Thanks
Page generated in 0.31819 seconds with 9 queries
