Old 12-08-2015, 07:11   #586 (permalink)
Member: 442808
Thanks Meter: 195
KECHAODA K27 Call Log Not working slove by format
Operation : Check/Read Info [ v1.07 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
 ====  Wait for phone...
Phone found! [ 174 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Elapsed: 00:00:21
Reconnect Power/Cable!
Operation : Read NV [ v1.07 ]
3. Insert battery
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Check data ...
Reading NV ...
Saved to : C:\InfinityBox\CM2SPD\phdata\backup\6531_NV_00008000_Kechaoda K27.nv
Elapsed: 00:00:28
Operation : Read FullFlash [ v1.07 ]
3. Insert battery
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Read Flash Content
Read Ok , collect info
Set FileInfo :
Model Vendor : Kechaoda
Model Name   : K27
ExtInfo Data : ENG
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_W25Q32_ENG__Kechaoda-K27.bin
Done!
Elapsed: 00:00:43
Operation : Format File System [ v1.07 ]
Settings : SmartFormat is On
3. Insert battery
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:09
Old 12-17-2015, 13:24   #587 (permalink)
Member: 2281696
salam Qmobile R250 spd can't flash by cm2 dongle
Old 12-17-2015, 14:19   #588 (permalink)
Member: 1043909
Thanks Meter: 60,926
Could you please explain the problem in details.
Old 02-29-2016, 09:06   #589 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Originally Posted by pradeep_kus View Post
Format FFS
Operation : Format File System [ v0.07 ]
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
CPU ID : 6531 , FDLStat : 0000
[0] Flash DIE : 00C8 0060 0017 0000
[0] Flash VEN : GigaDevice , GD25LQ64
[0] Flash CAP : 00800000
Format Block Done!
Done!
Elapsed: 00:00:27
Read Flash
Operation : Read FullFlash [ v0.07 ]
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Read Flash Content
Project  : SC6531_BAR
HWInfo   : SC6531_BAR
Compile  : 12-30-2013 08:42:35
Set FileInfo :
Model Vendor : Lianke
Model Name   : P100
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_12302013084235__Lianke-P100.bin
Done!
Elapsed: 00:01:07
If You This Model Flash File PLEASE Upload Here
Thanks & Regards By:
Gopal Parmar
The Following User Says Thank You to Yashbanswara For This Useful Post:
Old 07-18-2016, 09:51   #590 (permalink)
Crazy Poster
Member: 2522900
Thanks Meter: 7
sc7731c i have this i need to remove frp but software keeps hang
Old 07-20-2016, 11:38   #591 (permalink)
Member: 148515
Thanks Meter: 19,534
Please post operation log text.
Old 09-09-2016, 15:36   #592 (permalink)
Member: 2564038
Sonork: 100.1674499
Thanks Meter: 157
My Chines miracle 2 spd 1.21 version not open
Hello
infinity team My Chines Miracle 2 Working Fine All Module Full Working But SPD 1.21 module not open
old SPD module working
how to solve this problem please guaide me
Old 09-09-2016, 15:39   #593 (permalink)
Member: 2564038
Sonork: 100.1674499
Thanks Meter: 157
Qmobile r250
Download From Here
https://mega.nz/#!fM0XSLrT!4eL7Rafan...XukC9a5NiPZVSE
Old 09-09-2016, 15:41   #594 (permalink)
Member: 2564038
Sonork: 100.1674499
Thanks Meter: 157
Qmobile R250
Download link here
Old 09-09-2016, 15:42   #595 (permalink)
Member: 1043909
Originally Posted by malik_sajid View Post
Hello
Hello,
What is "not open" means ?
Do you see any error message ?
Old 09-09-2016, 15:46   #596 (permalink)
Member: 2564038
Sonork: 100.1674499
Thanks Meter: 157
Originally Posted by YellowBoss View Post
Hello,
Not Showing Any Error
and Not Open SPD 1.21 Module
Old 09-10-2016, 10:20   #597 (permalink)
Member: 2564038
Sonork: 100.1674499
Thanks Meter: 157
Hello,
Hello
infinity team my SPD 1.21 module not open
old spd module working fine
and mtk module old and new all working fine
Old 09-10-2016, 12:18   #598 (permalink)
Member: 1043909
Hello
Hello,
Do you have fault.bin file in folder with CM2SPD 1.21 ?
Old 09-10-2016, 16:34   #599 (permalink)
Member: 1418143
Thanks Meter: 353
I can't Read or Frp nor anything with SPD , I posted 9.08.2016 none car
Start at : [9/10/2016 / 12:58:27 PM]
Operation : Format File System / Reset Settings [ v1.21 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Initial Boot Failed!
Finish at : [9/10/2016 / 12:58:47 PM]
Start at : [9/10/2016 / 12:59:07 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Finish at : [9/10/2016 / 12:59:17 PM]
Start at : [9/10/2016 / 12:59:34 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Finish at : [9/10/2016 / 12:59:40 PM]
Start at : [9/10/2016 / 12:59:47 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
Boot failed!
Finish at : [9/10/2016 / 1:00:18 PM]
Start at : [9/10/2016 / 1:00:40 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [9/10/2016 / 1:01:07 PM]
Start at : [9/10/2016 / 1:01:25 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [9/10/2016 / 1:01:39 PM]
Start at : [9/10/2016 / 1:01:48 PM]
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
Phone found! [ 50 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Sync...
Init Ok , reset settings ...
Format Ok!
Done
Elapsed: 00:00:33
Finish at : [9/10/2016 / 1:02:21 PM]
Start at : [9/10/2016 / 1:04:30 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Finish at : [9/10/2016 / 1:04:38 PM]
Start at : [9/10/2016 / 1:04:46 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [9/10/2016 / 1:05:19 PM]
Start at : [9/10/2016 / 1:05:48 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [9/10/2016 / 1:06:00 PM]
Start at : [9/10/2016 / 1:06:13 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Finish at : [9/10/2016 / 1:06:23 PM]
Start at : [9/10/2016 / 1:06:30 PM]
Start at : [9/10/2016 / 1:06:34 PM]
Start at : [9/10/2016 / 1:06:37 PM]
3. Insert cable
Device boot not done
Check Drivers
Try again
Finish at : [9/10/2016 / 1:07:15 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Finish at : [9/10/2016 / 1:07:19 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Finish at : [9/10/2016 / 1:07:20 PM]
Start at : [9/10/2016 / 1:07:29 PM]
Operation : Check/Read Info [ v1.21 ]
2. Insert cable
Phone found! [ 50 ]
Open Port Failed!
Finish at : [9/10/2016 / 1:07:29 PM]
Start at : [9/10/2016 / 1:08:14 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [9/10/2016 / 1:08:22 PM]
Start at : [9/10/2016 / 1:12:42 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Sync...
Boot Files missing! Select SLDR or PAC file!
Boot failed!
Finish at : [9/10/2016 / 1:12:58 PM]
Start at : [9/10/2016 / 1:13:20 PM]
2. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
InitSvc Failed!
Finish at : [9/10/2016 / 1:13:27 PM]
Start at : [9/10/2016 / 1:13:42 PM]
2. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Sync...
Phone Initial Info :
Platform : MOCORTM_Pike_W15.18_Debug
Project : sc7731g_CP0_modem
HWInfo : sc7731g_CP0_modem
Compile : 04-14-2016 16:11:56
Phone Security Info :
IMEI [1] : 356071074383069
IMEI [2] : 356071074383077
BT_ADDR : 000000000000
SelfInfo :
BatVoltage : 3.724 V
Done
Start at : [9/10/2016 / 1:14:43 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [9/10/2016 / 1:15:19 PM]
Start at : [9/10/2016 / 1:15:32 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [9/10/2016 / 1:15:59 PM]
Start at : [9/10/2016 / 1:16:28 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Finish at : [9/10/2016 / 1:16:40 PM]
Start at : [9/10/2016 / 1:16:48 PM]
3. Insert cable
Phone found! [ 50 ]
Open Port Failed!
Finish at : [9/10/2016 / 1:16:48 PM]
Start at : [9/10/2016 / 1:17:00 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Finish at : [9/10/2016 / 1:17:08 PM]
Start at : [9/10/2016 / 1:17:45 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [9/10/2016 / 1:18:12 PM]
Loading : [Hovatek]-Itel-1407-W403-20151007.pac
CRVersion : BP_R1.0.0
PacCPUinfo : SC7730_UMS
PacVersion : 12123123
FastCheck : 0x0029FA4047
Loading files ...
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : nvitem_wcn.bin
File : prodnv.img
File : u-boot-spl-16k.bin
File : SC7702_sc7731g_band128.bin
File : DSP_DM_G2.bin
File : SC8800G_x30g_wcn_dts_modem.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : logo_AX45.bmp
File : cache.img
File : u-boot.bin
File : SC7730_UMS.xml
Load Ok!
Start at : [9/10/2016 / 1:20:56 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Finish at : [9/10/2016 / 1:21:05 PM]
Start at : [9/10/2016 / 1:21:11 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
Boot failed!
Boot failed!
Finish at : [9/10/2016 / 1:21:41 PM]
Loading files ...
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : prodnv.img
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : cache.img
File : u-boot.bin
Load Ok!
Start at : [9/10/2016 / 1:22:33 PM]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [9/10/2016 / 1:22:58 PM]
Start at : [9/10/2016 / 1:32:36 PM]
Operation : Read FullFlash [ v1.21 ]
3. Insert cable
Phone found! [ 50 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [9/10/2016 / 1:33:10 PM]
Start at : [9/10/2016 / 1:36:54 PM]
3. Insert cable
Phone found! [ 38 ]
Open Port Failed!
Finish at : [9/10/2016 / 1:37:09 PM]
Start at : [9/10/2016 / 1:37:30 PM]
3. Insert cable
Phone found! [ 38 ]
Open Port Failed!
Finish at : [9/10/2016 / 1:37:31 PM]
Start at : [9/10/2016 / 1:37:56 PM]
3. Insert cable
Phone found! [ 38 ]
Port Opened
Sync...
Finish at : [9/10/2016 / 1:38:11 PM]
Start at : [9/10/2016 / 1:38:34 PM]
3. Insert cable
Phone found! [ 38 ]
Port Opened
Sync...
Finish at : [9/10/2016 / 1:38:50 PM]
Start at : [9/10/2016 / 1:39:36 PM]
3. Insert cable
Phone found! [ 38 ]
Port Opened
Sync...
Finish at : [9/10/2016 / 1:39:50 PM]
Start at : [9/10/2016 / 1:40:19 PM]
2. Insert cable
Phone found! [ 38 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Sync...
Format Ok!
Done
Elapsed: 00:00:22
Finish at : [9/10/2016 / 1:40:41 PM]
Loading files ...
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : prodnv.img
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : cache.img
File : u-boot.bin
Load Ok!
Start at : [9/10/2016 / 1:42:48 PM]
3. Insert cable
Phone found! [ 38 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [9/10/2016 / 1:43:26 PM]
Start at : [9/10/2016 / 1:44:07 PM]
3. Insert cable
Phone found! [ 38 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [9/10/2016 / 1:44:30 PM]
Start at : [9/10/2016 / 1:55:56 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [9/10/2016 / 1:56:35 PM]
Start at : [9/10/2016 / 1:57:10 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [9/10/2016 / 1:57:49 PM]
Start at : [9/10/2016 / 1:58:05 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [9/10/2016 / 1:58:44 PM]
Start at : [9/10/2016 / 1:59:08 PM]
2. Insert cable
Phone found! [ 50 ]
Open Port Failed!
Finish at : [9/10/2016 / 1:59:13 PM]
Start at : [9/10/2016 / 1:59:32 PM]
2. Insert cable
Phone found! [ 50 ]
Open Port Failed!
Finish at : [9/10/2016 / 1:59:37 PM]
Start at : [9/10/2016 / 1:59:44 PM]
2. Insert cable
Phone found! [ 50 ]
Open Port Failed!
Finish at : [9/10/2016 / 2:00:01 PM]
========================= Start =========================
9/10/2016 / 2:20:47 PM
Card found: S/N : 82DD5E90 , v0132
Chinese Miracle II [SPD module] v 1.21
Start at : [9/10/2016 / 2:22:06 PM]
3. Insert cable
Phone found! [ 50 ]
Open Port Failed!
Finish at : [9/10/2016 / 2:22:20 PM]
Start at : [9/10/2016 / 2:25:22 PM]
3. Insert cable
Phone found! [ 50 ]
Open Port Failed!
Finish at : [9/10/2016 / 2:25:37 PM]
Start at : [9/10/2016 / 2:25:46 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [9/10/2016 / 2:26:24 PM]
Start at : [9/10/2016 / 2:27:34 PM]
3. Insert cable
Phone found! [ 50 ]
Open Port Failed!
Finish at : [9/10/2016 / 2:27:37 PM]
Start at : [9/10/2016 / 2:27:58 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [9/10/2016 / 2:28:07 PM]
Start at : [9/10/2016 / 2:28:15 PM]
3. Insert cable
Phone found! [ 50 ]
Open Port Failed!
Finish at : [9/10/2016 / 2:28:18 PM]
Start at : [9/10/2016 / 2:28:27 PM]
3. Insert cable
Phone found! [ 50 ]
Open Port Failed!
Finish at : [9/10/2016 / 2:28:49 PM]
Start at : [9/10/2016 / 2:29:21 PM]
3. Insert cable
Phone found! [ 50 ]
Open Port Failed!
Finish at : [9/10/2016 / 2:29:40 PM]
Start at : [9/10/2016 / 2:29:47 PM]
3. Insert cable
Phone found! [ 50 ]
Open Port Failed!
Finish at : [9/10/2016 / 2:29:47 PM]
Old 09-10-2016, 20:19   #600 (permalink)
Member: 1043909
@psytr0nic
What is your text means ?
Page generated in 0.38123 seconds with 10 queries
