Old 09-30-2014, 14:31   #556 (permalink)
ishant's Avatar
Member: 1763238
Thanks Meter: 370
Kailinuo K925
Read info
Start at : [9/30/2014 / 6:18:59 PM]
Operation : Check/Read Info [ v0.07 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 101 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0000
[0] Flash DIE : 00EF 0060 0017 0000
[0] Flash VEN : Winbond , W25Q64
[0] Flash CAP : 00800000
Done!
Elapsed: 00:00:13
Read flash
Start at : [9/30/2014 / 6:45:21 PM]
Operation : Read FullFlash [ v0.07 ]
3. Insert battery
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Read Flash Content
Read Ok , collect info
Platform : MOCOR_12B_6531.W13.07_Release
Project : SC6531_PDA
HWInfo : SC6531_PDA
Compile : 09-27-2013 17:52:10
Set FileInfo :
Model Vendor : Kailinuo
Model Name : K925
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MO COR_12B_6531.W13.07_Release_09272013175210__Kailin uo-K925.bin
Done!
Elapsed: 00:01:19
Read user code
Start at : [9/30/2014 / 6:48:11 PM]
Operation : Read User Code [ v0.07 ]
3. Insert battery
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Check data... Can take some time
User Code : 5656
Done!
Elapsed: 00:00:27
Reconnect Power/Cable!
Finish at : [9/30/2014 / 6:48:38 PM]
Flash file link SPD6531_00800000_MOCOR_12B_6531.W13.07_Release_092 72013175210__Kailinuo-K925 - Download - 4shared
The Following User Says Thank You to ishant For This Useful Post:
Old 10-01-2014, 13:08   #557 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
Originally Posted by JorgeVla View Post
YXTEL C802 Format Successfully, done in latest version, not done with V... box
[/CODE]Great work, keep going
if possible plz upload this file
Old 10-02-2014, 07:49   #558 (permalink)
Member: 2110293
Sonork: 12312345
Thanks Meter: 103
lemon B169 SPD6531 Read Flash File Done
Download : SPD6531_00400000_GD25LQ32_English__Lemon -B169 - Download - 4shared - Akash India
B.R.,
Mobile_CareŽ
The Following User Says Thank You to Mobile_CareŽ For This Useful Post:
Old 10-03-2014, 10:32   #559 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
CELKON C7040
Operation : Format File System [ v0.07 ]
Settings : SmartFormat is On
3. Insert battery
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
[0] Flash DIE : 00EF 0060 0018 0000
[0] Flash VEN : Winbond , W25Q128
[0] Flash CAP : 01000000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:52
The Following User Says Thank You to VIJAY2U2 For This Useful Post:
Old 10-10-2014, 07:33   #560 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 158
Originally Posted by Abzal View Post
Read User Code
But connect only via UART cable, via USB not work.
After reinstall drivers, work via USB
Old 10-18-2014, 15:00   #561 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,693
Wink e 2200
Operation : Format File System [ v1.00 ]
3. Insert battery
Phone found! [ 30 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
CPU ID : 6530 , FDLStat : 0000
[1] Flash DIE : 00EF 0060 0018 0000
[1] Flash VEN : Winbond , W25Q128
[1] Flash CAP : 01000000
Format Block Done!
Done!
Elapsed: 00:04:18
The Following User Says Thank You to genci titi 2002 For This Useful Post:
Old 10-29-2014, 02:32   #562 (permalink)
Member: 1228709
Thanks Meter: 268
Yes bro, i will search and upload the file, if i have, sure.
Sorry for big delay
Old 10-29-2014, 18:57   #563 (permalink)
Member: 2126371
Hi everybody! I'm happy to here.
Old 10-29-2014, 21:15   #564 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
We are very glad to see you here too.
You can buy Infinity-Box products here: Infinity-Box - Multibrand Unlock & Repair Tools
Old 11-16-2014, 06:55   #565 (permalink)
Member: 2110293
Sonork: 12312345
Thanks Meter: 103
Yxtel Q636 SPD6531 Flash File Read Done
Phone found! [ 143 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C2 0025 0038 0000
[0] Flash VEN : Macronix , MX25
Read Flash Content
Platform : MOCOR_12B.W13.07_Release
ExtInfo  : 2014-06-05 21:13:49
Project  : SC6530_PDA
HWInfo   : SC6530_PDA
Compile  : 2014-06-05 21:13:49
Set FileInfo :
Model Vendor : Yxtel
Model Name   : Q636
ExtInfo Data : English
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_01000000_MOCOR_12B.W13.07_Release__English__Yxtel -Q636.bin
Done!
Elapsed: 00:02:05
B.R.,
Mobile_CareŽ
Old 11-16-2014, 06:56   #566 (permalink)
Member: 2110293
Sonork: 12312345
Thanks Meter: 103
Megaget T960 SPD6531 Read Flash Files Done
B.R.,
Mobile_CareŽ
Old 11-16-2014, 07:00   #567 (permalink)
Member: 2110293
Sonork: 12312345
Thanks Meter: 103
Vinko Z10 SPD6531 Restart Problem & Read Flash File Done
Phone found! [ 147 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Read Flash Content
ExtInfo  : VINKO
HWInfo   : SC6531_PDA
Compile  : 06-06-2014 22:19:07
Set FileInfo :
Model Vendor : Vinko
Model Name   : Z10
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MOCOR_12B_6531.W13.07_Release_06062014221907_English__Vinko-Z10.bin
Done!
Elapsed: 00:01:15
B.R.,
Mobile_CareŽ
Old 11-20-2014, 17:39   #568 (permalink)
sweetboy's Avatar
Member: 146939
Sonork: 100.1609615
Thanks Meter: 245
blu 6571
Phone found! [ 6 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6571_S00
Processing BROM stage
BLVersion : 0xFE
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
NAND_ID : 002C00BC009000660054000000000000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x8B
Configure emi settings
DA Sent. Configure setting now ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x007A , [Micron] NAND_MT29C4G48MAAHBAAKS
[NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
i have backup from working phone but is not writing to this phone
Old 11-20-2014, 18:43   #569 (permalink)
sweetboy's Avatar
Member: 146939
Sonork: 100.1609615
Thanks Meter: 245
geting this message when writing bin backup file
Old 11-20-2014, 22:03   #570 (permalink)
Member: 1043909
You have to rename file with valid file name and then you should select file again.
1. What is exact phone model name ?
2. Upload file somewhere and post link here, we will check it.
Page generated in 0.22623 seconds with 9 queries
