11-21-2014, 04:34 | #571 (permalink) | |
No Life Poster Join Date: May 2005 Location: bridgetown Age: 59
Member: 146939 Status: Offline Sonork: 100.1609615 Thanks Meter: 245 | Quote:
MT6571__blu - Download - 4shared BLU Dash JR K D142K that is phone model | |
02-27-2015, 13:06 | #572 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | E2200 after flash SW from E2202 IMEI 000000000000000 Repair IMEI, after flash E2200 with E2202 Code: Start at : [27.02.2015 / 17:55:47] Operation : Repair Security [ v1.01 ] Normal Normal : Power On phone. Insert USB cable ( Normal USB cable ) ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... Phone Initial Info : Phone : GT-E2202 Platform : MOCOR_W12.15.01_EtonDS_R3.0.2_Debug ExtInfo : sc6530_samsung_EtonDS Project : SC6530_SAMSUNG HWInfo : SC6530_EtonDS Compile : 02-16-2013 13:27:36 Phone Security Info : IMEI [1] : 00000000000000 Read Ok! Write new security data : IMEI1 : 355254********* IMEI2 : 355254********* Write Items Ok Elapsed: 00:00:03 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to Abzal For This Useful Post: |
05-26-2015, 09:27 | #576 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: kenya karatina
Member: 251792 Status: Offline Thanks Meter: 21 | Quote:
Boot Ver : SEND_ERROR_RSP(0x97) func:_FDL_HWInit, line:458 3è~~ Boot Ok any solutions | |
06-01-2015, 17:08 | #578 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 (Test Version) can be activated for Infinity CDMA-Tool users: http://forum.gsmhosting.com/vbb/f633...users-1954665/ |
08-27-2015, 05:45 | #581 (permalink) | ||
Freak Poster Join Date: May 2009 Location: *JAVA*
Member: 1026340 Status: Offline Sonork: 100.1621159 Thanks Meter: 142 | write flash Quote:
format Quote:
08-27-2015, 14:51 | #582 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2213738 Status: Offline Sonork: 100 Thanks Meter: 8 | i need patched firmware for unlocking the itel it2100s its spd6531 here is log: Operation : Read FullFlash [ v1.03 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 107 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : Itel Model Name : it2100 ExtInfo Data : english Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD 25LQ32_english__Itel-it2100.bin Done! Elapsed: 00:00:53 Reconnect Power/Cable! here is link of firmware in the phone: SPD6531_00400000_GD25LQ32_english__Itel-it2100 - Download - 4shared |
12-03-2015, 13:53 | #583 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Inside Universe
Member: 442808 Status: Offline Thanks Meter: 195 | Samsung E1282T Sucessfully Recover from dead with CM2 Magic Tool Code: Operation : Check/Read Info [ v1.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 48 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 Elapsed: 00:00:08 Reconnect Power/Cable! Code: Operation : Read FullFlash [ v1.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 48 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 Read Flash Content Read Ok , collect info Platform : MOCOR_W12.15.01_ERICPLUS_R3.0.2_Debug sc6530_samsung_EricPlus ExtInfo : LevelofLock 00000000 00000000 Project : SC6530_SAMSUNG HWInfo : SC6530_ERICPLUS Compile : 11-10-2012 23:28:38 Set FileInfo : Model Vendor : Samsung Model Name : E1282T ExtInfo Data : Hindi Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6530_SAMSUNG_01000000_MOCOR_W12.15.01_ERICPLUS_R3.0.2_Debug_sc6530_samsung_EricPlus_11102012232838_Hindi__Samsung-E1282T.bin Done! Elapsed: 00:02:43 Reconnect Power/Cable! Code: Operation : Format File System [ v1.07 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 48 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:02:02 Reconnect Power/Cable! |
