05-03-2014, 16:52 | #76 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,541 | Micromax X088 Hang Problem Solved Code: Card found: S/N ********* Chinese Miracle II [SPD module] v 0.04 Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:30 Code: Reconnect Power/Cable! Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_W25Q32.bin Done! Elapsed: 00:00:51 Reconnect Power/Cable! |
The Following User Says Thank You to pradeep_kus For This Useful Post: |
05-04-2014, 09:01 | #78 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | karbon k111* not done and taking too much time in reading plz post flash file if any one have Port Opened Wait for phone ... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_W2 5Q32_2.bin Done! Elapsed: 00:13:25 Reconnect Power/Cable! Operation : Format File System Settings : SmartFormat is On Connect Powered Off phone. Insert battery ( If not used VPP ) ==== Wait for phone... Port Opened Wait for phone ... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Error while prepare! Format error, something went wrong Reconnect Power/Cable! |
The Following User Says Thank You to rehmani For This Useful Post: |
05-04-2014, 09:47 | #80 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
05-04-2014, 10:20 | #81 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,541 | Alcatel Virgin Vm575 / Alcatel 1060x Restart Problem Solved Read Info Code: Card found: S/N ********* Chinese Miracle II [SPD module] v 0.04 Operation : Check/Read Info 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Done! Elapsed: 00:00:16 Reconnect Power/Cable! Code: Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info ExtInfo : ²ا² Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_²ا²_.bin Done! Elapsed: 00:00:44 Reconnect Power/Cable! Code: Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to pradeep_kus For This Useful Post: |
05-04-2014, 10:31 | #83 (permalink) | |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | Quote:
karbon k111 SPD6531_00400000_W25Q32_2 - Download - 4shared - ABDUL MUSEEB REHMANI | |
05-04-2014, 10:54 | #85 (permalink) | |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,541 | Quote: Send Me Request I'll (Enable) For You And This File Is Only Infinity-Box User's | |
05-04-2014, 11:23 | #87 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,541 | Karbonn K103* Hang On Logo Done Problem Always Solved Without Any Flash !! Cool.. Read Flash Code: Card found: S/N ********* Chinese Miracle II [SPD module] v 0.04 Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_W25Q32_2.bin Done! Elapsed: 00:02:15 Reconnect Power/Cable! Code: Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
05-05-2014, 09:52 | #89 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Please, also send copy of all flash files/links to [email protected] - we must add all files to support area |
05-05-2014, 10:51 | #90 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn K595 Test Report Operation : Read User Code Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Check data... Can take some time User Code : 1122 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Format File System Code: Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Read FullFlash Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 117 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0016 0000 Flash VEN : GigaDevice , GD25LQ32 Flash CAP : 00400000 Read Flash Content Read Ok , collect info Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32.bin Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
The Following User Says Thank You to MyGSM World For This Useful Post: |
