Old 05-01-2014, 10:28   #46 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
Originally Posted by njush View Post
Good update but spd 6531d still problematic tried with v 0.02 hope v 0.04 will be successful
Thanks
Please, explain with logs what and how problematic and we will fix that.
Also, yes , better use latest version. For now it is v0.04
Link with info here :
Chinese Miracle-2 (Test Version) : SPD Module v0.04 Update
Old 05-01-2014, 19:18   #47 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,362
Karbonn K451+ SPD6531 Test Report
Check/Read Info
Chinese Miracle II  [SPD module] v 0.04
Operation : Check/Read Info
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
 ====  Wait for phone...
Phone found! [ 117 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0000
Flash DIE : 00C8 0060 0016 0000
Flash VEN : GigaDevice , GD25LQ32
Flash CAP : 00400000
Done!
Elapsed: 00:00:34
Reconnect Power/Cable!
Read User Code
3. Insert battery
Port Opened
Sync...
Sending boot ...
Boot Ok
Check data... Can take some time
User Code : 1122
Done!
Elapsed: 00:00:06
Format File System
Settings : SmartFormat is On
3. Insert battery
Port Opened
Sync...
Sending boot ...
Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:15
Read FullFlash
3. Insert battery
Port Opened
Sync...
Sending boot ...
Boot Ok
Read Flash Content
Read Ok , collect info
ExtInfo  : K451+_SC6531_NHW_V22_24102013_1500
Project  : S239_B164B_V1.2.2
HWInfo   : SC6531_BAR
Compile  : 10-24-2013 16:50:48
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_K451+_SC6531_NHW_V22_24102013_1500_10242013165048.bin
Done!
Elapsed: 00:00:42
Really It's Amazing.
The Following User Says Thank You to MyGSM World For This Useful Post:
Old 05-01-2014, 19:58   #48 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,362
Karbonn K70 SPD6531 Test Report
3. Insert battery
Port Opened
Sync...
Sending boot ...
Boot Ok
Flash DIE : 00EF 0040 0016 0000
Flash VEN : Winbond , W25Q32
Done!
Elapsed: 00:00:16
Operation : Read User Code
3. Insert battery
Port Opened
Sync...
Sending boot ...
Boot Ok
User Code : 1122
Done!
Elapsed: 00:00:30
Operation : Format File System
3. Insert battery
Port Opened
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:17
Operation : Read FullFlash
3. Insert battery
Port Opened
Sync...
Sending boot ...
Boot Ok
Read Flash Content
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_W25Q32.bin
Done!
Elapsed: 00:00:41
Old 05-01-2014, 20:34   #49 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,362
Karbonn K73 SPD6531 Test Report
3. Insert battery
Port Opened
Sync...
Sending boot ...
Boot Ok
Flash DIE : 00C8 0060 0017 0000
Flash VEN : GigaDevice , GD25LQ64
Flash CAP : 00800000
Done!
Elapsed: 00:00:08
3. Insert battery
Port Opened
Sync...
Sending boot ...
Boot Ok
User Code : Active Code not found (Standard : 1234 , 0000 , 1122)
Done!
Elapsed: 00:00:20
3. Insert battery
Port Opened
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:27
3. Insert battery
Port Opened
Sync...
Sending boot ...
Boot Ok
Read Flash Content
Platform : MOCOR_12C.W13.04.05_Release
Project  : SC6531_OPENPHONE
HWInfo   : SC6531_OPENPHONE
Compile  : 05-14-2013 11:58:00
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MOCOR_12C.W13.04.05_Release_05142013115800.bin
Done!
Elapsed: 00:01:04
Old 05-01-2014, 21:40   #50 (permalink)
Member: 1043909
Thanks Meter: 47,364
Chinese Miracle-2 (Test Version) SPD/Spreadtrum v0.04 released
.Improved SPD6531 support
.Improved UserCode reading
.Improved Format/Reset setting
.Improved Flash Detection
.Improved Dual-Type structure support
.SpeedUp (x2 times) for some operations
.Flash Read operation improved, Error Correction mode supported
.Minor bugs fixed
The Following 2 Users Say Thank You to YellowBoss For This Useful Post:
Old 05-02-2014, 02:05   #51 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
3. Insert battery
Port Opened
Sync...
Sending boot ...
Boot Ok
Done!
Elapsed: 00:00:20
Hello! Please, send me dump from this K73 for futher check
Old 05-02-2014, 05:02   #52 (permalink)
irfan_gsm's Avatar
Member: 709520
Thanks Meter: 263
FINALLY DONE THANKS VERY MUCH INFINITY TEAM AND Dzirt
3. Insert battery
Phone found! [ 278 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Flash DIE : 00C8 0060 0018 0000
Flash VEN : GigaDevice , GD25LQ128
Flash CAP : 01000000
User Code : 45678
Done!
Elapsed: 00:01:11
The Following 3 Users Say Thank You to irfan_gsm For This Useful Post:
Old 05-02-2014, 07:00   #53 (permalink)
Member: 2116484
Thanks Meter: 35
Please support china android tab and Phone!!!!!!!!!!
Old 05-02-2014, 08:13   #54 (permalink)
pradeep_kus's Avatar
Member: 459784
Sonork: 100.1592448
Thanks Meter: 1,348
Panasonic Ez240 Call Log Problem Solved By Infinity-Box
Read User Code
Card found: S/N *********
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
User Code : 123456
Done!
Read Flash
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Read Flash Content
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32_2.bin
Done!
Elapsed: 00:00:51
Format Done
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:16
The Following 3 Users Say Thank You to pradeep_kus For This Useful Post:
Old 05-02-2014, 08:18   #55 (permalink)
Member: 459784
Sonork: 100.1592448
Thanks Meter: 1,348
Micromax X088 Illegal Use Power Done
X088 Illegal Use Power Done Without Flash !!
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:16
Cool.!!
Old 05-02-2014, 10:05   #56 (permalink)
Member: 459784
Sonork: 100.1592448
Thanks Meter: 1,348
Spice M5611 Msg Not Delete Problem Solved By Infinity-box
Msg Problem Solved Without Flash !!
Card found: S/N B3F6:0126
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:35
Read Flash
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Read Flash Content
ExtInfo  :
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000__.bin
Done!
Elapsed: 00:00:33
The Following 2 Users Say Thank You to pradeep_kus For This Useful Post:
Old 05-02-2014, 10:45   #57 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 970
Improve usb spd6531 boot, without bootkeys as some boxes do like Gp.. drag.....,superdoc....
BOOTKEYS ARE DIFFICULT AND NOT THE SAME
AGAIN ABOUT SPD SERVICE CABLE
NOT EVERY SPD PHONE USE MICRO-USB OR MINI USB
Old 05-02-2014, 12:00   #58 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
Please, read docs again. Service Cable Adapter NOT require modify. Just make it once and use with any USB cable.
Flash cable - most current phones use Micro and Mini. For other - Rx/Tx as way.
You can also use any box, with it tinternal PinFinder and after use it as port for CM2 module.
@pradeep_kus , please send me that Spice M5611 flash backup! Thanks!
Old 05-02-2014, 12:09   #59 (permalink)
Member: 459784
Sonork: 100.1592448
Thanks Meter: 1,348
Done Sir Chk Pm.........
Old 05-02-2014, 15:21   #60 (permalink)
bencharqui1's Avatar
Member: 1629321
Thanks Meter: 404
i9190w 6531 Flashing Done!
Phone found! [ 44 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
======= Flashing MCU
Mapping file ...
Mapping done
Processing file : i9190w 1_FullFlash.bin
Init ok, send data
Flashing Done!
The Following User Says Thank You to bencharqui1 For This Useful Post:
Page generated in 0.50374 seconds with 8 queries
